4perrev Posted March 4, 2013 Author Report Share Posted March 4, 2013 Holy crap, there is sun in Washington. Well, I took the opportunity to do a little work. Thought I would tackle the bed. Surprisingly enough, all 8 bolts came right out with no swearing or knuckle busting. Can't believe it! Here is the before and some work after it was off. Getting her ready for a nice POR 15 juicing. Here is the frame and axle stuff. Not too bad, just light surface rust that will come right off. And as an added bonus, here is the new painted dash. She shines up nice! Now, I just need more time and sunlight. Both of which I have too little of! 1 Quote Link to comment
Kirden Posted March 4, 2013 Report Share Posted March 4, 2013 Thanks, I'll print off a few of those tonight. Gives me something fun to do at work :P That resto work on the headlight bezels and heater looks great. Seeing the amount of detail work you are doing makes me want to try harder on my truck. Keep up the great work and make that head turner beautiful. 1 Quote Link to comment
Rocket Dog Posted March 5, 2013 Report Share Posted March 5, 2013 How did you get your heater parts so sparkly and new looking? 1 Quote Link to comment
4perrev Posted March 6, 2013 Author Report Share Posted March 6, 2013 How did you get your heater parts so sparkly and new looking? I just sanded the crap out of them. Every nook and cranny (which is a lot). I don't have a sand blaster, so sandpaper works good, but it takes longer to complete. Wiped it off with thinner, primered, painted and then cleared it with a matte finish. The paint I used so far was Rustolium, but I would use actual car paint if you can get it. I'm trying to go thin on money to see how far I can get. I think I'm going to switch to Duplicolor paint because it is more durable. I used it on some YSR 50 rims and that stuff is stuck on there good. The outside of the truck will be painted in actual "real car paint" so it will stay beautiful. I tried to pull the hinge pins out of the flapper doors, but they were in for good, so I figured out how to spray all the insides as best I could. Actually, got every crease painted on the inside. Was amazed! 1 Quote Link to comment
gene knight Posted March 6, 2013 Report Share Posted March 6, 2013 nice build thread keep it up and for future info u might want to do it under project datto for your build/resto thread 1 Quote Link to comment
4perrev Posted March 18, 2013 Author Report Share Posted March 18, 2013 (edited) Another sunny day (for about 4 hours atleast). Well, decided to get in the gas tank. Here is the outside and all it's wonderful rust! Have you ever seen your fuel level gizmo and float? I'll show you mine if you haven't seen yours! It was a chore getting the top securing ring off. But, with a little WD-40 and some love from the hammer and brass push bar, it came off. Here it is: Everything works as advertised. Checked it with a multi-meter and after 40 years, she's kickin' fine. Sealed her back up and installed the securing ring. Tank is all cleaned and primered. Will post pics of the final painted tank when the sun comes back out!! 😕 Edited June 23, 2019 by 4perrev 2 Quote Link to comment
4perrev Posted March 27, 2013 Author Report Share Posted March 27, 2013 So, I blasted the tank clean. Looks good, but I blasted the rust so well, I found two holes in the tank. Not good, but I had a friend weld up the two holes and we did a leak check. All turned out good. Got worried about the tank after I read the thread about a gas tank fire, so I just wanted to be sure. Better safe than sorry. Pictures to follow when I can get some paint on it! 2 Quote Link to comment
konig209 Posted March 27, 2013 Report Share Posted March 27, 2013 Everytime i get my truck on a car lift like every other week there is a small line of what looks to be gas comming out of somewhere up top. I needa get off my ass and check before i myself have a fire o_O 2 Quote Link to comment
4perrev Posted March 27, 2013 Author Report Share Posted March 27, 2013 once I pulled the tank, the pickup line from the fuel tank came loose. All the fittings on the tank are soldered on after the tank seams are welded. Over the years, the solder gets weak or you may just have a pin hole leak from the tank. The two holes a had were pinholes that we caught by pressurizing the tank and spraying soapy water on it. 2 Quote Link to comment
konig209 Posted March 27, 2013 Report Share Posted March 27, 2013 Thanks for the tip i have an extra gas tank sitting outside maybe even two idk yet. I guess ill clean one up and fix it. 1 Quote Link to comment
4perrev Posted March 27, 2013 Author Report Share Posted March 27, 2013 My next step is to pour a bunch of sand in the tank and spin it around for a while to knock the rust off the inside. Getting the sand out my be a bit troublesome, but I figure I can wash it all out, dry it good and then seal it. Should work?! 1 Quote Link to comment
Rocket Dog Posted March 27, 2013 Report Share Posted March 27, 2013 That color blue was the same as my first car back in high school, a 71 521. You might use a citrus based cleaner for the gas tank vice using sand. Ask DanielC on that one. 1 Quote Link to comment
4perrev Posted March 27, 2013 Author Report Share Posted March 27, 2013 The blue is nice, but there are so many of them that I'm going with Sunkist orange, if possible. Thanks for the citrus tip. I'll look DanielC up. 1 Quote Link to comment
4perrev Posted March 31, 2013 Author Report Share Posted March 31, 2013 (edited) Finally finished painting the gas tank today: Was going to start doing the frame and axle with undercoating, but when I went to the store to get some Chassis Saver, it was $40. a quart. Holysh!t. I decided to go on line and find it cheaper. So, I ended up on Stock Wise Auto. Just bought a gallon for $99.03 with shipping and a promo code from Google. Should be here in a week, but that's ok cause I just saved 68 bucks!! Edited June 23, 2019 by 4perrev 2 Quote Link to comment
4perrev Posted April 1, 2013 Author Report Share Posted April 1, 2013 Happy Easter to all. Had some good times today and pulled the engine. Used a couple 4x4's and made an engine trellis to hang a come-along to. Not too bad as the engine wasn't that heavy, but still pretty easy pullin' her out. Engine was completely full of gunk and old pine needles? Clutch needs a little de-rusting, but it wasn't too corroded. Cleaned it up for the most part. Made an engine stand with casters to get it around the garage for now. More pics tomorrow. 1 Quote Link to comment
4perrev Posted April 7, 2013 Author Report Share Posted April 7, 2013 (edited) Well, now that the engines out, I had a chance to finally get to that ugly heater core box. That thing was nasty. Took the fan motor apart and cleaned it. Crazy little brush type fan motor. Gave a picture below. Here's the motor: And the finished box with paint and the fan: Side shot! Edited June 23, 2019 by 4perrev 2 Quote Link to comment
wayno Posted April 7, 2013 Report Share Posted April 7, 2013 Yea that little motor is strange, works like a record player, sure does make a lot of noise when it goes bad though. 1 Quote Link to comment
4perrev Posted April 22, 2013 Author Report Share Posted April 22, 2013 (edited) Decided to work on the engine bay today. Here is a couple pictures for the start: The bumper was really rusted behind, but the chrome on the front looks decent, so I painted the back. Never going to see it and had to stop the rust! Edited June 23, 2019 by 4perrev 1 Quote Link to comment
4perrev Posted April 28, 2013 Author Report Share Posted April 28, 2013 Can I move this to the DATTO folder? Does anybody know how to do that? 1 Quote Link to comment
4perrev Posted May 7, 2013 Author Report Share Posted May 7, 2013 Split the cab and the frame this weekend. Again, amazingly enough, all the cab bolts came out without a big hassle. Although rusty inside the spacers, they weren't too bad, but will replace them when the cab goes back on. Made a nice stand for the cab with loads of room underneath to fix my cancer hole in the passangers floor board. Here's the frame: And the frame number: Have coated the frame with Chassis Saver and will post more pics once the coating is completed! 1 Quote Link to comment
4perrev Posted May 15, 2013 Author Report Share Posted May 15, 2013 So I went through the steering box and I have a crushed bearing. I listed a wanted ad on the classified, but any help would to find one would be greatly appreciated. 1 Quote Link to comment
mrbigtanker Posted May 15, 2013 Report Share Posted May 15, 2013 wow are you going to paint it. 1 Quote Link to comment
4perrev Posted May 15, 2013 Author Report Share Posted May 15, 2013 Yeah. Is that bad? Paint the frame or the whole truck? I'll tell you, that chassis paint is some heavy stuff, so kids, use a respirator! 2 Quote Link to comment
4perrev Posted May 18, 2013 Author Report Share Posted May 18, 2013 So let me first start with the fact that I've never welded before. My friend lent me his Lincoln, so I just jumped in feet first. The guy who owned the truck before I got it drilled giant screws in the kick panels for speakers and there were big holes that I didn't want to deal with water coming through when it's raining. Here is the first try with lap welding. Pre weld: Post Weld: I didn't want to sand it down completely just incase I didn't get it all perfect. But it's the fender well, right? Critiques please! 1 Quote Link to comment
4perrev Posted May 19, 2013 Author Report Share Posted May 19, 2013 (edited) Went and did a little scouting today to find some new parts. Found a new heart for the truck. Thought I'd swap out the old fuse box with something more up to date and water proof under the hood. Kept it in the Datsun/Nissan family. Here's a couple of the goodies: Edited June 23, 2019 by 4perrev 1 Quote Link to comment
