a.d._510_n_ok Posted October 18, 2012 Report Share Posted October 18, 2012 my Dat has always ran cold in the winter so I just assumed it was lacking a thermostat. when I pulled the thermostat housing I found this thing inside: I'd never seen one with the copper element and spring off-center. the little brass piece at the top is a wedge that slides back and forth....guessing it's a fail-safe thing? I the brand is motorad but I noticed that the unit never completely closed, even when cold as ice. I replaced it with a standard 180' motorad and am tickled with the engine's new found consistent heating! Quote Link to comment
ggzilla Posted October 18, 2012 Report Share Posted October 18, 2012 The little brass thing is called a jiggle-valve and Datsun started using them in the late 1970s. It's good. The spring needs to face into the engine. If it was put in backwards it won't work properly. Quote Link to comment
MikeRL411 Posted October 18, 2012 Report Share Posted October 18, 2012 Looks like the tilting element valve used in 1970 Buicks. Fairly fail safe, although GM used a hefty bypass hose on the housing. Might be a "oops" substitute? Quote Link to comment
Laecaon Posted October 18, 2012 Report Share Posted October 18, 2012 If you dont have the jiggle valve, and you have heating issues, you might consider drilling a 1/8th hole. I know Hainz will do this. Its a good thing though. Quote Link to comment
a.d._510_n_ok Posted October 18, 2012 Author Report Share Posted October 18, 2012 The little brass thing is called a jiggle-valve and Datsun started using them in the late 1970s. It's good. The spring needs to face into the engine. If it was put in backwards it won't work properly. naw, it was installed the correct way but it was stuck partially open.....hmmm.....will replacing it with a regular 'stat make any difference? Quote Link to comment
ggzilla Posted October 18, 2012 Report Share Posted October 18, 2012 Yes, of course it will make a difference. Most important it won't be stuck. The jiggle-valve is a small thing, you won't notice the difference if you bleed the air properly. Quote Link to comment
metalmonkey47 Posted October 18, 2012 Report Share Posted October 18, 2012 Go get one from NISSAN. Best 'stat I've ever owned. Quote Link to comment
CharlieW Posted October 22, 2012 Report Share Posted October 22, 2012 The valve is always supposed to be positioned at the 12oclock position. This is so that the system can 'burp'....or vent air out. On my z24 they're is a mark on the thermostat housing for the valve to line up with. Quote Link to comment
72240z Posted October 22, 2012 Report Share Posted October 22, 2012 You could consider changing the temp thermostat you use if you want to run hotter/colder. Though if its stuck open thats def why it was always cold. Quote Link to comment
a.d._510_n_ok Posted November 14, 2012 Author Report Share Posted November 14, 2012 can't believe I froze for four years........freakin' heater will run ya out now! Quote Link to comment
banzai510(hainz) Posted November 14, 2012 Report Share Posted November 14, 2012 I seen a 510 square headlight in Enumcalw Washington on Sunday just like yours. It was a Auto, in perfect condition. Quote Link to comment
Stoffregen Motorsports Posted November 14, 2012 Report Share Posted November 14, 2012 Speaking of thermostats, has anyone here ever used the Toyota two stage thermostat before? Quote Link to comment
ggzilla Posted November 14, 2012 Report Share Posted November 14, 2012 Looks like a thermostat with a large jiggle-valve. What does 2-stage mean? Here's what Nissan said about the jiggle-valve, which they started fitting in 1970: * "fitted with a jiggle valve to improve defrosting performance" * "shorten the warm up period" Quote Link to comment
ggzilla Posted November 14, 2012 Report Share Posted November 14, 2012 Reading up on this, the two-stage actually has a second tiny thermostat. This is to deal with certain inadequacies of the the Toyota cooling system. It's used for reason similar to a jiggle vavle to keep a small amount of coolant flowing (a larger amount than a jiggle valve type). Quote Link to comment
Stoffregen Motorsports Posted November 15, 2012 Report Share Posted November 15, 2012 I have used them in a few of my own vehicles, especially my rock crawlers. They are added insurance in my opinion. Quote Link to comment
ggzilla Posted November 15, 2012 Report Share Posted November 15, 2012 Insurance for what? They are not the fail-safe type. Quote Link to comment
oldskoolvws Posted November 15, 2012 Report Share Posted November 15, 2012 Speaking of thermostats, has anyone here ever used the Toyota two stage thermostat before? In everything it fits in my friend. Toyota Part Number: part # 90916-03070 What this is a three component TS. -The first is the jiggle valve. It can be seen in the picture at about 330 oclock. -Second is the stage one TS. It can be seen in the picture at about 6 oclock. It opens at a cooler temperature to allow water to pass once the engine reaches a specific temperature but still restricts the flow to maintain a minimum constant temperature to warm up the engine properly. This also allows "minimal" heat to your heater core during the winter months to bring heat on early instead of having to wait for the main TS to open. I LOVE THIS!!! -Third is the stage two TS. Obviously the large one in the center. When this opens and closes based on engine temperature (radiator, fan, load, etc.), the smaller one normally remains open to ensure a constant minimal heat load. The concept behind this that no matter the temperature, you do not get a fluctuating heat load typically seen with single stage thermostats that do not have a piped bypass system. It's important on EFI systems because the temperature sensors put you in either open loop or closed loop based on temperature. Once you've reached the stage one TS temp, you no longer bounce in and out of loops. Even with these, I still drill a 1/8" hole in every thermostat to help reduce airlock and maintain a very minimal flow through the TS. I learned about these way long ago when I was modding my 22RE in my 4Runner (which is about to get a brand new rebuilt motor in about 3 days). 2 Quote Link to comment
Stoffregen Motorsports Posted November 15, 2012 Report Share Posted November 15, 2012 Insurance for what? They are not the fail-safe type. Read below. The concept behind this that no matter the temperature, you do not get a fluctuating heat load typically seen with single stage thermostats that do not have a piped bypass system. It's important on EFI systems because the temperature sensors put you in either open loop or closed loop based on temperature. Once you've reached the stage one TS temp, you no longer bounce in and out of loops. Quote Link to comment
Stoffregen Motorsports Posted November 15, 2012 Report Share Posted November 15, 2012 Like I said, good in a rock crawler which sees heavy winter usage, plus extreme heat at low speeds. Quote Link to comment
oldskoolvws Posted November 15, 2012 Report Share Posted November 15, 2012 I fixed it for you :rofl: Like I said, she's good in bed, sees heavy winter usage, plus extreme heat at low speeds. 1 Quote Link to comment
Stoffregen Motorsports Posted November 15, 2012 Report Share Posted November 15, 2012 Are we talkin' about my wife or yours?! Quote Link to comment
oldskoolvws Posted November 15, 2012 Report Share Posted November 15, 2012 I gotta get mine real drunk to have REAL fun hahaha. 1 Quote Link to comment
