Rear end suggestions needed....70' 521
What?It runs...
Alright, so I've begun some work on a 1970 pickup I had in high school. I have recently picked up a nicely built L20 and would like to change out the rear end and perhaps the brakes. Which rear end should I use that may also provide some independant suspension? I'm relatively new to the world of japanese cars and will welcome any suggestions. Thanks for your time...
  • Replies 17
Welcome !
Any IRS will work ...
People who know..... just do ;)
If you don't have an un-disturbed workplace to set the truck from start to finish ... It's going to be more difficult than it already is.
I can see a cool $850-$1,000 being dropped right off the bat if you want NEW performance coilovers in general with IRS. Thinking specifcally Qa-1 coilovers. Than again other coilover setups could be cheaper !
Add more money for exhaust re-routing and more un-expected costs.
Add more for driveline shortening or custom driveline.
THEN... You choose whether to shorten cv joints and making custom a-arms ... More money.
Bushings ...
Metal needed ...
To re-drill or to not re-drill ?
E-brake ...
Brake re-routing...
Etc
Etc
Or
You'll be swapping out lug patterns to ... 2 spare tires.
Hopefully you won't end up disc rear and drum front.
Infiniti Q45
350z or G35 ?
240sx IRS
30Ozx IRS
510 IRS
280zx IRS
Lincoln mark viii IRS
Ford Mustang Cobra IRS
Cougar xr7 IRS
Thunderbird 5.0 IRS
Etc ?
^ track width issues on many of those.
Just as many don't have LSD.
Which is a big re-sale issue.
etc.
Soon youll have more into the rear suspension than the whole truck including the engine.
Unless you're a sly guy with money and parts slinging.
Not to mention down time or cost versus fun ratio and possible a heavier setup than the original ...
You could also Keep it the way it is and enjoy :)
Or
Choose the rear end setup that you'll still enjoy 10 years down the road if you do !
I'll have $2,200 in an 8.8 straight axle conversionr into my 240z
That's counting everything I can think of needing ..
Feels almost impossible everytime I type that figure but its true.
And it's my reference :lol:
You have to be super accurate in wheel base measurements via plumb bobs , jigs , angles and measurements.
Not to mention lots of free time and even more patience period.
Sure you can do it cheaper than my figures.
But do you really want a top notch system operating with cheap or half worn parts ?
Some of those parts work and even a larger percentage won't work as well.
Not attempting to discourage.
I do hope you're a bit more prepared for the journey though.
Good luck
Dtp
Welcome to Ratsun B)
Leave the damn thing alone. Put some good shocks on it, maybe lower is a couple of inches. Some nice rubber. Stiffer springs maybe a larger sway bar to tune the over/under steer. Enjoy driving it. You don't want IRS! What for? it's a truck not a 510. It's heavy and has a frame. It will always handle like a truck but you can improve on it. .
Thanks for ALL the feedback! @thisismatt, clearly IRS is a full time thing. I'm not new to the car world. but thank you. I am sort of new to datsuns and am really excited to get my pickup back on the road. I do have a full machine/fab shop at my fingertips so the work isn't the issue. However, being relatively new to Datsuns, I didn't know if there was a particularly common rear end swap.
@DTP, thanks for all the info. I may leave it alone for now just to get it on the road and to a couple of events. I look forward to meeting some of you and seeing what you've got...
