DatMo
Feels like autumn.
Yeah, he said he bought that cross member which means he'll need a z isolator.
That valve cover will hit ;)
Share this post
Link to post
I'm sure it will but I'll see what I can do for clearance :/
I'm not looking forward to gettin that z isolator either.
Share this post
Link to post
Rock auto... Cheap :)
you got a point there. lol.
I won't buy it until i need it. im moving so don't wanna waste time and crap.
Share this post
Link to post
suspension done. so damn solid. Thank god.
Share this post
Link to post
So here's some pics of what has been happening. I have not had any time so I was not able to do much work lately.
I put in the engine last night so it would be easier to move and I've been doing my researcher because my l20 is fitting way too high.
It was extremely difficult to fit in and I know you need the l16 brackets and l16 mounts which I have.
The engine still sits high and my mounts seem to be about 1.5 inch thick which seems way too thick.
Also, my clearance from the oil pan to xmember is about two fingers or an inch. So I'm assuming it's my mounts for sure.
Here's some pics of the mounts, engine in, and suspension.
I do have to remove the engine later and finish painting.
It's getting there.
Share this post
Link to post
I think it's a combination of a few things, valve cover for sure and also the mounts look huge! I am about to put in a L20B into my 510 and purchased NOS L16 engine mounts and they measure 1 1/8 inches.
Share this post
Link to post
A lot of the time when you buy new ones they are a lot taller than the original ones. In the past I've seen people order 5-6 from Rockauto just to get two that are the right height.
They work fine for an L16...   ^_^
Oh, and that Coonan. Never seen it work with an L20b.  :rofl:
In the past, the easy solution was always to remove the engine brackets, slots the holes downward, then the engine will sit a good bit lower.
Share this post
Link to post
I'll slot the engine brackets but I'll also need some nos mounts. Where did ya get yours from?
Share this post
Link to post
A Fram!!! Nnnooooooo!!!!!
What's so bad. lol. I've used em for awhile with no problems?
Share this post
Link to post
You can get them from Nissan.  I don't know the PN but I'm sure you could find it with a little searching.  I think I paid $20 a piece a few years ago.
Share this post
Link to post
Fram=bad. From filter are just plain terrible, mostly cardboard inside with about half the pleats as a Wix or Napa gold.
Share this post
Link to post
What he said.   B)
Share this post
Link to post
I wasn't aware. Thanks. I'll be heading to napa this weekend to pick one up then.
I'll have to see, the site they gave me was for about $100 for both. I'm gonna see where I can get them for a bit lower. I'm pretty tight on money so need something a bit more on my budget for the moment.
Share this post
Link to post
Its more than just bad filtering from FRAM. You will find more reports of Fram filters killing motors than any other filter. Its just not worth the risk. There is a mod on the CA18 section of NicoClub that blew up a motor, because he drove 50 miles on a Fram (just was going to use it to get home). Filter imploded, went through the pump, and clogged the oil feed to the head. Also went through the crank, and ended up in all the main and rod bearings. Its not worth it.
Share this post
Link to post
Holy fuck lol. I wasn't that aware. Luckily I had never had problems before hand but I'll be on my way to get a Napa one soon.
Share this post
Link to post
Welp, I just got my wheels.
Here's a cute picture of me with them.
Share this post
Link to post
Try not to look so......excited...
Being that close to real Hayashi Streets? Not possible...   :rofl:
Share this post
Link to post
I'm pretty much excited about anything and everything lol.
Share this post
Link to post
Been that close to real hayashi streets on a real SSS coupe......and I don't think I was that excited, just not an excitable guy I guess. :lol:
Share this post
Link to post
