Top of the line 2 post Auto Lifts
I'm in the market for a new 2 post auto lift for my garage/workshop. I've only used a friends old junker lift and don't know anything about what is good and what is bad. I have $3k-$4k max to spend. Can someone help shed some light on what lifts are great for the money, safe and reliable? What have you used and what are your opinions? Help will be appreciated. I will post pics of my new setup once it is purchased and installed.
  • Replies 22
It's Ratsun man, No one here can afford one. I have 3 shops here in my complex That do auto repair and all of them use lift's just like the one's you posted.
BendPack. So they must be good.
Bend pak is good. Top of the line is Mohawk and Rotary make nice lifts. I personally have used a Dannmar 10AC in my shop for the past 2 years with no  problems. To bad your not closer, I'd sell you mine as I am moving out of the shop. :crying:  At minimum make sure whatever you get is ALI/ETL certified. Watch out for those $1500 lifts. I saw one in person while I was looking to buy the one I have now and ran the other way! Really poor welding and reinforcing design.
Mark
Bend pax is a good brand but the leg design is what I don't like. Worked in a shop with lifts of similar set up and they were pain to get low/small cars on. A lot of pushing back and forth, these you have to be pretty dead center or you may not hit all your jack points. I know it was a bit$%! trying to get my 210 to fit on one. Not dissing the brand, it's a good work horse but doesn't like certain type of cars.
I do not know how true this is, but it seems to me that when small narrow cars, like our Datsuns were popular, most garages used a single post lift, or they had twin posts, that fit the rear axle, and fhe frame at the front of the car.  Both posts under the car.
Now it seems the twin side post lift is popular, and there is not as many narrow cars around anymore.
Was the issue that you had trouble getting the arms underneath a lowered car? Or was the problem getting the arms to extend to the jack points? From what I understand, a lot of the newer lifts' arms extend/telescope far to acomidate the new small Eco car movement
I have worked on cars for over fifteen years and have used Rotary, Hunter (alignment racks), and Mohawk in the shops I have worked in. Most shops I worked in had Rotary/Rotunda. Only failures I ever saw with Rotary was user related. Too heavy of a vehicle, off balance load, not paying attention when lowering, user rigged up locks or controls, or not dropping to locks before working. Only worked in one shop (Sears) with Mohawk, half of the lifts there were broken, but unsure as to why, I was only there three months. One shop had a Bendpack lift that they bought used, the thicker arms made it hard to fit under a lot of cars. The arms also sat higher off the ground than the Rotary next to it which didn't help with clearance either. Because of that I didn't like using it. Thcker and bigger is not always a good thing.
i have used bend pack for over 14 years, i still have a 4 post and 2 post from when i opened my shop and now have 7 total--- u will need to maintain any you buy -lube cables, keep mounting nuts tight, etc   bend pack has excellent customer service if and when needed   -we also service heavy fleet trucks with no issues
Nice, I dream of having my own some day. Shit in Phoenix you can find a nice used one thats less than 8 years old for  like 1500 or less sometimes. But I would need to own a shop first.....
Install one on top of your "ultimate honda", I thought it does everything.
-Robert
