wallrockets 620 build
WallRocket
  • Replies 101
  • 4 weeks later...
Ok, I got some more work/research done on the sr20 to 620 wirring. =)
Please, dont mind the quick diagram i drew. It gets the point i see in my head out on paper to help others see how to wire it in. This has not been started yet of course.
Here is the two main plugs needed to convert wirring on a sr20det.
1. Brown Main Interface Plug.
This will hold your O2 sensor brown wire (Brown)
This will hold your black yellow IACV (Black/Yellow strip)
2. Grey Oval Interface Plug
This will hold your ecu power (Black/white strip)
This will hold your ecu back up power (Red)
This will hold your IGN power wires (2) (Blue/red strip, Black/red strip)
Parts Needed:
1 Fuse box/Panel  (Here is the one I used) (Search ebay for "14 Gang ATO Fuse Block")
http://www.ebay.com/itm/14-Gang-ATO-Fuse-Block-with-Ground-Bar-/180527940278?pt=Boat_Parts_Accessories_Gear&hash=item2a084dc2b6&vxp=mtr
Fuses
5 basic Relays
Wire of your choice. (Remember never put smaller wire on big wire)
Helpful Thread. (Use pretty much all the same steps for extending the harness. MAF, and O2 Sensor)
http://www.frsport.com/SR20DET-Swap-Engine-Harness-Wiring-Diagram-Guide-SR-SR20_t_26.html
  • 3 weeks later...
Only thing left is getting some small parts, and hoses. Then I will do my first test start!
Parts List.
S13 trottle cable
S13 sr20det redtop starter
Relays
Switches
Coolant
S13 Sr20det MAF
S13 sr20det o2 sensor
Center console to hold ecu, and switch panel
Bucket seat.
BOV pipe
Small list now! I am excited.
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
I ordered my brass nuts from fr sports. Still waiting for my oem nut lock plates.
Its very important to assemble the turbo so it does not come loose. Its s common pain in the ass problem to have the turbo fall off the manifold. Here is a picture of how much was cut off the oem turbo housing.
Anyways, i removed the steering box, and steering shaft. It gives you enough room to install the manifold/turbo/ all as one assembly.
I figured it out!
I just started it just now. Had to re time it, and triple check wirring. I didnt take no as a answer!
Pretty awesome feeling. Hearing a engine you built start for the first time!
Here is a small updates of the build.
Wired in lights to all work with oem switches.
Custom front chassis harness. All done correct.
Garmet engine wire harness hole. Wired complete engine harness. Loomed as well.
Complete engine bay finished (ish)
It was a full day of work.
I started it at night, so i will make a start up video tomarrow in the daytime.
Whats left?
Fuse panel
Seats (brides)
Weld up trans tunnel
Gear oil
Find leak in trans
Make sure drive shaft works
Coolant temp sensor
Thermostat
Coolant
Maf pigtail
floor pan rust repair
Greddy blow off valve
Air filter
