4perrev Posted May 21, 2013 Report Share Posted May 21, 2013 Hope your day is full of good wrenching, driving or whatever else your doing to the little monsters!! :thumbup: 1 Quote Link to comment
uberkevin Posted May 21, 2013 Report Share Posted May 21, 2013 Should be dropping the L18 in today. And I have the day off... its alllllll 521 MasterChief today. :) Quote Link to comment
Tucson620 Posted May 21, 2013 Report Share Posted May 21, 2013 Dang! Didn't realize. Left the 521 in the driveway this morning. Maybe I'll take him on a hauling trip tonight. Quote Link to comment
erichwaslike Posted May 21, 2013 Report Share Posted May 21, 2013 i will be welding up a 521 bed and gettign it ready for flares. also driving my 521 everywhere, as i do everyday lol Quote Link to comment
piraterumm Posted May 22, 2013 Report Share Posted May 22, 2013 took mine to an empty parking lot for a little drifting in the rain. :) Quote Link to comment
oldskoolvws Posted May 22, 2013 Report Share Posted May 22, 2013 I stare at mine in the garage....including today. Quote Link to comment
datzenmike Posted May 22, 2013 Report Share Posted May 22, 2013 As a former owner of a 6 year old '71 521... happy 5/21. Quote Link to comment
mrbigtanker Posted May 22, 2013 Report Share Posted May 22, 2013 I stare at 2 of them drive one spend money on the other.lol Quote Link to comment
datzenmike Posted May 22, 2013 Report Share Posted May 22, 2013 I had mine from '78 through '86. Rebuilt the L16 with new rings and valve seals. The rod bearings were real bad but couldn't afford new, so took the ones out of my retired field car (510) they weren't as bad and used them. Eventually I replaced the tired L16 with an L20B that was luckily, for me, from a car so it had the 200mm clutch release bearing collar that I knew nothing about anyway. The heaters are crap for Ontario winters so I threw out the glove box and installed an air conditioner heat exchanger in the opening. (about 5 x bigger than the stock one) I found it in the dump and used a blower fan from a '57 (something) It had 4 225/75R14 truck tires, fiberglass front fenders, a '55 Chev gas tank in the box, tied down with bungee cords. Halogen lamps two pair of hi beams so 6 in all. Pretty skookum for the late '70s. Alternator mounted on the driver's side because the bolts sheared off in the block. 510 buckets. Tranny froze in 4th found another for $20. Replaced the king pins twice and finally said fuck it and left them. Changed the oil and filter on a Sunday, drove to work Monday and the oil light came on in the parking lot. Filter blew open, split all around the base. Complained to Canadian Tier they gave me new oil and filter. Drove home, oil light on filter blown... wtf. Took oil pump out and the pressure relief was jammed with a small bit of aluminum casting. Scratched it off, complained to Can Tire got new oil and filter for free... problem solved. Driving around one night coasting down hill, step on gas and motor revs up and no go. Flywheel bolts all sheared off. The L20B sat in a snow drift all winter before I installed it. The crank bolt holes got rusty, bolts torqued up tight but weren't snug against the flywheel. Removed motor, drilled out bolts with Black and Decker, bought a tap and 6 oversize grade 8 bolts, holes not very straight but it held. Head gasket blew twice before I thought about it being warped. Ran a 210 head from the 510 while fixing it. Nissan dealer said it wouldn't fit. I drove it down there and the parts dept manager called the mechanics out to see it running. I lultzed. She was my best friend through some bad times in my life. Great time now. So happy 5/21 everybody who loves them!!!! Quote Link to comment
wayno Posted May 22, 2013 Report Share Posted May 22, 2013 Everyday is a 521 day for me, and I always make it home when I leave, well except for the dogleg blowing up that one day, i time out of thousands isn't bad. Happy 5/21 day everyone, and I don't care if you don't have one, have a great day anyway. :rolleyes: Quote Link to comment
4perrev Posted May 22, 2013 Author Report Share Posted May 22, 2013 Damn Datzenmike that was a great story. That's the kind of stuff that makes this all so good. Since I bought my truck, I have had nothing but good time wrenching, scrapping parts and meeting people along the way. This is much better than the sportbike scene! Quote Link to comment
Willdatsun Posted May 23, 2013 Report Share Posted May 23, 2013 I have been doing kingpins. Urgh. Well, one at least. Other side tomorrow hopefully. the RH side pin was really stuck in the dogbone thing. Had to take it somewhere to use their 30 ton press! Quote Link to comment
oldskoolvws Posted May 23, 2013 Report Share Posted May 23, 2013 Quite the nice reamer wrench. Ratsun style. Quote Link to comment
mrbigtanker Posted May 23, 2013 Report Share Posted May 23, 2013 Did you say ream me. Quote Link to comment
oldskoolvws Posted May 23, 2013 Report Share Posted May 23, 2013 You kind frisky today huh big man? Go Hamburga Mary's LOL. Quote Link to comment
mrbigtanker Posted May 23, 2013 Report Share Posted May 23, 2013 Cuz I mahu.ahhh Quote Link to comment
Willdatsun Posted May 23, 2013 Report Share Posted May 23, 2013 Reaming some new bush with my tool! What better way to pass the afternoon. Quote Link to comment
4perrev Posted May 24, 2013 Author Report Share Posted May 24, 2013 Started this as a 521 appreciation. Didn't know it was going to go dirty on us!! You guys need to get a room.......Motel 6 perhaps. The do let the lights of for you! Quote Link to comment
