tubbedbaggedstockfloored65 Posted January 2, 2014 Author Report Share Posted January 2, 2014 This is really bummin me out first day of new years and my truck wants to catch fire Quote Link to comment
GRpufnstuf Posted January 3, 2014 Report Share Posted January 3, 2014 There are good how to write ups for the internal reg install. Sounds like you have a shorted wire in the loom leading to the regulator (just a guess) Quote Link to comment
Boxcar Posted January 3, 2014 Report Share Posted January 3, 2014 Convert to a Delco 1 wire alternator. Cheap , wiring is a snap, simple conversion.... Quote Link to comment
tubbedbaggedstockfloored65 Posted February 9, 2014 Author Report Share Posted February 9, 2014 So after hours and days of knuckle smashing in noze freezing weather(1) and Brand Spankin New parts(2) as stated below and a good washing inside and out underneath and above i officially have a running and driving datsun 620 4x4 dealer prep2 tabs2 insurance2 front window2 front window rubber seal2 windshield wipers2 new wiper motor2 rubber foot pedal covers1 removal of paper towels and leaves from heater2 spark plugs2 fuel filters2 fuel pump2 oil2 oil filter2 air filter2 alternator2 voltage regulator2 2 electric fans and toggles2 50 feet of wire2 assorted wire connectors2 carpet dash pad2 volt gauge2 water temp gauge2 white face gauge covers2 all light and dash led replacement enhancement1 hours of dash wiring non sense2 rims2 tires2 passenger mirror2 front datsun emblem2 seatbelts2 seat cover2 air fresheners2 heater console and vent knob2 both vent defrost tubes1 radiator flush2 radiator coolant1 re wiring of harness from ignition to other end1 re wiring of reverse lights2 back up light switch2 front seal1 fuel tank flush1 water pump fan clutch removal2 rubber mud floor liners2 seahawks liscense plate frame2 gas cap1 straightening of front lip2 two bumper brackets2 rubber fuel line replacemen1 cleaning and removal of bees nests in door vents1 dent removal of front left fender1 cleaned all light bulbs and lense covers inside and out2 glass fuses1 re wired coil1 cleaned all grounds up 1 Quote Link to comment
tubbedbaggedstockfloored65 Posted February 9, 2014 Author Report Share Posted February 9, 2014 will take pictures in next few days with my new camera Quote Link to comment
Rushnracin Posted February 16, 2014 Report Share Posted February 16, 2014 Low Mfg. In Monrovia Ca. Did many of these conversions. I owned one with a3.8 v6 and th350. Did lots of mods finished if with 26 3/4 ground to lowest portion of the frame 37 inch monster tracs 4:27 gears Dana 30 and 44. Front springs were early willys and rear were Chevy 4x4 front springs. It had divorced trans case/3 drive shafts Quote Link to comment
Steroid Posted February 17, 2014 Report Share Posted February 17, 2014 Do You remember a truck called Lil' Stomper ? 1 Quote Link to comment
620Turbo4X4 Posted February 18, 2014 Report Share Posted February 18, 2014 Low Mfg. In Monrovia Ca. Did many of these conversions. I owned one with a3.8 v6 and th350. Did lots of mods finished if with 26 3/4 ground to lowest portion of the frame 37 inch monster tracs 4:27 gears Dana 30 and 44. Front springs were early willys and rear were Chevy 4x4 front springs. It had divorced trans case/3 drive shafts That's what I remember too... I my dad (RIP) was going to buy one of their kits back in the mid-80's. Never heard of "dealer preps" I picked my 4x4 620 up couple years ago and recently got another. They both have Dana 30 front and 20 transfer. But they way they were built (brackets, mounts, etc...) is completely different. Quote Link to comment
tubbedbaggedstockfloored65 Posted February 18, 2014 Author Report Share Posted February 18, 2014 please tell me how to raise my truck? if i make body mounts 3 inches or so for body lift what all else do i have to do and what do i do for a suspsnsion lift i ran into some money not much but would love to rasise my 4x4 please anyone with info tell me how Quote Link to comment
]2eDeYe Posted February 18, 2014 Report Share Posted February 18, 2014 How much lift are you looking for? If you do a body lift I would not recommend going over 2". The solid steering column will really become a hassle if you go bigger. You will need to address the fuel tank fill hoses and your brake lines and fuel lines will need to be looked at as well. There are a few options suspension wise, but it really depends on how much you want to spend. The quickest way to get some lift would be some longer shackles. With enough money you could link it up and go with coil overs and put the truck at whatever altitude you want. 1 Quote Link to comment
620Turbo4X4 Posted February 19, 2014 Report Share Posted February 19, 2014 I'm not much of a fan of body lifts myself. Re-arched or custom leafs and longer shocks would be the way to go so you have the lift and suspension travel. You'll most likely have to have your drive lines lengthened with longer slip joints and depending on the amount of lift and u/joint angles, may need double cardan joints too, which are not cheap. If you go with the longer shackles you may need some tapered shims that go between the axle and leafs to keep your pinion angles in check with the engine/trans. I'm going link and coil-overs on my truck... Quote Link to comment
tubbedbaggedstockfloored65 Posted February 19, 2014 Author Report Share Posted February 19, 2014 how much is link and coi over set up and wheere would i purchase these things and not i alone have the fab skills i dont know any 4x4 experts to help me Quote Link to comment
tubbedbaggedstockfloored65 Posted February 19, 2014 Author Report Share Posted February 19, 2014 well i would love to make my truck about 6 inches higher , how much do you guys think would it take to put coil overs and links in my truck, do you guys even know a site i can get them from or a vehicle see its just weird i am confused ? Quote Link to comment
tubbedbaggedstockfloored65 Posted February 19, 2014 Author Report Share Posted February 19, 2014 hey redeye with the green 4x4 i wasnt to put an sr20 in my 4x4 or a ka 24de but i dont know what tranny to use and which rear end to useand what drive line to use will it bolt to my rear end? what about transfer case how do i connect it to a ka24 or sr20? Quote Link to comment
620Turbo4X4 Posted February 19, 2014 Report Share Posted February 19, 2014 how much is link and coi over set up and wheere would i purchase these things and not i alone have the fab skills i dont know any 4x4 experts to help me Thousands... Not something you would want to attempt without good fab skills, full shop and lots of time... Why raise it so high? I would invest in some aggressive looking 32" tires and some nice wheels... I think it looks good the way it sits. 2 Quote Link to comment
]2eDeYe Posted February 19, 2014 Report Share Posted February 19, 2014 I'm not much of a fan of body lifts myself. Re-arched or custom leafs and longer shocks would be the way to go so you have the lift and suspension travel. I agree. If my truck didn't have the 2" already, it wouldn't have ever have one. That said, it will make it much easier to clock my tcase up for a flatter belly when the time comes. :) well i would love to make my truck about 6 inches higher , how much do you guys think would it take to put coil overs and links in my truck, do you guys even know a site i can get them from or a vehicle see its just weird i am confused ? Do you plan to wheel this? 6" is a lot, are there lift blocks on your truck? hey redeye with the green 4x4 i wasnt to put an sr20 in my 4x4 or a ka 24de but i dont know what tranny to use and which rear end to useand what drive line to use will it bolt to my rear end? what about transfer case how do i connect it to a ka24 or sr20? For a KA, you can use a 720 transmission from in front of a Z series motor. Everything else will stay the same. To do an SR would require modifying everything else to use the SR trans Quote Link to comment
620Turbo4X4 Posted February 20, 2014 Report Share Posted February 20, 2014 So he needs to source the KA from a truck to have the rear oil sump? Right? I've been out of the loop for quite some time with datsun/nissan engines myself. I assume that's what you mean by z series. I think all SR's are front sump too??? I was also looking into a engine swap for mine, but steering linkage will be a issue for me with anything front sump. Quote Link to comment
