jacktherippa215 Posted November 6, 2013 Report Share Posted November 6, 2013 stock rear suspension Quote Link to comment
kelowg Posted November 6, 2013 Report Share Posted November 6, 2013 Straight axle, so no camber to adjust. Or im i missing something. Quote Link to comment
flatcat19 Posted November 6, 2013 Report Share Posted November 6, 2013 Nope. Solid axle. Quote Link to comment
datzenmike Posted November 6, 2013 Report Share Posted November 6, 2013 Solid axle housing. No adjustment possible or needed. If trying to tuck those too big rims/tires you bought... that cake... don't bake. Quote Link to comment
ggzilla Posted November 6, 2013 Report Share Posted November 6, 2013 Live axle. No adjustment Quote Link to comment
DanielC Posted November 6, 2013 Report Share Posted November 6, 2013 If you need to adjust the camber on a stock 521, you have some other problems you need to deal with first. Quote Link to comment
thisismatt Posted November 6, 2013 Report Share Posted November 6, 2013 Two in one year? http://community.ratsun.net/topic/55891-camber-on-my-620/ Quote Link to comment
ggzilla Posted November 6, 2013 Report Share Posted November 6, 2013 The linked thread, talked about changing front camber. Which is desirable isn't it? Seems like 0 camber would be better than the stock negative camber. Quote Link to comment
datzenmike Posted November 6, 2013 Report Share Posted November 6, 2013 Truck ride height is easily adjusted and any adjustment changes camber and toe to some extent. Quote Link to comment
ggzilla Posted November 7, 2013 Report Share Posted November 7, 2013 Given that, how much will lowering blocks change the camber? Quote Link to comment
datsunaholic Posted November 7, 2013 Report Share Posted November 7, 2013 Since lowering blocks go in the back, the camber change (in the front) will be determined on the amount of weight bias change. Which is minisicule, if any. 1 Quote Link to comment
datzenmike Posted November 7, 2013 Report Share Posted November 7, 2013 Sorry I meant only the front is easy to adjust the height and the camber is always affected to some extent. . Quote Link to comment
