Cahoon520 Posted October 3, 2012 Report Share Posted October 3, 2012 Deisel????????? why bother. a l20 with the stock gear ratio would be more than enough why deal with torsion bar issue and retrofitting and the truck will be worth less. you can find 720 deisels and they dont go for much mone Why are you hatin' on the diesels Hainz? Quote Link to comment
what Posted October 25, 2012 Author Report Share Posted October 25, 2012 http://<a href="http://s905.beta.photobucket.com/user/70snova/library/" target="_blank"><img src="http://i905.photobucket.com/albums/ac251/70snova/DSCN0734.jpg" border="0" alt="Photobucket"/></a> Quote Link to comment
what Posted October 25, 2012 Author Report Share Posted October 25, 2012 Gots some wide white walls and steel wheels. Will take better pictures tomorrow outside. Quote Link to comment
gene knight Posted October 25, 2012 Report Share Posted October 25, 2012 hey wayno how about some pix of interior of your 521kc and don't forget the kc cab Quote Link to comment
wayno Posted October 25, 2012 Report Share Posted October 25, 2012 Here you go, he has not taken any photos of the inside yet. Quote Link to comment
wayno Posted October 25, 2012 Report Share Posted October 25, 2012 hey wayno how about some pix of interior of your 521kc and don't forget the kc cab Why do you want photos of the inside of my cab? Fact is I never finished the inside other than making it solid, and painting it where it was welded so it would not rust. There are photos in the build thread, the link is in my signature. Quote Link to comment
banzai510(hainz) Posted October 25, 2012 Report Share Posted October 25, 2012 Calhoon I dont hate diesels per say But lets get praticle here. diesels is more expensive and also the parts which are not really common which face the fact most Datsun guys dont want to pay for. and alot of these parts Nissan is not going to keep for low production numbers. I seen alot of Datsun 810 wagons go for cheap. Nobody wants them and dealers really dont want to see one of those come in the shop to work on. L motors are stacking up in the Seattle area almost FREE. I cant see the + side for a car/truck thats going to get the same milage as the early Nissan motor werent all that great in fuel economy. Quote Link to comment
what Posted October 25, 2012 Author Report Share Posted October 25, 2012 http://<a href="http://s905.beta.photobucket.com/user/70snova/library/" target="_blank"><img src="http://i905.photobucket.com/albums/ac251/70snova/DSCN0740.jpg" border="0" alt="Photobucket"/></a> Quote Link to comment
what Posted October 25, 2012 Author Report Share Posted October 25, 2012 If you could upload all the photos of the inside and the engine bay I would be very thankfull. Thanks. Quote Link to comment
DatWifey Posted October 25, 2012 Report Share Posted October 25, 2012 Great looking truck! When you want to post your photos, hover over the thumbnail in the main gallery and click on the IMG code line, then paste the line in here. Quote Link to comment
banzai510(hainz) Posted October 25, 2012 Report Share Posted October 25, 2012 What where is this vacumme advance going to? It should go to the base of the weber carb which is most likely the valve cover side on the 32/36DGV. Hopefully your not taking it off the manifold hole in the back also the whats the 2 lines ging to the fuel vent valve? the lower one goes to the crank case vent tube there is a upper smaller tube where it plugs to. The upper went to the cased of the aircleaner I believe.Im not sure if you need it to the intake manifold. Is that crank case tube vent open.? You should find the hose and route it to the PCV valve on the intake manifold. motor bay looks pretty clean and stock Quote Link to comment
what Posted October 25, 2012 Author Report Share Posted October 25, 2012 Hi. I do have the vacuum advance hooked up to the intake. The vacuum at the base of the carb I blocked off. Crank case has a chrome valve cover style breather on it. What would you recommend using the intake vacuum for? The way it is the motor runs and idles great. Quote Link to comment
what Posted October 25, 2012 Author Report Share Posted October 25, 2012 Banzai. Thanks for the advice. I went out there. Blocked off the intake vacuum. routed the dist advance vacuum to the carb. I then had to adjust the timing and the air mixture along with the idle to get it running right. It now runs like a complete different truck. It has alot more power without any hesitation. Thanks for the advice. Quote Link to comment
jon521 Posted October 26, 2012 Report Share Posted October 26, 2012 Al! that looks so good man! i need to stop by sometime soon! 1 Quote Link to comment
ol'skoolrob Posted October 26, 2012 Report Share Posted October 26, 2012 damn that truck is clean i love the whitewalls and the hubcaps it looks pretty slick nice truck bro 1 Quote Link to comment
sergent Posted October 26, 2012 Report Share Posted October 26, 2012 The diesels go for good bucks down here in so cal. Its at least .25 cents cheaper than the cheapest gas right now. And running good,a 720 could pull upper 30 mpgs. Not bad. parts are a bastard (transmission) I am going to get a 521 next however for beautys sake. I have my eye on a fairly clean one. I love your truck! Quote Link to comment
what Posted October 26, 2012 Author Report Share Posted October 26, 2012 Thanks bro. Quote Link to comment
banzai510(hainz) Posted October 26, 2012 Report Share Posted October 26, 2012 Banzai. Thanks for the advice. I went out there. Blocked off the intake vacuum. routed the dist advance vacuum to the carb. I then had to adjust the timing and the air mixture along with the idle to get it running right. It now runs like a complete different truck. It has alot more power without any hesitation. Thanks for the advice. YOUR WELCOME!!!!!!!!!!!!!!! I have caught this about 4-6 times this has happens. I cant believe other ratsuner dont see this at the local shows. Quote Link to comment
what Posted October 27, 2012 Author Report Share Posted October 27, 2012 Love it here. Quote Link to comment
Royal Sierra Posted October 29, 2012 Report Share Posted October 29, 2012 The best looking 521. I love those whote walls. Damn Quote Link to comment
what Posted October 29, 2012 Author Report Share Posted October 29, 2012 Thanl you Royal sierra. Thanks alot. Quote Link to comment
DISLEXICDIME Posted October 29, 2012 Report Share Posted October 29, 2012 did you get that shift lever off e bay? Quote Link to comment
what Posted October 30, 2012 Author Report Share Posted October 30, 2012 Shift lever. Yes sir. Bought it off of ebay probaly a couple years ago. I cut off the base of my shifter and welded the ebay peice onto it. Quote Link to comment
redrooster Posted November 19, 2012 Report Share Posted November 19, 2012 great lookin truck! i was gonna go with the white walls and hubcaps, but man,,,you got me liking them old Cragar slots now. Quote Link to comment
