RedBanner Posted July 11, 2012 Report Posted July 11, 2012 So its alittle humbling, with diagnostic equipment, tools and space gallore, books, ratsun, lots of resorces. But i cant get spark from the coil on my freinds 79 210. I need to get it sorted by the end of the day tomarow at the latest. To say the least there has ben some custom wiriring, the starter is ran off a momentary sitch, pulling power off the coil. So my first thought was coil. Change the coil and got no spark. So i jumped right to the coil off the battery, no spark, so i pulled the dizzy checked it out the best i could and it seems great i would have bought it. I have ignition power at the switch, coil, alt, but no,dash lights I rang out the fuses. I swapped in a third coil. I need some help with trouble shooting this one. Quote
DanielC Posted July 11, 2012 Report Posted July 11, 2012 Points type distributor, or electronic? Ignition systems work like this. Battery power is supplied to the coil positive. The coil negative is grounded by some type of switch, controlled by the engine. When it is time for the coil to fire, the engine opens the switch, and the coil fires. The switch could be a set pf points, a black "matchbox", or some other electronic device, but it is still essentially a switch. Quote
MicroMachinery Posted July 11, 2012 Report Posted July 11, 2012 Don't run anything off the coil except for the tach and possibly an electric choke. You can run a push button or something for the starter if you must, but don't use the coil for that. Is the coil hooked up correctly? 1 Quote
ggzilla Posted July 11, 2012 Report Posted July 11, 2012 Here's how to test the coil on a 210: Spark Test, matchbox Quote
wayno Posted July 11, 2012 Report Posted July 11, 2012 Check the coil wires, the best of people get the wires backwards on EI dizzys, negitive side of the coil goes to the "C" terminal, positive side of the coil goes to the "B" terminal. If that isn't it, make sure you have power to the coil when the key is in the start position. Quote
DATN510 Posted July 11, 2012 Report Posted July 11, 2012 A wiring diagram would help, check the black box to make sure it didn't get fried. Quote
Hardwyre Posted July 11, 2012 Report Posted July 11, 2012 No dash lights is interesting. Def need a wiring diagram. Was the coil you swapped in from a running rig? Quote
I'm BLUE Posted July 11, 2012 Report Posted July 11, 2012 Are you by chance ... losing (+) to the coil during "cranking" position of Ignition switch ? *Disconnect the starter "excite" wire or activation wire (at the starter --- from ign switch) *Grab a friend. *Have friend turn key to "On" position on Ign switch and test for voltage in engine bay *Have friend turn key to "Start" position on Ign switch and test for voltage in engine bay ( turn as needed ) *** In my experience condensors can literally be bad right out of the the new box! Make sure those connections are super clean and tight/double check gapping. The connectors through the distributors on many of my l-series have given me "notice" at one point or another.*** I'd look really hard at that distributor ... and (b+) while cranking to coil if it were my own :) . You already hot-wired the damn car so it should have ran :lol: ;). If "Acc" do not work you might consider fusible links and/or bad ignition relay/shorted wire or a possible bad ignition switch. I would be suspicious of the internal guts of the ignition switch itself. If you have a spare pop it in (after testing or suspicion). Edit: I'm pooped and probably not giving good advice or reading straight lol Quote
I'm BLUE Posted July 11, 2012 Report Posted July 11, 2012 Also make sure distributor shaft pin/gear pin is not sheared off. Some Ford's tend to do this lol Quote
elmerfudpucker Posted July 11, 2012 Report Posted July 11, 2012 And if you have a fast testlight, touch it to the ground side of the coil and see it it flickers from it catching a ground. I have a two wire led light and it strobes back and forth from red to green when it is cranking or running. Quote
RedBanner Posted July 11, 2012 Author Report Posted July 11, 2012 i cant post the wiriring dia. But i pulled it from the pdf page, i didnt wire the starter to the coil, both coils i tried where from running cars. The car ran but had another problem, then when i sorted those out i made it a block from home and lost spark. Its a 79 b310 with a ei distibutor. Thank you for the suggestions ill get back to it right after work :) 1 Quote
ggzilla Posted July 11, 2012 Report Posted July 11, 2012 Sounds like a loose wire. Very common. Quote
b3y0ndd34th Posted August 4, 2012 Report Posted August 4, 2012 Interested in how/if you got this fixed, having some trouble with my coil and plugs firing. Quote
