Llittle_Llama Posted May 11, 2008 Report Share Posted May 11, 2008 my 4 speed started acting up tonight so.......what are the years of the 280 (i think) that i need to look for to get the 5 speed out of, and is there anything i need to look out for in particular and it is just a straight bolt in swap correct? is there anything else i need to grab while im in there? do i need the clutch or is my new one fine? just looking for an all inclusive list, dont want to get halfway through and not have the money to finish it. i have a day to look, and can go back the next day to pull it, but need to make sure they have it before i drive the 3 hours back to get it. Quote Link to comment
jefe de jefes Posted May 11, 2008 Report Share Posted May 11, 2008 81-83 I believe. Quote Link to comment
datsunfish Posted May 11, 2008 Report Share Posted May 11, 2008 A 5 speed from any 280z with a L28 standard motor should be fine I believe.Any stock L series has the same bellhousing pattern.Unless you have the early 620 that came with the short shaft tranny,like mine,any l series long shaft tranny should be a bolt and go. Do you actually know if they have datsuns at this yard?Dont come home with a 720 tranny for a naps Z.Personally I would look around for an early 720 L series tranny considering there probably arent a ton of older dattos where you are at.Or even just look for the same 4 speed. Quote Link to comment
datzenmike Posted May 11, 2008 Report Share Posted May 11, 2008 As long as it measures 31.5" or 80cm long it will fit. There are two choices of 280Z car trannys: http://i138.photobucket.com/albums/q251/datzenmike/transZ5speedearlywideratio.jpg[/img]"] http://i138.photobucket.com/albums/q251/datzenmike/transZ5speedlatecloseratio.jpg[/img]"] Take note of the over drive gear on the late box. It's insanely low so mostly for road cruising, and high mileage. Note also the earlier one has a lower 1st gear for take offs and load carrying and the gear spacing would be more spread out, or wide ratio. The late box would be a close ratio and would have the least drop in RPMs between shifts. Another choice would be the 620 tranny from '77-'79 and has the same ratios as th early 280Z box. And last would be the '80 720 box but 1st is even lower and the gears are even more spread out: 1st.... 3.592 2nd.... 2.246 3rd.... 1.415 4th.... 1.000 5th.... 0.882 BTW don't pull an '80 4X4 as it won't have a speedometer cog drive in it. Quote Link to comment
Llittle_Llama Posted May 12, 2008 Author Report Share Posted May 12, 2008 theres a guy a few hours away that has a 280 with the 2.8 turbo, coulk a full swap be possible!?! and there are no datsun trucks here, but cars galore!!! Quote Link to comment
datzenmike Posted May 12, 2008 Report Share Posted May 12, 2008 The turbo cars had a T-5 Tremec 5spd I believe. It has an L bolt pattern but is longer so the driveshaft needs mods, and it is physicaly bigger so trans tunnel may need bashing. I'd skip it. I'll post a pic when I get home and you'll see. Quote Link to comment
DoctorB Posted May 13, 2008 Report Share Posted May 13, 2008 Hey, looks like we're doing the same thing! Just picked up an 82 ZX 5 banger to stuff in my 71 PL521. Will keep ya posted on how it goes. Nothing wrong with my 4-speed, I just wanted a better highway gear. Quote Link to comment
Gensaiken Posted May 13, 2008 Report Share Posted May 13, 2008 What kind of work is required to fit the 280Z trans in a 521? I know with my 510 it was a mess of work getting it all together. Isn't the 720 5speed identical to the 280Z? Quote Link to comment
Bleach Posted May 13, 2008 Report Share Posted May 13, 2008 Hey, looks like we're doing the same thing! almost but not quite. All 521's will have a short tail 4-speed. I believe Dwnshfter's 620 truck is the year with a long tail. His 5-speed from a Z should just bolt right in and be done. You will have some work to do. There is a thread on swapping in a Z 5-speed into a 521. Some extra work is required. As for the 720, 1980 720 (L20b) probably uses the same long tail as the 1980 Z. Gearing might vary but the size is the same. Quote Link to comment
Pacific coast Datsun Posted May 13, 2008 Report Share Posted May 13, 2008 I did the Z trans into a 521 swap. Search for my thread or PM for info. Quote Link to comment
denveratsun Posted May 15, 2008 Report Share Posted May 15, 2008 This site has been a real treat to work with! Yeah...I have used the "search" mechanism many times:) It even works! This is the start of the 4 speed swap for me too. Mine stuck in 4th gear the other day and so I got one from a 78z car...turns out to be from a newer car originally though, according to the pics up top, it is a later version. Either way...fine with me! I am looking forward to getting all the little stuff done and feeling the difference the 5th gear will make. I will try to get a pic up too. I know I like it when ya'll put pics up. Thanks guys. Quote Link to comment
datsunfish Posted May 16, 2008 Report Share Posted May 16, 2008 I had one stick in 4th gear too.I took it apart to find that a small rectanguar metal block that pushes in a release ring or something fell out.Impossible to free up,literally. Quote Link to comment
Bleach Posted May 16, 2008 Report Share Posted May 16, 2008 well, Dwnshfter hasn't been online in a few days. I think he may have died at the wrecking yard.... Quote Link to comment
Gensaiken Posted May 16, 2008 Report Share Posted May 16, 2008 well, Dwnshfter hasn't been online in a few days. I think he may have died at the wrecking yard.... Maybe it was a big yard... got lost..:blink: Quote Link to comment
MrRobatoGato Posted May 16, 2008 Report Share Posted May 16, 2008 Maybe his rig fell on him:lol:. Quote Link to comment
Bugeye Posted May 16, 2008 Report Share Posted May 16, 2008 Maybe his rig fell on him:lol:. funny, wrong, but funny:lol::lol::lol::lol: Quote Link to comment
]2eDeYe Posted May 16, 2008 Report Share Posted May 16, 2008 Maybe he got his 5 speed in and he's zoomin down the freeway... He'll have to change his name to upshftr :D Quote Link to comment
MrRobatoGato Posted May 16, 2008 Report Share Posted May 16, 2008 Maybe he has a secret vow and he's using the search button. Quote Link to comment
Llittle_Llama Posted May 18, 2008 Author Report Share Posted May 18, 2008 Maybe he has a secret vow and he's using the search button. close, but no cigar....dogs chewed up internet wire and then laptop had to go to geek squad for repairs....on my ex's now...... going back to the J/Y this week and will be pulling it asap, lol been working on the 240 a lot, pics will be up in a week or so. Quote Link to comment
yello620 Posted May 27, 2008 Report Share Posted May 27, 2008 So what happened to this guy?? Ex found you on her computer? Also, another mega-poster that i had forgotten about Cruzn620. Wonder where he went? Jason Quote Link to comment
datzenmike Posted May 27, 2008 Report Share Posted May 27, 2008 So what happened to this guy?? Ex found you on her computer? Ex's fat ass boy friend you mean. Also, another mega-poster that i had forgotten about Cruzn620. Wonder where he went?Jason Yeah no posts for just over a month Quote Link to comment
Llittle_Llama Posted May 27, 2008 Author Report Share Posted May 27, 2008 well went to the J/Y again yesterday adn no luck :( they just crushed a bunch last week and they went with them. going to the yard in montgomery here in a few days and will look there. Quote Link to comment
yello620 Posted May 27, 2008 Report Share Posted May 27, 2008 Your back!! I thought that you had already gotten a transmission. Jason Quote Link to comment
