Dat Lurka Posted September 19, 2012 Report Share Posted September 19, 2012 So I should be driving a datto right now, but It was having compression issues. Carnage: These two are where the headgasket was missing Heads going to the shop in the morning. I've seen worse. Quote Link to comment
Dat Lurka Posted September 19, 2012 Author Report Share Posted September 19, 2012 The heads pretty well dipped between 2&3. Should I expect a higher compression ratio? Will swapping for flat-top pistons get me up to 10:1? Quote Link to comment
INDY510 Posted September 19, 2012 Report Share Posted September 19, 2012 Something looks wrong here ... :confused: 1 Quote Link to comment
nismo dr Posted September 19, 2012 Report Share Posted September 19, 2012 just one thing? 2 Quote Link to comment
Dat Lurka Posted September 19, 2012 Author Report Share Posted September 19, 2012 What's wrong? Quote Link to comment
Dat Lurka Posted September 19, 2012 Author Report Share Posted September 19, 2012 And it better not be the fram filter :fu: Quote Link to comment
flatcat19 Posted September 19, 2012 Report Share Posted September 19, 2012 I sense a radio somewhere. 1 Quote Link to comment
metalmonkey47 Posted September 19, 2012 Report Share Posted September 19, 2012 Holy headgasket batman. Glad mine works great :rofl: 1 Quote Link to comment
INDY510 Posted September 19, 2012 Report Share Posted September 19, 2012 . Did you block the chain tensioner?? .... I didn't even notice the FRAM .. :rofl: ..... why are all the pistons at bottom dead center? Quote Link to comment
flatcat19 Posted September 19, 2012 Report Share Posted September 19, 2012 ^ That's the first thing I saw. Fram second. Quote Link to comment
Dat Lurka Posted September 19, 2012 Author Report Share Posted September 19, 2012 . Did you block the chain tensioner?? .... I didn't even notice the FRAM .. :rofl: ..... why are all the pistons at bottom dead center? No, I did not :no: I don't think it popped all the way out though. It's just an illusion form the picture angle. Quote Link to comment
bananahamuck Posted September 19, 2012 Report Share Posted September 19, 2012 Top dead center ?? we don't need no top dead center.. Quote Link to comment
flatcat19 Posted September 19, 2012 Report Share Posted September 19, 2012 They always pop out. I see a timing gasket kit in your future. Quote Link to comment
datzenmike Posted September 19, 2012 Report Share Posted September 19, 2012 Engine is not at TDC so I hope you marked the chain/cam sprocket relation. If you didn't block the timing chain tensioner, disregard the above statement. Fram filter failure. This gasket has been blown for some time to be eroded this much OR severely over heated. (or both) The heads pretty well dipped between 2&3. Should I expect a higher compression ratio? Will swapping for flat-top pistons get me up to 10:1? ANY shaving of the head will raise the compression. Just flattops will give 9.941 Did you straight edge it to look for a warp? Shops will gladly shave a head that doesn't need it. Quote Link to comment
Jayden71 Posted September 19, 2012 Report Share Posted September 19, 2012 Top dead center ?? we don't need no top dead center.. Fram, we don't need no filter neether Timing chain wedge?? Wait......whuuut?? :confused: Quote Link to comment
Busta Nut Posted September 19, 2012 Report Share Posted September 19, 2012 I see a timing gasket kit in your future. :rofl: Quote Link to comment
Dat Lurka Posted September 19, 2012 Author Report Share Posted September 19, 2012 Engine is not at TDC so I hope you marked the chain/cam sprocket relation. If you didn't block the timing chain tensioner, disregard the above statement. Fram filter failure. This gasket has been blown for some time to be eroded this much OR severely over heated. (or both) ANY shaving of the head will raise the compression. Just flattops will give 9.941 Did you straight edge it to look for a warp? Shops will gladly shave a head that doesn't need it. I just got back from the shop. I pulled the timing cover off and collected the tensioner parts. The marks on the chain are gone so I'm not sure where to start but I saw a thread about counting the links or some shit. I can't find a mark on the crank sprocket but I thought it was stamped. I have the original one and I know it's stamped. I'm not fooling with it till I get the head back. I guess I'll put #1 and the cam at TDC and bolt the head on. Then figure out the timing chain. Never done this before. Shit happens and I learn from my mistakes. Not putting a piece of wood between the chain is costing me another 2 hours of labor. I believe the HG was blown before the last owner bought it. When I got the truck I found oil on the plugs. I just finished it off. The head does not appear to be warped but If i put an edge across the head between 2&3 you can see the wear. I'm getting the works. Dip, shave, port and polish, valve seats, valves, valve guides, valve guide seals, and he said he would do his best to repair any pitting. All for 100$ As for wear... The pistons seem to sit to one side of the cylinders. When I do the rebuild it may end up a 2.1 or hell I think I can go to 2.4. I'm not the first :fu: Quote Link to comment
Dat Lurka Posted September 19, 2012 Author Report Share Posted September 19, 2012 I've done it one. I can do it again. One link is definitely a bright link. And I can count! It will all work out in the end. Kind glad I pulled the timing cover. A lot of my bolts needed to be retorqued. I'll be on the road by the weekend. At which point I'm gonna go visit metalmonkey to bring him his wiper arm nut back :D and steal his wheels 1 Quote Link to comment
Draker Posted September 19, 2012 Report Share Posted September 19, 2012 Dude, that's a brush not a flashlight... Wtf? 1 Quote Link to comment
Dat Lurka Posted September 19, 2012 Author Report Share Posted September 19, 2012 Dude, that's a brush not a flashlight... Wtf? If I took pics of the rest of the shop they'd baker act me Quote Link to comment
I'm BLUE Posted September 19, 2012 Report Share Posted September 19, 2012 Try not to let any debris get in the cylinders/rings .. vacuum it out ... and cover it when not working with it .. least dusty environment possible if you can help it All that work for $100 ? Wow ! Quote Link to comment
Draker Posted September 19, 2012 Report Share Posted September 19, 2012 If I took pics of the rest of the shop they'd baker act me Lol, I hear ya. Looks like you made an effort to organize. That's probably more than a lot of us. Quote Link to comment
Dat Lurka Posted September 19, 2012 Author Report Share Posted September 19, 2012 Try not to let any debris get in the cylinders/rings .. vacuum it out ... and cover it when not working with it .. least dusty environment possible if you can help it All that work for $100 ? Wow ! I'm gonna hit them with the shop vac when it's time. They're already full of gunk. I took the thin cardboard sheet from the new headgasket and covered them up. First thing I did when I pulled the head was take an oak leaf out of an oil channel. :rofl: Yeah can't beat the price. He charges 50$ a head to clean and shave them, 100$ to do it all. You can call any place around here and they all recommend him. I first found him through my buddy that races dirt track. He brings his pinto engine there. He spent about 3k last time though. It was pretty much a stock 2.3 when I met him. Now it's a 2.5? It's running 13:1 and spins 10k rpm. It's in a foxbody and it's fast as shit! Quote Link to comment
I'm BLUE Posted September 19, 2012 Report Share Posted September 19, 2012 oakleaf lol ! that's a great deal !!! :cool: those little 2.3's are interesting !! Quote Link to comment
Dat Lurka Posted September 19, 2012 Author Report Share Posted September 19, 2012 oakleaf lol ! that's a great deal !!! :cool: those little 2.3's are interesting !! It's kind of like the L engine. They took the bullet proof Ford I6 and made a I4 from it. I like me some Fords. But like all domestics, I like them pre 75' Quote Link to comment
