Help removing 40 year old balljoints.
mantas
I don't know where to fucking begin. I've removed balljoints millions of times. I've learned to use a puller, and i can work a hammer quite well and get them out that way - which is really a big waste of time. Either way, i tried to remove the centerlink and the balljoints. After hours of playing around with them, i ended up cutting a few off. Now i'm stuck on the drivers side arm connecting to the steering shaft, how is that supposed to come out?
Tried the following - 2 arm, 3arm pullers, fork, hammers of every size, breaker bar. I would post pix but all of a sudden i can't use Flickr links on this forum......
  • Replies 48
With mine I used a powerful air chisel with a pickle fork attachment to break my ball joints free. A 5lb hammer.and torch did nothing.Also saturating them several times with PB blaster would help.
Yeah i tried hammer and pb blaster. I think i've wasted a whole can of pb blaster on it, i actually let some of it sit for a day and nothing...have no air tools at the moment. But i'll try a torch. Ive read that its supposed  to get rid of any dirt in the cracks that might prevent it from moving - sounds like a load of you know what but worth a try.
Funny, i have never been able to get any joint loose hitting it there. Though many guys swear by that method.
With a large sledge with pickle ive taken off hundreds of ford, gm, chrysler, toyota, datsun, etc. never fail
I have pickle forks that gather dust, this method allows removal of the joint without damaging the dust boot. It's simple metal deformation physics :)
I figure, I never remove them unless I need to replace them.  Because by the time I've gotten some of them off, I HAVE to replace them.
I suppose a situation could someday arise where I would need to remove a functional one for some reason, and hope to reuse it... haven't had that happen yet.
So you never drive metal nails with a metal hammer, or is there more too it? Bodymen use metal hammers on metal panels. Professional mechanics use metal hammer to hit metal drifts.
The weight of the hammer is what makes the ball joint easy to get apart. Why guys say Big hammer or 12-pound hammer. What does the hickory mallet weigh?
