Supra510 Posted October 30, 2013 Report Share Posted October 30, 2013 I had composite leaf springs from Flex-a-Form, Kelvin's traction bars (which work great btw, eliminated wheel hop even with 400 + rwhp), and adjustable shocks, panhard bar, and leaf spring sliders in the rear. I broke a leaf spring mount which bent the u-bolt, which contacted the leaf. That started a stress crack in the spring. So....it was either get new composite leafs for 400+ and be stuck with that spring rate....or build a 3-link for less. Plus the panhard/leaf is not the best combo. 2 different roll centers can create bind....who needs that?? I'm building a 3 link for less...But this is made a lot easier since I have the panhard and mounts built already. The victim: Bent u-bolt. I don't have pix of the leaf spring crack. Will post later Some of the parts. Yes, there are 4 links...but I'm not building a 4 link. These are actually for an AE86, but are adjustable, pre-made, and the right length. I'll modify the 2 shorter ones to make the upper 3rd link. 250lb springs. I have coil over shocks not pictured. Link mounts that will be welded to the axle tubes. Purchased from Barnes 4WD. 1/4 inch thick... Tacked Welded Next step will be to make the front mounts. They will attach where the front leaf spring mount does now. I'll make the base plate and tabs from 1/4 inch thick steel. Could be slow progress, but with the girlfriend out of town on business and no more coaching for the season, I might actually have some time to make headway on this. 6 Quote Link to comment
metalmonkey47 Posted October 30, 2013 Report Share Posted October 30, 2013 Man this car is gonna be tough as nails when you're done man :fu: Right on. I always thought this was one of the coolest goons. Even though it's got a 2J Quote Link to comment
Supra510 Posted October 30, 2013 Author Report Share Posted October 30, 2013 Thanks, pretty excited to see how this works out. Quote Link to comment
]2eDeYe Posted October 30, 2013 Report Share Posted October 30, 2013 Nice part selection and welds :D Love your goon Quote Link to comment
Supra510 Posted November 2, 2013 Author Report Share Posted November 2, 2013 Mostly boring update, but an update nonetheless Broken spring Traction bar. Will be selling these as they aren't needed with the new set up. 1/4 inch plates that will be bolted in the front leaf spring mount area. Bracket to be welded to these. Plate bolted on to see if I drilled those holes correctly. I did. Next step is likely pulling the axle out and welding on the link mounts. Then I'll need to place the chassis at ride height, put the axle underneath, and figure out the location for the bracket I'm going to weld to these plates. 1 Quote Link to comment
]2eDeYe Posted November 2, 2013 Report Share Posted November 2, 2013 Nice of them to place that bolt pattern just so. :D Quote Link to comment
Farmer Joe Posted November 2, 2013 Report Share Posted November 2, 2013 what axle do you have this? Quote Link to comment
Supra510 Posted November 3, 2013 Author Report Share Posted November 3, 2013 Nice of them to place that bolt pattern just so. :D I know, right?? what axle do you have this? Ford 8.8 out of a Crown Victoria, early 90's. Came with disk brakes. Had it narrowed at Dutchman 1 Quote Link to comment
Ranman72 Posted November 3, 2013 Report Share Posted November 3, 2013 this is one of the baddest goons because of the 2jz saw this at canby and it looks insane Quote Link to comment
jesusno2 Posted November 3, 2013 Report Share Posted November 3, 2013 I did a 4 link on 510keepers wagon. The hardest part was trying to get shocks on the SOB. The geometry didnt quite work out under the stock floor pan. But he used bags so it didnt really matter. Just set it up best i could at a reasonable ride height. Quote Link to comment
Farmer Joe Posted November 3, 2013 Report Share Posted November 3, 2013 Ford 8.8 out of a Crown Victoria, early 90's. Came with disk brakes. Had it narrowed at Dutchman nice! Quote Link to comment
frisco510 Posted November 3, 2013 Report Share Posted November 3, 2013 nice cant wait for it to be done :thumbup: Quote Link to comment
Supra510 Posted November 4, 2013 Author Report Share Posted November 4, 2013 Rear end sitting on blocks with the leaf spring mounts attached. Enough grinders and extension cords in this pic? It's possible.... Scraps left of the leaf spring pads They were a bitch to cut off...to the tune of this many cut off wheels.... and a few more. Setting pinion angle. This will be controlled by the upper 3rd link ultimately, but for the baseline/tower position I set it as it was with the leaf springs. Welded up Close up Double adjustable coil over shocks. Recently had them rebuilt as one developed a leak, but all new hardward/innards now. Next step is to roll it under the body, set the body at ride height, and figure out the 3rd link mount and location I did a 4 link on 510keepers wagon. The hardest part was trying to get shocks on the SOB. The geometry didnt quite work out under the stock floor pan. But he used bags so it didnt really matter. Just set it up best i could at a reasonable ride height. Yeah, this is made a lot easier in that I have the rear floor cut out and braces welded in so it makes shock position etc. much easier to figure out and work on. 1 Quote Link to comment
ArchetypeDatsun Posted November 4, 2013 Report Share Posted November 4, 2013 Nice man, I saw your goon at canby In person for the first time always loved your goon! I hope to do something like this on my 810 goon as well. Quote Link to comment
Supra510 Posted November 4, 2013 Author Report Share Posted November 4, 2013 Nice man, I saw your goon at canby In person for the first time always loved your goon! I hope to do something like this on my 810 goon as well. this is one of the baddest goons because of the 2jz saw this at canby and it looks insane Thanks, appreciate it. Let me know if you have any questions on the install. Trying to document this pretty well. I think the biggest difference will be that I have the rear floor cut out which makes things a lot easier. Decided to make the axle 3rd link mount tonight so I'm not pulling the axle in and out from underneath the car. Few Pix Used a 2x2 as my base. I wanted to keep it pretty low, but not mount the tabs right off the axle tube. Welded to the axle tube. The weld does not butt up against the center pumpking on purpose. It's cast iron and the weld would crack...ask me how I know... Quote Link to comment
Just Joel Posted November 4, 2013 Report Share Posted November 4, 2013 Awesome build! Very impressive in person. Quote Link to comment
Eagle_Adam Posted November 4, 2013 Report Share Posted November 4, 2013 awesome sauce goon! Quote Link to comment
Draynor Posted November 12, 2013 Report Share Posted November 12, 2013 Badass! Can't wait to see more man :thumbup: Quote Link to comment
Supra510 Posted December 16, 2013 Author Report Share Posted December 16, 2013 So....slow progress but I'm getting there. Cardboard template for front link mount. http://community.ratsun.net/index.php? Said tabs. Making things from 1/4 inch plate in a pain. Welded to base plate Front mount bolted to the location the front leaf spring mount typically does... I'd love this ride height, but it likely won't work with the flares. I'll have to see if it's ok with the new spring rate. Link mounted to the axle. I will likely never use the lowest hole so I'll probably cut some of that tower off. It's ok with 18 inch wheels, but any thing else and I don't think it would. Also completed some work on the upper 3rd link and the mount...again more drilling and cutting of 1/4 plate. Takes forever. Will post pix upcoming 1 Quote Link to comment
Cpl620 Posted December 16, 2013 Report Share Posted December 16, 2013 seen your ride around the internet, glad i finally found it here. your whole build makes me want to punch an infant in the face. it has its own level of bad ass. Quote Link to comment
Supra510 Posted December 23, 2013 Author Report Share Posted December 23, 2013 Completed the front upper 3rd link mount. This will be welded to a support brace I welded in when I cut out my floor which is close to the back seat area. I likely won't need all the adjustability this provides....but it's nice have. Quote Link to comment
Draynor Posted December 23, 2013 Report Share Posted December 23, 2013 Digging it :thumbup: Quote Link to comment
Farmer Joe Posted December 26, 2013 Report Share Posted December 26, 2013 what keeps it from sliding under power? i get it should be tight, but will it stay? Quote Link to comment
Just Joel Posted December 26, 2013 Report Share Posted December 26, 2013 ^^^ I was wondering the same... Quote Link to comment
Supra510 Posted December 27, 2013 Author Report Share Posted December 27, 2013 what keeps it from sliding under power? i get it should be tight, but will it stay? Tighten the shit out of it? Lol. I see what you're saying, but I'd guess most of the force is going forward since it's controlling the pinion angle. I'll mark it and I guess worst case if it slips I'll dial it in and tack it in place. Quote Link to comment
