Kalani's '72 DIME
Kalani
can i have your 5 spd and rear passenger quarter ... by tthe way on the front run 7" springs ... not 8's .... 7"  200 lbs ... i had to ask for hem from gabe ... they will keep  the adjust free from the tire and wheels and grind a flat side on the outside of that retainer ring
  • Replies 638
A little more work
87554949-0E1F-460C-9839-141E3F760E4D_zps
F1AB1061-96D7-4D72-B41C-D288B4009849_zps
7368C15A-92F9-4C07-9965-C59D7BEB2443_zps
8EB28590-BAFC-4512-8180-CA96A1F69649_zps
Not quite this far ahead. Head is just on top. Waiting for rings. *cough*bus..ta*cough*
3D42344D-E63E-4724-81D3-904ECCFDDBBC_zps
Anyone need stock L16 rod bearing part number?
633C54B7-2A4B-4189-90D5-0B53D7638FD8_zps
  • Like 3
Timing cover blasted and washed.
BA3D124D-EFCE-4133-A97C-12AF428282BA_zps
Pistons cleaned and ready fur rings.
D1C7E072-3E00-45D5-9864-4753400C5B94_zps
Pistons going in.
B287E211-08AF-4558-A03B-213A2289C2ED_zps
Pistons done
0BCCAC60-D99C-4E7D-BE3B-EEC742D3C832_zps
0605DE4D-13DD-416C-B344-648BC8BDEB3D_zps
Head and timing cover mocked up
DD99E170-83BE-4B5C-9D48-2DCB8ADD2D79_zps
Done for the day
3664797A-482B-4F21-AEF0-6FA977BF983F_zps
  • Like 5
Now I need a plug.......
Feel free to correct me if I'm wrong but I'm reasonably sure that that plug serves as a free air breather for the box in addition to the fill port plug. Blocking it off entirely will likely cause the seals to leak after the header heat warms up the box and subsequently the oil/air inside.
I believe you are correct, I would suggest drilling a very small hole in the plug for ventilation.
