Eagle_Adam Posted August 9, 2013 Author Report Share Posted August 9, 2013 mother fucking winning!!!!!!!!!!!!!!!!!! just need a few more things from the JY and this will be at blue lake! Link to comment
Eagle_Adam Posted August 10, 2013 Author Report Share Posted August 10, 2013 Up and running! My dads drive it to work tomorrow for the first time! Mission accomplished Link to comment
Eagle_Adam Posted August 12, 2013 Author Report Share Posted August 12, 2013 this is why i do what i do! my parents both made it to blue lake in the 620 i built for my dad!!! 5 Link to comment
its_karl Posted August 13, 2013 Report Share Posted August 13, 2013 I thought you were alright before... You fucking rock! Truck sounds good. Link to comment
Eagle_Adam Posted August 14, 2013 Author Report Share Posted August 14, 2013 thanx guys, datsun are a labor of love. When my dad said he "could" daily a 620 i about fainted...... then went strait to craigslist! Update: my dads been driving it to work every day, says it need the brakes looked at(its got new shoes and springs all around so just an adjustment/bleed) but other than that hes loving the 5 speed and the sound of the truck Gets lots of looks and has co-workers asking about it 1 Link to comment
Eagle_Adam Posted September 13, 2013 Author Report Share Posted September 13, 2013 just got word that the new valve cover and timing inspection plate are done being powder coated at jrocks!!!!1 insert DTP comment here VVVV 1 Link to comment
Eagle_Adam Posted September 27, 2013 Author Report Share Posted September 27, 2013 since im going to be using my dads truck as a DD while i do my KA swap i figured a once over and quick tune up were in order retourqued the head bolts checked the valve gap oil chance new belt topped off the anti freeze re timed the motor and tweeked with the carb a bit runs like a raped ape..... for an L motor with a weber it scoots good! also replaced the broken hazard switch then i went to find out why the truck started pulling to the right really bad on my test drive....... seems like i found the issue :/ brand new fucking shoes >< so looks like ill have to do front brakes this weekend :( Link to comment
Eagle_Adam Posted October 7, 2013 Author Report Share Posted October 7, 2013 new seat new horn pad 1 Link to comment
Eagle_Adam Posted October 14, 2013 Author Report Share Posted October 14, 2013 topped off all the fluids checked all the mani bolts(several were loose causing a coolant leak) cleaned her out real good put in a few missing pieces(knob on the heater control, garnish behind one of the window rollers, ect) time for my dad to drive her one more time before his hip replacement this Wednesday - then hes down and out for 6 weeks :/ Link to comment
Eagle_Adam Posted October 17, 2013 Author Report Share Posted October 17, 2013 well, surgery went well doc said he would be a rock star if he could get out of bed and walk to the bath room. he did that, and then walked down the hall 75ft to chase a nurse that was flirting with him!! which is great for him, but shortens my time frame for my swap...... 2 Link to comment
]2eDeYe Posted October 17, 2013 Report Share Posted October 17, 2013 Sounds like your pops wants back in his Datsun :) 1 Link to comment
Eagle_Adam Posted October 17, 2013 Author Report Share Posted October 17, 2013 right!!! the physical therapist said he could drive his mustang in a few weeks(its an auto) but the datsun was off limits until they cleared him 1 Link to comment
Eagle_Adam Posted October 24, 2013 Author Report Share Posted October 24, 2013 well the truck started making a horrible screaming bearing noise on the way home the other day, followed by the charge light flickering and by the time i got home the charge light was on. so i swapped in a new(re-manned) alt figuring that would solve both my issues or at least let me check off one issue and keep looking for the sound but oddly it only solved the bearing noise...... so riddle me this? why when the truck idles does the charge light turn off and when you hit the gas it comes back on till you release the gas and the RPM's come down......... anywho, while i was int he engine bay i added the new blue bling i picked up from Jrock last weekend yummy! once i have the charge light issue sorted i can DD this truck and take my blue truck down for the KA swap Link to comment
]2eDeYe Posted October 24, 2013 Report Share Posted October 24, 2013 Sounds like the voltage regulator might be having some issues. May be over charging at higher RPMs? Link to comment
Eagle_Adam Posted October 24, 2013 Author Report Share Posted October 24, 2013 grumble grumble grumble....... knew i shoulda just did the IR swap Link to comment
izzo Posted October 24, 2013 Report Share Posted October 24, 2013 I like that blue valve cover man. 1 Link to comment
Eagle_Adam Posted October 24, 2013 Author Report Share Posted October 24, 2013 thanx, me too. It was the crowning touch that makes it look diff that the PO had it when we bought it Link to comment
Eagle_Adam Posted October 28, 2013 Author Report Share Posted October 28, 2013 Sounds like the voltage regulator might be having some issues. May be over charging at higher RPMs? grumble grumble grumble....... knew i shoulda just did the IR swap the mystery continues, i had jacob stop by over the weekend and the alt is charginf fine, and the volt reg is operating fine..... ive driven the truck for 4 days with the charge light on waiting for it to die on me.... but nothing has happened. Link to comment
]2eDeYe Posted October 29, 2013 Report Share Posted October 29, 2013 How many volts is it charging at? Link to comment
Eagle_Adam Posted October 29, 2013 Author Report Share Posted October 29, 2013 Its charging fine. It was charging in the 13v range at all rpms... Just the light would come on any time above 800 rpm... Link to comment
heretic Posted October 29, 2013 Report Share Posted October 29, 2013 Hope your pops is doing good man.!!! what alternator do you have.? what's the condition of the sensing wire? Link to comment
Eagle_Adam Posted October 29, 2013 Author Report Share Posted October 29, 2013 its a new remand stock alt all wires look good to me.... Link to comment
