Duncan Posted April 5, 2015 Report Share Posted April 5, 2015 Sorry to ask. I shifted through a LOT of searches and couldn't come up with what car this was from. This regular shift pattern 5-spd was in the 510 wagon I imported, and I need to get a slave cylinder for it. Anyone know which slave will work with this? Thanks for your help! RT side: Left side: Quote Link to comment
84720FourWheel Posted April 5, 2015 Report Share Posted April 5, 2015 Looks a lot like my trans. Looks like a 5 speed out of a 720 based on the top gear switch. Fs5w71b Quote Link to comment
MikeRL411 Posted April 5, 2015 Report Share Posted April 5, 2015 Aside from improperly referenced in an acceptable format photos, this poster is in Huntington Beach CA per his/her katakana. If you want help, meet us as least half way! Instructions on proper photo posting formats are in the very first subject area. No, I won't hold your hand, grow up! Read the introductory section before you dump on us. Quote Link to comment
ggzilla Posted April 5, 2015 Report Share Posted April 5, 2015 What is your problem, Mike? Aside from improperly referenced in an acceptable format photos, this poster is in Huntington Beach CA per his/her katakana. If you want help, meet us as least half way! Instructions on proper photo posting formats are in the very first subject area. No, I won't hold your hand, grow up! Read the introductory section before you dump on us. 1 Quote Link to comment
ggzilla Posted April 5, 2015 Report Share Posted April 5, 2015 Yes, it looks like a 71B 5-speed. If its a non-US Market model, we won't be able to tell which car it came from. For example L18s were sold into the 80s in Japan, and L20B into mid-80s in AUS. A 280ZX slave will probably bolt up to it. 1 Quote Link to comment
Duncan Posted April 5, 2015 Author Report Share Posted April 5, 2015 Thanks for the help guys. (except Mike, of course) Hey Mike, sorry my photos are improperly formatted. I could not find any "how-to" on formatting photos. Maybe you could send me a link? BTW, how do you breathe with your head so far up your ass? 3 Quote Link to comment
Dolomite Posted April 5, 2015 Report Share Posted April 5, 2015 Looks like a zx 5spd to me, try that one. Pretty much any l series slave will work, some(620) have straight bleeders that are hard to get a piece of tubing on, but they all work in a pinch. I've had 510, 620, and zx on mine because of what was available at the time. Quote Link to comment
datzenmike Posted April 5, 2015 Report Share Posted April 5, 2015 It's an L series 5 speed made after 1980 but imported? From Japan? I don't know what the emissions standards were there but here, if this was 'imported' from Texas, this would be from a carbureted vehicle. Here, this would only be found on the 1980 2wd 720 truck. Any slave used on any 71B 4 or 5 speed should be fine. If this for use in a truck get a '77-'79 620 truck slave, the fitting is on the end for torsion bar clearance. If for use in a car get a 290z, 280zx or 810/Maxima, the fitting is on the side. If you want to ID the transmission precisely, pop it off, place in first and place a mark on the input and output splines. Have someone turn the input exactly 10 turns while you count the output turns. 2 3/4 turns... wide ratio, definitely a 720 truck transmission (most likely) 3 turns......... mid ratio, 810 or Maxima transmission 3 1/4 turns... close ratio transmission from a 280zx. (very unlikely as it has top gear switches in it) PL510 or A10? Not that it matters. Looks like a gear reduction starter on it. Pictures look fine to me. Quote Link to comment
Stoffregen Motorsports Posted April 5, 2015 Report Share Posted April 5, 2015 Most any Datsun L or Z series slave will bolt up to it, the question is which one do you want? 510's have manually adjusting slaves with a threaded rod and a return spring, they must use the return spring or the pressure will pack up and destroy the thrust bearing and crank in the engine. Later, the Z cars (and others) use a self adjusting slave with a solid rod and no return spring. Trucks use a slave with the inlet coming straight out the front of the cylinder body. I believe any of these will work, providing you use the corresponding clutch fork. The manual adjust slaves use a fork with a hole in it. Quote Link to comment
Duncan Posted April 5, 2015 Author Report Share Posted April 5, 2015 Thanks again folks. This is my first 510, and I have an Aussie Import that has had some stuff changed on it, so not having a bunch of 510's under my belt makes this a bit of a challenge sometimes. The existing slave has a solid rod and no springs, so I will assume it's a Z unit. Appreciate the help! 1 Quote Link to comment
ggzilla Posted April 5, 2015 Report Share Posted April 5, 2015 If the transmission has NMCA cast letters then its from a 910. Quote Link to comment
datzenmike Posted April 5, 2015 Report Share Posted April 5, 2015 I have at least two 71B 5 speeds that were NMCA cast in Australia. One was an '85 CA18ET 200sx and the other a '85 or '86 720 gas engine 5 speed. Quote Link to comment
