UnderControl Posted March 10, 2020 Author Report Share Posted March 10, 2020 This is one time I was looking to avoid a project, I've been searching for a replacement daily for a while and for whatever reason I'm into murican land yachts at the moment. Also for a change of pace this isn't rusty. 1 1 Quote Link to comment
UnderControl Posted March 11, 2020 Author Report Share Posted March 11, 2020 Put a shiny new OE fuel filter on the new beater. And then got to put the cruddy old one back on when it immediately started leaking. Then I got some progress in on the bike. Good bit of cleaning, a couple new seals, and new sprocket. 1 Quote Link to comment
UnderControl Posted March 12, 2020 Author Report Share Posted March 12, 2020 Made some more what I guess could be called progress. Mostly just more disassembly, but also got the rear sprocket swapped so I could have that getting something done dopamine. 3 Quote Link to comment
UnderControl Posted March 13, 2020 Author Report Share Posted March 13, 2020 Fuck this c clip and seal in particular. Two hours plus or minus a bit for looking for tools, and forks are ready for new oil. 1 Quote Link to comment
UnderControl Posted March 17, 2020 Author Report Share Posted March 17, 2020 Got a few days until the replacement fork c clip shows up so taking a little extra time cleaning stuff up. Instead of just replacing the seal on the caliper I gave it a proper clean and paint. Getting started on my bike rice with a mini chop and and dechroming of the front fender. Rear will be getting the same treatment and both will finished in satin black. 2 Quote Link to comment
UnderControl Posted March 19, 2020 Author Report Share Posted March 19, 2020 Fenders shopped and painted. Hopefully they'll be dried enough to bolt back on without scratching them to hell. Almost back together, got a few things to finish up once it's back on the ground. 2 Quote Link to comment
UnderControl Posted March 20, 2020 Author Report Share Posted March 20, 2020 (edited) Back on the ground and together. Just need to put oil in it, hook the fuel lines up and bleed the front brake and probably remove one of the baffles from the muffler. Rear fender is chopped to be flush with the bottom of the plate. Weather looks pretty meh for the next few days so likely wont get to ride until next week, but looking forward seeing how it runs and sounds. Edited March 20, 2020 by UnderControl 3 Quote Link to comment
UnderControl Posted March 26, 2020 Author Report Share Posted March 26, 2020 I've gotten the bike out for a couple quick test rides. Runs pretty well, but definitely gonna need to do a proper sync on the carbs. New exhaust is louder than expected with both baffles, it has a deeper tone and kinda sounds like like a scooby. Neighbor was pressure washing when I got bad so no terrible cell phone audio of the new pipes. Plugs look just about right compared to the lean look of last season's. Pics for no real reason. 2 Quote Link to comment
]2eDeYe Posted March 26, 2020 Report Share Posted March 26, 2020 Cause it's a nice looking bike 🙂 Quote Link to comment
UnderControl Posted March 31, 2020 Author Report Share Posted March 31, 2020 Really starting to wish I had taken an extra couple of days to paint the front turn signal housings and mount while I had the forks out, last real chrome left. Back to the mustang. Started on correcting the mistake of cutting the upper flange. 1 Quote Link to comment
UnderControl Posted April 2, 2020 Author Report Share Posted April 2, 2020 Moving along, first of the new flanges is underway. The cowl definitely didn't warp at all when welding the upper flange back on. With the corner pressed down to where it should be you'll see I didn't totally fubar the new flange height. 2 Quote Link to comment
UnderControl Posted April 9, 2020 Author Report Share Posted April 9, 2020 I've opted to start on the side flanges before doing anymore with that large front one. This largely due to it being considerably easier to pop a fender on to check for fit than the hood. First side started. I didn't really feel like pulling the bead roller out of the big vice, and don't really have a good spot to permanently mount the old small vice, so I got a bit creative. Added bonus that I didn't have to keep walking back and forth to the bench to grind a little more off. 3 Quote Link to comment
UnderControl Posted April 15, 2020 Author Report Share Posted April 15, 2020 More stuff getting done, and I'm really getting some mileage out of the dual vice setup. 1 Quote Link to comment
UnderControl Posted April 16, 2020 Author Report Share Posted April 16, 2020 Cleanup and a little prep. 1 Quote Link to comment
UnderControl Posted April 23, 2020 Author Report Share Posted April 23, 2020 There be flanges around the the whole perimeter of the upper cowl. Still gonna be a good bit of work to finish them out, but they're there. 1 Quote Link to comment
UnderControl Posted April 24, 2020 Author Report Share Posted April 24, 2020 Flanges all welded up and mostly dressed. 1 Quote Link to comment
UnderControl Posted April 26, 2020 Author Report Share Posted April 26, 2020 Looking forward to being done with cowl work. 4 Quote Link to comment
UnderControl Posted April 29, 2020 Author Report Share Posted April 29, 2020 Tonight I practiced patience and restraint. Three and a half hours later. This being the most visible and easily warped so I actually took my time and even employed air where I got things a bit too hot. 3 Quote Link to comment
UnderControl Posted April 30, 2020 Author Report Share Posted April 30, 2020 Most of the way there. Little more grinding left, then welding in some low spots, then more grinding and then I should be ready for hammer work. 1 Quote Link to comment
UnderControl Posted May 6, 2020 Author Report Share Posted May 6, 2020 So, I patted myself on the back a bit early, turns out due to some mistakes the upper cowl is pretty fucked. While I contemplate my life choices I opted to turn my attention to another project I've been thinking about for a while. I've been wanting a belt sander for a while and since I keep not buying the reasonably priced used belt/disc sanders when they pop up locally I decided to see if I can come up with a decent solution out of some salvaged parts and scrap. 1 Quote Link to comment
UnderControl Posted May 7, 2020 Author Report Share Posted May 7, 2020 A little less doom and gloom about the cowl today. Researched some shrinking techniques and tried it out a bit and have the cowl mostly fitting again. It does mean that there will be a lot more body work than I was hoping for, but should be salvageable. Otherwise spent the rest of the night giving the dremel a hot supper boring this large nut out to accept this bearing for the drive pulley for the sander. 1 Quote Link to comment
UnderControl Posted May 12, 2020 Author Report Share Posted May 12, 2020 Got some more done on the belt sander. One of my objectives with this sander is to be able to be able to switch between vertical and horizontal. 1 Quote Link to comment
UnderControl Posted May 13, 2020 Author Report Share Posted May 13, 2020 Motor mount and tensioner setup are in. Gonna have to figure out something for the drive pulley in my test the belt was just slipping. I was hoping since the washing machine's pulley was smooth this would work, but not so. I tried this piece of rubber with a couple laps of elecchickens tape, and it worked for a moment before ripping the tape off. Quote Link to comment
UnderControl Posted May 15, 2020 Author Report Share Posted May 15, 2020 Belt sander, now with 100% more belt. Tensioner is super simple and I definitely didn't weld the upper angle to the wrong side at first. Tracking adjustment took a little more figuring. Still gonna need a table, a platten, and some way of actually securing the rotaty bit, not to mention getting the electrical to something nicer/safer than the bench test setup I've been using. I did give it a little test spin and it actually worked. 3 Quote Link to comment
UnderControl Posted May 19, 2020 Author Report Share Posted May 19, 2020 Short night tonight, got started on the table and platten. Base of the table is a rest from an old busted bench grinder and it is bolted through the two panels and helps keep it in situ. 1 Quote Link to comment
