Aibast Posted November 29, 2012 Author Report Share Posted November 29, 2012 did some work again. Got the rear ligths cables but in side the frame. A friend - whos garage I'm using and who is helping me will do the rear lights. He will be a navigator with me. So I have a co-driver who is a policeman (traffic accident investigator). This guy has seen enough bad things to make your stomick turn for hours. You can see the cables exiting fromt he frames rear end. I installed the underdash elektrics, and the dash itselt. Started on the floormats. Got the fan and wipers working properly again. Restoresd the cabeling to original state. To give me some idea of what goes where. PS. The red button on the dash replasing the sigarette lighter is the cars start button. Did the rear brakes. The andjusters where seased up with rust. But 15min with a blowtorch and they opened up. Treated them with graphite grease. Quote Link to comment
Aibast Posted December 2, 2012 Author Report Share Posted December 2, 2012 Rear lights and license plate in the metal framework. Everything is now hooked up. Got the hazards and sidemarkers working. The seat is in, mounted the seatbelts. I still need to do one center clamp for the belts. Changed out the fusebox. Now I need to make a proper mount for it. Quote Link to comment
Aibast Posted December 5, 2012 Author Report Share Posted December 5, 2012 what are the stock 14" wheel measurments. The bolt pattern is 6x139,7mm, But what is the offset and center hole diameter? Quote Link to comment
TyS Posted December 5, 2012 Report Share Posted December 5, 2012 Mines s long bed that's straight...useful for work. Quote Link to comment
Aibast Posted December 6, 2012 Author Report Share Posted December 6, 2012 How is life with a long bed? Mine is more or less streight, the frames are in realy good condition considering the salt cars get in here in the winter time. The bed itself has some frames rusted trough, but not very bad. As I work in a concrete product company I'll be using my car also as a transport trucks for small elements like planters, dustbins and so on. That's why I'll be replacing the original @ some point with a flatbed so I can get cargo on from the sides with a forklift. Quote Link to comment
Aibast Posted December 6, 2012 Author Report Share Posted December 6, 2012 Today registered my self and the car for 23-24.02.2013 oldtimers winter rally. http://forum.automot...d.php?tid=43002 As its the first time I'll be driving myself I need to go trough qualifying. Hope to get the car running and inspected for legal use in the early january Quote Link to comment
Aibast Posted December 9, 2012 Author Report Share Posted December 9, 2012 well got the interior all ready this is what it looked like when I got the car this is now Well did some other things: new shocks and lower mounts this is the rear lights cable exit also you can see new leafspring clamp. this is where I'm going next 1 Quote Link to comment
FlyinPat Posted December 10, 2012 Report Share Posted December 10, 2012 I really like watching this project move along. So are you planning on using this truck as a work truck and a rally racer? Quote Link to comment
Aibast Posted December 10, 2012 Author Report Share Posted December 10, 2012 you got it right. I don't think a car should stand most of the year, I'll be using it as a work truck + a rally racer Quote Link to comment
Aibast Posted December 14, 2012 Author Report Share Posted December 14, 2012 waiting for my new M+S tyres - Barum SnoVanis 185 R14C http://www.barum-online.com/generator/www/de/en/barum/tires/themes/winter-tires/snovanis/snovanis-en.html I hope these will give me some traction in snow and in summer time on gravel and mud. Also got new exhaust tubing, still need to rent a tubebender. The exhaust will be small 40mm outer diameter and 2mm wallthicknes. I think it will last a while. Didn't want to go bigger than stock so I wouldn't loose exhaust gas impuls and give me good low end torque. As its more needed than highrev hp. Quote Link to comment
Aibast Posted December 18, 2012 Author Report Share Posted December 18, 2012 today got a new muffler for the exhaust and but on a new copper fueline from the tank to under the hood. The exit is next to clutch silinder. To that a piece on fuel line rubber tube + a filter + tube to the fuelpump. Removed the carb and cleaned it all up.Took it to pieces to properly clean the insides. Made a new throttle cable from a bicycle brake cable. Lubed the joints on the carb. Adjusted the cars doors to give more stress to new door seals. So they'll sit nice and flush. Removed the old oil from the engine. Need to get a new oilfilter, but Audi 80's one goes on there, so thats just droping by a parts store. What came out was horrid black tar like crap. Got new BP mineral 10W40 oil waiting. But everyting seams to work on the engine. The inlet manifold was realy clean. one of the cleanest I've seen for a long time. It tells me that valves seal properly and doesn't have any timing or blowby issues. Spark blugs are so old they are beginning to rust, but burn color was spot on perfect. Going to change the plugs for new ones, also the ditributer cap and rotor, new spark cables to. My friend will fix the gastank and make a proper protection for it. 20x20mm tubing frame under it + a skidplate. Then the exhaust and after that I can drive the car a bit. Turn it around on its own power. Can chenc ke brakes, and engine frod leaks. Checked over the front brakes. There are new brake pads and the brake rotors are in good shape, just need to be bleed properly. No play in the steering :)so no need for new tie rod ends and other stuff. Front shocks are also good. Its -12 C in here outside @ moment so need to get proper -36C coolant for the engine. The rear differential now has had its new oil in it for about 2 weeks. No leaks what so ever :) Damn happy with that. Now no work from 22nd dets. to 7th of jan. hope to get a lot of things done over the holidays. Hoped to get the car ready enough to get some xmas trees, but didn't work out. Have to get them with my 850 again this year. http://www.panoramio.com/photo/46115082 This was last year :) Got a new oilcap for the engine, original got busted when opening. Someone has had some fun with it. It didn't move @ all, finaly when I got it open useing pliers and so on, then the metal insert thats between a spring and the caps bottom had moved to one side and torn the caps lower half open and releasing the spring. That got stuck with rest of the valvecover. Quote Link to comment
Aibast Posted December 26, 2012 Author Report Share Posted December 26, 2012 found this pic does anyone have any info on this one or even a color picture? Quote Link to comment
merlin Posted December 26, 2012 Report Share Posted December 26, 2012 http://afxslotcarstickers.net/html/AFX/stickers/htmls/datsunpu.html Quote Link to comment
merlin Posted December 26, 2012 Report Share Posted December 26, 2012 this page sells afx decal packs for that truck so you can get those colors right... http://www.hoslotcarracing.com/Decals.html Quote Link to comment
Aibast Posted December 26, 2012 Author Report Share Posted December 26, 2012 It would be great to get my hands on a vector file of these decals :thumbup: As my car is yellow, then this theme would be great. Quote Link to comment
Steroid Posted December 27, 2012 Report Share Posted December 27, 2012 That was Jimmy Conner. My first truck was one He added accessories to supplement His racing. He lives in Lake Havasu City, AZ. I have not been able to track Him down though. The pushbar was made by House Of Steel in El Cajon, California. Those wheels were Tacomas that were made in My hometown of Escondido, California. Notice the headlight covers. I made a pair out of fiberglass sheet and used upholstery snaps to hold them on. These photos were taken in 1974 and 1975. I enlarged the pic quite a bit to show the headlight covers I made. That is the only view I have of it. Notice in the top photo the CRE sticker on the front fender. The same sticker is on Jimmy's race truck above the front side marker light. Quote Link to comment
merlin Posted December 27, 2012 Report Share Posted December 27, 2012 jim connor is still around i met him at the BRE reunion. http://jimconnerracing.com/video-gallery.htm Quote Link to comment
Aibast Posted December 28, 2012 Author Report Share Posted December 28, 2012 Made some changes to logos, and made new print files in Corel. Took me a "lot" of time, whole 4 minutes :thumbup: . So all in vector graphics ready for print. Here is a preview pic of decals pack. If you need some of these files let me know via PM 2 Quote Link to comment
Aibast Posted December 30, 2012 Author Report Share Posted December 30, 2012 tried on the car today Mazda B2000 steelies, well they work :). Now got a second set of steel wheels. I can take on the rally with me two spare wheels. The fueltank is now repaired and has new heavy-duty brackets holding it to the car. Just needs a protective paint cover. Quote Link to comment
Aibast Posted December 31, 2012 Author Report Share Posted December 31, 2012 A bit off topic, but still a bit connected to Datsun. I wanted this year to get my xmas trees with the Datsun, but didn't have enough time to finish it by christmas. Well had to use my R again to drive 7km to woods on a road used only by 4x4 and tractors. Some game hunters use the place for hunting for boar and elk. There wheren't a lot of snow this year. Only about 20 cm. Didn't get stuck at all. Some snow blew over the bonnet and some you can see is stuck on the bumper. Did skid over some places with the cars bottom, but still went on strong. Had to play with throttle a lot not to spin the wheels to much. As it would have just dug deep into packed snow. 1km hike on foot in snow to my land. Good to have some land where to get at least some xmas trees. Only 4 this year. Quote Link to comment
Aibast Posted January 3, 2013 Author Report Share Posted January 3, 2013 finaly did something on the car. Changed the oil. What came out was black as night but still flowed nicely. In went BP's 10W40 mineral oil. Made a new oilcap. Original was uselessly twisted. Waiting on my ordered goods - outside sealer/paint for the fueltank, fuel filters, 1 working light for lighting up the truck bed and two 180mm round lights (Ring Rally Giant) for additional lighting for the nightime roads. These will be mounted behind the cab on the safety bar. Quote Link to comment
Aibast Posted January 7, 2013 Author Report Share Posted January 7, 2013 Got a box of goodies :thumbup: Spotlights, one worklight for the truckbed, paint for a gastank, gastank repair butty, exhaust assembly paste. And my little devil got a box to play in Quote Link to comment
Aibast Posted January 8, 2013 Author Report Share Posted January 8, 2013 got the exhaust done. just need to seal up and clamp the connection. The whole exhaust is in 2 parts. From manifold to the muffler. And the rear part with a muffler. All bent from straigth pipe all in one piece without any welds. You can see the old exhaust on the frame. Used that to bent the part thats under body. Also but on the fueltank and everything is now connected. Just some minor things, fuel and its time for a startup. Sorry for the callphone pic. Left my DSLR home. Quote Link to comment
banzai510(hainz) Posted January 8, 2013 Report Share Posted January 8, 2013 nice photos Lots of wild pigs in Estonia???????? Quote Link to comment
