DP Disc brake bracket build for kingpin trucks - mklotz70
mklotz70
  • Replies 78
There may be a vid or two that should be before these, but I really wanted to get these up for feedback.  I've gotten some great feedback on youtube, so I'll be changing them up just a bit.....more work! :(
Mike looks great.  Beveling the pin part instead of the bracket hole might work better. Also heating heavy metal before welding helps with penetration.
I do not believe you will have any problems with the welds as these were done.
Thanks Charlie.
I did the test weld pretty fast and loose.  The welds on the were done at a much slower rate.  I'll try to get some better vid of it when I do some more.  I need to come up with a way to put my camera behind a welding helmet.
In the next couple of days, I'll start doing a bit of rework on the standoffs to prep them for the perimeter welds.  I'll also chamfer the  brackets and tabs.  Hmmm.....I should probably get a couple of new belts for the grinder!! :)
lol.
I have 3 auto-darkening helmets. I may just see if I can take the cartridge out of one and put in front of the camera.  I might use the point and shoot, but it limits the clip to 10 min....which should be plenty.
That thing was awesome!!!!  Thanks! :)    My brain hurts enough just trying to learn what I'm doing on what I've got.......I'd pass out with something like that!! :)
You wouldn't pass out, but we likely would have to come to your house to check up on you, to make sure you were still alive. :)
Maybe one of the other guys knows better, but I'm sure that machine is over $750k.  I wouldn't be too surprised to hear it's a good bit more than that............
..........I just did a bit of digging.  An auction site lists replacement cost at 1.1 million.
I don't know much so bare with me,,, won't moving hub out with spacer put more of a load on the bearings  then the first type spacer you made/make?
OH GEEEZE !! i must have clicked out of the 411 thread and posted here somehow,,,,,,,,,, well we all know how,, cuz imma dumbass really.
Pushing the rotor and wheel out 1/8" with the spacer between the rotor and hub would put a bit more load on the outer bearing and the spindle.
Pushing the entire hub/rotor/wheel out 1/8"  with the bearing spacer would put a bit more on the spindle, but the bearings should see the same load.  Either way, I think it would be fairly negligible.  People put 1/2" wheel spacers on with longer studs without much issue.  The outer bearings on the 411 and roadster are bigger the same as the truck outer bearing.
I'll need to borrow a hub before I can check things out much further.
