kaoss Posted September 6, 2010 Author Report Share Posted September 6, 2010 Both sides on the front are done now. Still needs permanent welding, and I have to plate the bottom of the frame but I'm going to burn it all in later. Cycled the front, everything works great. It'll be on a shorter tire, and I won't know how much of a z it'll need to make it lay until I get the rear end tore down. Front Down. That'll work. Down. Up. And compared to my Frontier's frame . Quote Link to comment
Slammy Posted October 9, 2010 Report Share Posted October 9, 2010 Can you flip the king pins upside down? Looks like you could bolt 720 control arms right to that truck and then run dropped spindles Quote Link to comment
]2eDeYe Posted October 9, 2010 Report Share Posted October 9, 2010 I think you can but you have to get/make custom bushings. It might throw off the camber though, not sure. You can use the 720 stuff but you need a custom upper arm. Quote Link to comment
kaoss Posted November 7, 2010 Author Report Share Posted November 7, 2010 Got the leaf springs removed, axle center and tacked to frame using the old u-bolts. Looks like I can use a small notch in the frame to get this thing to lay. Next on the list is to cut off some random brackets on the frame and then build a cross member. Quote Link to comment
Pacific coast Datsun Posted November 8, 2010 Report Share Posted November 8, 2010 Just wondering what brand bags will you be running up front ? Quote Link to comment
kaoss Posted November 8, 2010 Author Report Share Posted November 8, 2010 Those are Slam Specialtie's RE-6's. Quote Link to comment
King620 Posted November 12, 2010 Report Share Posted November 12, 2010 love the old school paint Quote Link to comment
510kevin Posted November 12, 2010 Report Share Posted November 12, 2010 anymore progress? ive been lookin for another 620 to bag and body, just gotta find one on the cheap if i'll be cutting it up :D looks good, cant waitto see it done! Quote Link to comment
kaoss Posted November 13, 2010 Author Report Share Posted November 13, 2010 Maybe tonight, if I can get out from in front of the Xbox :D Quote Link to comment
Pacific coast Datsun Posted November 15, 2010 Report Share Posted November 15, 2010 Those are Slam Specialtie's RE-6's. Thanks for the bag info. Ive heard that the RE-5 will work on a kingpin Datsun truck without having to "cup" the frame. Either way yours looks clean & you know there will be no rubbing issues. Quote Link to comment
kaoss Posted November 15, 2010 Author Report Share Posted November 15, 2010 I thought about going with the 5's, but I knew that the 6's would fit with a little more work. A Toyota front clip swap is were it's at though. Cut out the peices to build a cross member out of some scrap I had laying around. Quote Link to comment
kaoss Posted December 8, 2010 Author Report Share Posted December 8, 2010 Welded all of that scrap together into a cross member, plated the ends, and tacked it in. Quote Link to comment
fisch Posted December 8, 2010 Report Share Posted December 8, 2010 And my awesome wheels. It looks like an inch and half Z is in store for this thing in order for it to get to lay. Totally bitchin choice on the wheels man! I was looking into Pathy spare tires for my '59 at one point. But they aren't 18"! Quote Link to comment
kaoss Posted December 10, 2010 Author Report Share Posted December 10, 2010 The start of my lower link bars out of 2*2 .025 wall. Notching the ends with a chop saw and a grinder. Too bad this is a scrap peice that I practiced on, and not the actual link bar. If you never knew that you could do this, check out this thread. Chop saw notching 101 Quote Link to comment
kaoss Posted December 18, 2010 Author Report Share Posted December 18, 2010 Found some 17" 10 year old billet wheels! Quote Link to comment
Pacific coast Datsun Posted December 20, 2010 Report Share Posted December 20, 2010 I like the 17's better :cool: Quote Link to comment
kaoss Posted December 20, 2010 Author Report Share Posted December 20, 2010 I hope that they tuck. I'll be real sad if they don't. Quote Link to comment
]2eDeYe Posted December 20, 2010 Report Share Posted December 20, 2010 Nice looking wheels :cool: Quote Link to comment
Wide14u Posted December 21, 2010 Report Share Posted December 21, 2010 i like all that you have done i want more Quote Link to comment
kaoss Posted December 21, 2010 Author Report Share Posted December 21, 2010 Next week there will be a lot more. Quote Link to comment
kaoss Posted December 28, 2010 Author Report Share Posted December 28, 2010 Got the lower link bars welded together, and the axle cleaned off of the four link tabs. Still have to finish my uppers. I hope to have the four link hung by Wednesday night. Quote Link to comment
Wide14u Posted December 28, 2010 Report Share Posted December 28, 2010 all your stuff ends up being so good Quote Link to comment
kaoss Posted December 30, 2010 Author Report Share Posted December 30, 2010 I had to take my link bars to a fab shop and have the bungs tapped out to accept the rod ends after I welded them up, only cost me $20 bucks, but these silly little $20 things always add up, like the $50 in grade 8 hardware for the link bars. Any ways, on to some pics. Got everything mocked up, small truck, but it'll all fit. Ended the night with a 2 link. Uppers are tacked in, next time it'll be the lowers. That's it for this week! Quote Link to comment
76bullit Posted January 1, 2011 Report Share Posted January 1, 2011 It may be a little too late to clue you into the fact that a 521 axle helps tuck wheels in the rear. I cant remember how much more narrow it is but i tucked titan wheels with a 3 inch body drop. Nice job by the way. Quote Link to comment
kaoss Posted January 1, 2011 Author Report Share Posted January 1, 2011 I was actually going to start a thread to see if anyone knew the WMS to WMS on a 521. There is one in the yard here, and it's not really too late to swap it. Quote Link to comment
