Round 2, FIGHT! - now with a DE in progress(for real this time...)
Eagle_Adam
Me too!!! :D
Drove her to work this morning for the first time, man i gotta say FUCK PUBLIC TRANSIT!!!! way prefer my datto!!!!!!!!!!!!
BUT, i have a rattle that i think is the exhaust that wasn't present till i lowered it so she might have to go back top my exhaust guy for some tweeking.
  • Replies 2k
Left to do before canby:
mount the rad
wire the engine bay
install the new coil
finish the interior install
Amber high beams
heater core, hoses, firewall grommets, and hearted core valve installed
intake and exhaust mani studs
white face gauges and LED's
install stereo head unit
install the new motor mounts
carb, intake mani and exhaust mani install
put in the new grill and bumper
put the steering wheel and clam shell back on so i can move it outta the garage
check the breaks
delete unneeded wires from the engine bay and under the dash
verify the front hubs have been turned
fill the trans
hook up the trans wires
time the motor
install speakers
drop it off at the exhaust shop
mount the titans
install the DZ start < half done
pick up the new camper shell i picked up from Siqx20 and get it on ( gotta have a safe place to escape the tasers from what ive been told)
put in the black seat belts i have
install the package tray
drop it off at my carb guy for a tune and to get the valves set hot
test drive and make a new list :P
Better?
mount the rad
wire the engine bay
Amber high beams
check the breaks
fill the trans
time the motor
install speakers
mount the titans
then install my valve cover
* Got the high idle issue figured out, ended up being a spacing issue causing a binding problem
* didn't mess with the valves and got lucky they are good
* had the motor timed wrong aperantly.... So that got fixed.
* found the oil leak, helps when the timing inspection plate is actually bolted down...
* did a quick oil change even put on a new brass oil drain plug gasket
* and finally got the powder coated valve cover on!!!!!!!!!!!!!!!!!'
D085FB4F-F3CF-49D3-B1EC-F0CA35F9FEFD-642
B896F7EE-70BA-4870-95F3-AF83FF05AEC6-642
make it as low as reds truck..........those wheels on stock height look like 22's ......i do like the green on the blue though....shoulda kept that other extra cab that was wrecked and built a silver and black one ...fer the nfl battles in the parking lot........u gonna be around this holiday weekend thinking about making a parts run ... dtp has patiently been waiting for me to come down...lets do some more under hood stuff that green .... and your tailgate chains and tie down points...
Dude,,,,, Seahawks haven`t been in the AFC for more than ten years.
Eagle_Man  the truck is coming along very nicely,, it is weird how when you need to finish a vehicle just get to Canby as opposed to just get there in the car you have been driving ,,  your want to get there is magnified 100%..
Dig it! :D
ME TOO!!!!!
No, no mas lower. i like the way it rides and for a DD its perfect......... well maybe a little lower but not till after canby :P
As for more green... ya needs lots more green..... everywhere
Left to do before Canby:
mount the rad
wire the engine bay
Amber high beams
check the breaks
fill the trans
time the motor
install speakers
mount the titans
figure out the high idle
find the oil leak
install pass side seatbelts
tune the carb better
no... i got out to tell him he was an asshole and that i was taking his plate number and reporting him
once out of the truck his middle finger aided in the decision to grab jessi's manifold and make sure i could ID his car later ;)
(no manifolds were hurt during the improvement of the hondurp)
carb still needs adjusted quite a bit but the choke is functioning properly now, the oil leak is gone and im very happy with it as of now!!!
Time to put this one on hold for a bit until jessi's goon is running again
