Guest Jamee Posted December 21, 2012 Report Share Posted December 21, 2012 Help my radiator in my 77 b210 died and Id like to replace it with something that cools better. Does anyone have any success stories fitting other radiators from different cars in there. Redbanner mentioned vw's having somewhat compatible radiators, but does anyone have other ideas so that when I go looking I'll have a wider range of options? haaallllp please! thanks everyone. :blush: Quote Link to comment
ggzilla Posted December 21, 2012 Report Share Posted December 21, 2012 Mine died too and i got a replacement which didn't work as well! So I put copper seal in the old one and it is now 100% perfect. Cools well and no longer leaks. That's my recommendation for a leaking radiator. And that is with the smallest stock radiator. For a $50 new aluminum (which I don't recommend) you can use a Jetta radiator. But they only have 20psi caps so it stresses out the old B210 heater core and hoses. I would instead get a B210 or B310 radiator which fit in but are bigger. Or get the same size one if it worked good in your weather before it died. Everything you need to know about B210 radiator swaps is at Datsun1200.com: http://datsun1200.com/modules/mediawiki/index.php?title=Radiator#Upgrades Be sure to check out the swap pics of the VW radiator to see what is involved. Quote Link to comment
Guest Jamee Posted December 21, 2012 Report Share Posted December 21, 2012 cool thanks for sharing info Quote Link to comment
bonvo Posted December 21, 2012 Report Share Posted December 21, 2012 banner hit the nail on the head with the vw radiator they fit well as long as you dont mind making brackets my motor ran cooler with it ive heard about a focus radiator working as well as a feiro but ive never tried either of these Quote Link to comment
Bentaxlebob Posted December 21, 2012 Report Share Posted December 21, 2012 Since B210s in other countries were available with L series motors, ( hence engine bay is made to accept an L series engine and its accesories.) try a Datsun 610 or 710 radiator. Those have same pressure characteristics to the B210's but those ( 610/710 ) have more capacity and better flow due to better capacity. Quote Link to comment
pwee4u2c Posted December 24, 2012 Report Share Posted December 24, 2012 I had mine re-cored, it was originally a 2 core I had it upgraded to a 3 core...haven't had an issue since, only downside is it ran me about $240.00 usd. Quote Link to comment
Guest Jamee Posted December 27, 2012 Report Share Posted December 27, 2012 :) thanks everyone Quote Link to comment
Nicholas7620 Posted December 28, 2012 Report Share Posted December 28, 2012 Hey Jamee, I acquired a new radiator at Rockauto.com for my B210 for around $110. I just checked they are going for $90 before discount. http://www.rockauto.com/catalog/raframecatalog.php Get a 5% Discount code from Ratsun Rock Auto thread. The radiator works great, I been using my radiator for over two years without any problems. Quote Link to comment
ggzilla Posted December 28, 2012 Report Share Posted December 28, 2012 And how much is shipping? A used radiator is $40 from Pick-n-Pull nationwide. Quote Link to comment
Guest Jamee Posted December 30, 2012 Report Share Posted December 30, 2012 Well at the moment i am completely F***ked. I have no monies for about a week and my car is my daily runner, If anyone out there in ratsun land near me could loan me a spare radiator until I get a pick n pull one next week that would be beyond epic. or hell i got $10... this really facking sucks :poop: . :crying: Quote Link to comment
datzenmike Posted December 30, 2012 Report Share Posted December 30, 2012 Help my radiator in my 77 b210 died Define died. Sometimes you can limp by for weeks and months buy just leaving the cap loose so pressure doesn't push the water out and just keep topping it off. Depends where and how large the leak is. Make sure it isn't a leaking hose. Quote Link to comment
Guest Jamee Posted December 30, 2012 Report Share Posted December 30, 2012 Died: the fins have exstensive damage, the top tank has a large crack and the top tank "seal" leaks as well. I apparently have been limping it for a while lol, Didnt realize how bad it was until it had sprayed anti freeze all over my engine, my mechanic(my man) says he has no idea how i've been able to run it for this long. It's only such a huge issue because like i said its my daily runner. We have the mod thing figured out (thank you everyone for that) we just have to wait until payday. Quote Link to comment
ggzilla Posted December 31, 2012 Report Share Posted December 31, 2012 Run it with the cap on, but not tightened. It'll go until summertime. The cap pressurizes the system to about 14 psi to raise the boiling point. You won't need that until summer. Quote Link to comment
Guest Jamee Posted December 31, 2012 Report Share Posted December 31, 2012 you peeps are blowing my mind here. lol. wont it boil out my water if the cap isnt tight? ya know because its a little engine gets hot blah blah? hmm no,its rather chilly right now so it would only get hot hot if I made a trip to vancouver and back.....sorry, thinking out loud. man o man I love you peoples :thumbup: Quote Link to comment
ggzilla Posted December 31, 2012 Report Share Posted December 31, 2012 No, the engine only gets to 180 degrees or so if you have a 180 degree thermostat. It will only boil water when it gets to 212 degrees or more. Without the cap being tight some will evaporate out so you'll want to watch it and top it up periodically. Quote Link to comment
Bentaxlebob Posted December 31, 2012 Report Share Posted December 31, 2012 Do not risk blowing your head gasket and messing your pushrods. If you can not buy a radiator yet, park your car. You are going to spend a lot more $$$ if you use your car like that. Quote Link to comment
bonvo Posted December 31, 2012 Report Share Posted December 31, 2012 Since B210s in other countries were available with L series motors, ( hence engine bay is made to accept an L series engine and its accesories.) try a Datsun 610 or 710 radiator. Those have same pressure characteristics to the B210's but those ( 610/710 ) have more capacity and better flow due to better capacity. problem with this idea is the fact that a 610/710 radiator is just as hard to find and if you do it could be just as bad as what your pulling out Quote Link to comment
Dguy210 Posted December 31, 2012 Report Share Posted December 31, 2012 Died: the fins have exstensive damage, the top tank has a large crack and the top tank "seal" leaks as well. I apparently have been limping it for a while lol, Didnt realize how bad it was until it had sprayed anti freeze all over my engine, my mechanic(my man) says he has no idea how i've been able to run it for this long. It's only such a huge issue because like i said its my daily runner. We have the mod thing figured out (thank you everyone for that) we just have to wait until payday. You can also do some redneck type patching to help things along. A little bit of RTV silicone smeared on the leaky fins and let dry overnight will help. For the top tank the leaks and the crack can be helped with some Epoxy putty. Clean the area with a brush for both the fins and tank and apply the silicone/epoxy and let sit overnight. Run it with the cap on, but not tightened. It'll go until summertime. The cap pressurizes the system to about 14 psi to raise the boiling point. You won't need that until summer. ^this. It's winter you can push this if absolutely necessary for a while. Do not risk blowing your head gasket and messing your pushrods. If you can not buy a radiator yet, park your car. You are going to spend a lot more $$$ if you use your car like that. Just keep an eye on the temp gauge and you should be fine. Keep some water/antifreeze in the trunk and pullover if it starts to overheat. Check the fluid level on a regular basis. I've patched and run crappy rads way longer than I should have when I was really desperate and had to drive the car. You'd be surprised how well you can patch some of the leaks temporarily. Quote Link to comment
Guest Jamee Posted December 31, 2012 Report Share Posted December 31, 2012 I've decided to just leave it parked, I only have to wait about 5 more days. :unsure: I think I can be patient enough for that long...ha! Thank you everyone, seriously. :thumbup: Quote Link to comment
ggzilla Posted January 1, 2013 Report Share Posted January 1, 2013 What happens in 5 days? Stop-leak will fix leaking seams and slightly damaged fins. But it won't fix cracks that are not along seam lines. Stop-leak is good when used according to directions, all the cars use it straight from the factory. Quote Link to comment
datsunfreak Posted January 1, 2013 Report Share Posted January 1, 2013 What happens in 5 days? He gets paid. ;) Quote Link to comment
CWhip Posted January 1, 2013 Report Share Posted January 1, 2013 Where in washington are you? I've got an extra rad out of a 80-81 210 just sitting in my shed. Don't know if it will work in a b210 tho. Pm me if you're interested. Quote Link to comment
Guest Jamee Posted February 2, 2013 Report Share Posted February 2, 2013 well, shit fell through and my car is still sitting in the driveway. Sometimes its seriously stressful owning a B210. :crying: *insert string of profanities here __________________* Quote Link to comment
B210GX Posted February 2, 2013 Report Share Posted February 2, 2013 As asked before where are you located? I may be able to help Mike Quote Link to comment
RedBanner Posted February 2, 2013 Report Share Posted February 2, 2013 near the pdx area, Quote Link to comment
