Eagle_Adam Posted December 11, 2012 Author Report Share Posted December 11, 2012 heater core is cleaned up with new foam added Link to comment
Eagle_Adam Posted December 11, 2012 Author Report Share Posted December 11, 2012 heater core is back in door panels are going back on Motor is about buttoned up Link to comment
Eagle_Adam Posted December 11, 2012 Author Report Share Posted December 11, 2012 ok, down to the last few things before i can check this build off my list for a while. Im stuck, on a tranny..... :confused: actually im stuck on how to mount said tranny propperly... :rofl: I pulled a 5 speed from a 720, and the truck had a 4 speed in it to begin with. The 4 speed mount is about an inch too tall and the 5 speed diddnt have a mount. Sooooooooooo, whats the correct x member and mount to install a 720 5 speed in a 620? Link to comment
]2eDeYe Posted December 11, 2012 Report Share Posted December 11, 2012 Are you swapping out a long tail 4 speed? If so, you should just be able to use the same mount and crossmember. Link to comment
Eagle_Adam Posted December 11, 2012 Author Report Share Posted December 11, 2012 yes, the 620 was a 4 speed, i have a 80/81 720 5 speed from a L20 powered 720. I thought the mount was the same regardless but i was tied and so was skib so we called it a night and went upstairs for a safety meeting Link to comment
]2eDeYe Posted December 12, 2012 Report Share Posted December 12, 2012 If they are the same length you should be able to use the same mount. If the old one in the shorter 4-speed you may need to order a new rubber mount and use the other ste of holes at the frame to mount the crossmember. Link to comment
Eagle_Adam Posted December 12, 2012 Author Report Share Posted December 12, 2012 no, the cross member lined up, it was just an inch or so away from the mount. I still haven't tried again so its prob just something stupid Link to comment
yello620 Posted December 12, 2012 Report Share Posted December 12, 2012 Long tail 4spd crossmembers are different than long tail 5spd crossmembers. As far as i know the rubber mount is the same, but may not be the same as the 720. Link to comment
Eagle_Adam Posted December 12, 2012 Author Report Share Posted December 12, 2012 Long tail 4spd crossmembers are different than long tail 5spd crossmembers. fuck Link to comment
yello620 Posted December 12, 2012 Report Share Posted December 12, 2012 A 4spd crossmember is basically flat across the top surface. From the ends where it mounts to the frame to the center where the trans mounts. A 5spd crossmember drops down about an inch just inboard of the frame mounting flange. The center section is still flat after that drop. So it is kinda like this.--\______/--. Once you see the two styles, they will be obvious. Link to comment
Eagle_Adam Posted December 12, 2012 Author Report Share Posted December 12, 2012 i think you nailed the issue yello620....... cus right now it seems like the x mem is an inch off Link to comment
yello620 Posted December 13, 2012 Report Share Posted December 13, 2012 And i threw one of those crossmembers in the scrap about nine months ago. Figured i would never need one. Link to comment
Eagle_Adam Posted December 19, 2012 Author Report Share Posted December 19, 2012 Got the trans back in! i was just tired and doing something wrong cus it worked just like i thought it should have the 2nd time around. So with that out of the way i got back into the swing of things Drum breaks are all adjusted and ready to go trans is in interior is going back together picked up a head unit and speaker wire so i can install the gauge bezel valves are checked and adjusted painted under the cowl still to do before it can be a DD: install drive line finish installing the interior figure out the fan issue - the pulled from a 280 zx was what i was told was right but it isnt . install cowl install hood exhaust welding and drive this SOB!!! Link to comment
converted_to_datsun Posted December 27, 2012 Report Share Posted December 27, 2012 How close is this thing to driving? Link to comment
Eagle_Adam Posted December 27, 2012 Author Report Share Posted December 27, 2012 needs the driveline put in, the gauges put in, the radio put in and a few other odd's and ends then it should be good Oh ya, and it needs an electric fan cus im done messin with the factory one Link to comment
converted_to_datsun Posted December 27, 2012 Report Share Posted December 27, 2012 The factory one won't fit? Link to comment
Eagle_Adam Posted December 27, 2012 Author Report Share Posted December 27, 2012 factory what? Link to comment
Draker Posted December 27, 2012 Report Share Posted December 27, 2012 factory what? Wind making device. Link to comment
Eagle_Adam Posted December 27, 2012 Author Report Share Posted December 27, 2012 ahhh.... :rofl: and no, the water pump i put in is aftermarket and doesnt have a clucth. So i need a different pulley and a different fan. Neither seem to be working for me so fuck it - electric fan and a switch it is Link to comment
Eagle_Adam Posted March 6, 2013 Author Report Share Posted March 6, 2013 ok, soooooo its been a long time since iworked on this project. Since my car accident i havent been able to do nearly as much wrenching as i used to but im getting back into the swing of things now!!! Lest weekend i got the new stereo wired in and ready to go center console is in old water pump was taken out in prep for on with a fan clutch Things to do: find a replacement hard line for coolant that goes around the front of the motor install the new water pump install the one piece drive line from my old truck install the speakers the whole gauge cluster is still out - so install it as well rewire a few things and get this one on the road!!! Link to comment
The Taterhead Posted March 7, 2013 Report Share Posted March 7, 2013 Set backs are a bitch but it doesn't look like it'll be long now. Then you can focus on your other 4,375 builds. haha Link to comment
Eagle_Adam Posted March 7, 2013 Author Report Share Posted March 7, 2013 LOLz, im tryn to trim down the number of build i have so i can focus on one or two. But ive been saying that for a year now :P Link to comment
Eagle_Adam Posted March 10, 2013 Author Report Share Posted March 10, 2013 got the new one piece driveline in! Got the water pump in! I just need to figure out this last coolant hardline and the gauges then its off to the exhaust shop and on to a DD status FINALLY!!!! Link to comment
Eagle_Adam Posted March 11, 2013 Author Report Share Posted March 11, 2013 Coolant line is done, el dizzy is wired, just need to get 2 new bulb sockets for the gauges and I can start putting the bezel back in. After that it's fluids and a once over before the exhaust shop. Link to comment
Eagle_Adam Posted March 14, 2013 Author Report Share Posted March 14, 2013 got one of the last major hurtles done!! the exhaust is not welded up with a new flange and all!!! WOOT WOOT now i gotta pick up a good battery and try to fire this bitch up 1 Link to comment
