jrock4224 Posted March 10, 2015 Report Share Posted March 10, 2015 can i have your 5 spd and rear passenger quarter ... by tthe way on the front run 7" springs ... not 8's .... 7" 200 lbs ... i had to ask for hem from gabe ... they will keep the adjust free from the tire and wheels and grind a flat side on the outside of that retainer ring Quote Link to comment
banzai510(hainz) Posted March 11, 2015 Report Share Posted March 11, 2015 i got 7 inch springs also. get it low. I think mine are 180 Quote Link to comment
skyblue Posted March 11, 2015 Report Share Posted March 11, 2015 A little more work Not quite this far ahead. Head is just on top. Waiting for rings. *cough*bus..ta*cough* Anyone need stock L16 rod bearing part number? 3 Quote Link to comment
mrbigtanker Posted March 11, 2015 Report Share Posted March 11, 2015 Wow man that portagee is busy cutting hair and your doing the dirty work.lol 3 Quote Link to comment
banzai510(hainz) Posted March 11, 2015 Report Share Posted March 11, 2015 Im sure you know make sure that head on TDC when you reinstall. I see the dowel down Quote Link to comment
Busta Nut Posted March 11, 2015 Report Share Posted March 11, 2015 Not quite this far ahead. Head is just on top. Waiting for rings. *cough*bus..ta*cough* Ummmmm.....ya......my bad..... 1 Quote Link to comment
skyblue Posted March 11, 2015 Report Share Posted March 11, 2015 Im sure you know make sure that head on TDC when you reinstall. I see the dowel down Yea I will. The Pistons aren't even in yet. 1 Quote Link to comment
Kalani Posted March 11, 2015 Author Report Share Posted March 11, 2015 Wow man that portagee is busy cutting hair and your doing the dirty work.lol my homies>your homies haha jk if I knew how. 1 Quote Link to comment
jrock4224 Posted March 11, 2015 Report Share Posted March 11, 2015 Wow man that portagee is busy cutting hair and your doing the dirty work.lol funniest ray quote ever 1 Quote Link to comment
Busta Nut Posted March 12, 2015 Report Share Posted March 12, 2015 Blah blah blah.....Datsuns.... Steering gear plug was broken..... .....lets get it out..... Hammered my big screw driver in....worked like a charm.... 2 Quote Link to comment
Busta Nut Posted March 12, 2015 Report Share Posted March 12, 2015 Now I need a plug....... ......there's gotta be one here... Found one..... 3 Quote Link to comment
Busta Nut Posted March 12, 2015 Report Share Posted March 12, 2015 Time for a quick cleaning.....scraped all the big crap off.... Wire brushed the rest..... 4 Quote Link to comment
mrbigtanker Posted March 12, 2015 Report Share Posted March 12, 2015 Car show man, all the way. 1 Quote Link to comment
Busta Nut Posted March 12, 2015 Report Share Posted March 12, 2015 Car show man, all the way. JCCS better look out!! :lol: 4 Quote Link to comment
jrock4224 Posted March 12, 2015 Report Share Posted March 12, 2015 nice busta.... good work as always 2 Quote Link to comment
jrock4224 Posted March 12, 2015 Report Share Posted March 12, 2015 Kalani I know a real good powder coat shop in Washington.lol Looking good Bu La ia. Haaaawaiian :thumbup: true story 3 Quote Link to comment
skyblue Posted March 14, 2015 Report Share Posted March 14, 2015 Timing cover blasted and washed. Pistons cleaned and ready fur rings. Pistons going in. Pistons done Head and timing cover mocked up Done for the day 5 Quote Link to comment
mrbigtanker Posted March 14, 2015 Report Share Posted March 14, 2015 looking good. 2 Quote Link to comment
datson4life Posted March 14, 2015 Report Share Posted March 14, 2015 Nice progress on this thing! 4 Quote Link to comment
skyblue Posted March 27, 2015 Report Share Posted March 27, 2015 Stopped by last night and got the chain on. 5 Quote Link to comment
Kalani Posted March 30, 2015 Author Report Share Posted March 30, 2015 :w00t: :w00t: :hyper: mikes the manggg. My lady just went back to school so now its crunch time for me 2 Quote Link to comment
Just Joel Posted March 31, 2015 Report Share Posted March 31, 2015 Now I need a plug....... ......there's gotta be one here... Found one..... Feel free to correct me if I'm wrong but I'm reasonably sure that that plug serves as a free air breather for the box in addition to the fill port plug. Blocking it off entirely will likely cause the seals to leak after the header heat warms up the box and subsequently the oil/air inside. 1 Quote Link to comment
510T Posted March 31, 2015 Report Share Posted March 31, 2015 Feel free to correct me if I'm wrong but I'm reasonably sure that that plug serves as a free air breather for the box in addition to the fill port plug. Blocking it off entirely will likely cause the seals to leak after the header heat warms up the box and subsequently the oil/air inside. I believe you are correct, I would suggest drilling a very small hole in the plug for ventilation. Quote Link to comment
Busta Nut Posted March 31, 2015 Report Share Posted March 31, 2015 You guys are probably right...... ........mines been plugged since I got the car....... Is that bad?? :confused: :lol: Quote Link to comment
510T Posted March 31, 2015 Report Share Posted March 31, 2015 Good info here: http://www.the510realm.com/viewtopic.php?f=29&t=24950 1 Quote Link to comment
