Busta Nut Posted June 14, 2013 Author Report Share Posted June 14, 2013 Had to warranty my starter when I got back from Canby..... ...started clicking on my first pit stop..... .....don't get me started on Botched I mean Bosch products. Out with the new....in with the new......that's crap Quote Link to comment
Eagle_Adam Posted June 14, 2013 Report Share Posted June 14, 2013 why not a gear reduction starter from a late model Z? Quote Link to comment
Busta Nut Posted June 14, 2013 Author Report Share Posted June 14, 2013 Never even thought about it.... .....I've had this one for a while just never used it so it looks brand new..... Yes......I cheated my parts company.......sue me. Quote Link to comment
Busta Nut Posted June 16, 2013 Author Report Share Posted June 16, 2013 Well......everything was going pretty good till Thursday night. Ran up to Costco......in 5Teezy of course......and on the way back I was sitting at a light when out of the blue this intake/exhaust hiss began....idle got a little rough....my heart started to pound. Got it back to the shop....thank goodness......I don't think I have any engine damage cause it runs pretty smooth off idle.....noise just gets louder.... This same noise started to happen when I met up in Redding before Canby.....it wasn't as loud and I checked all my intake and exhaust bolts..... ....the bolt on #3 that holds the intake & exhaust was slightly loose....when I went to tighten it, it felt like it was gonna strip....I left it at it's tightest point and the noise went away..... till the other night when it came back with a vengeance.......listen: This is a pretty handy trick.....take your stethoscope and pull the hose off...you can add an extension of hose if it's too short..... Use the hose end to listen for changes in air pressure around your intake and exhaust port........found one.... I'll have to heli-coil that one before I drive her again......gonna be a few days before that happens.......said it before and I'll probably keep saying it for life...... ..........there ain't enough hours in a day. Quote Link to comment
tr8er Posted June 16, 2013 Report Share Posted June 16, 2013 ..........there ain't enough hours in a day. *confirmed. Quote Link to comment
skyblue Posted June 16, 2013 Report Share Posted June 16, 2013 Yikes! Well at keast you' were able to get it to the shop. Quote Link to comment
Busta Nut Posted June 16, 2013 Author Report Share Posted June 16, 2013 Ya..... Holy crap!!!................What the hell are you doing up @ 7am on a Sunday??!! :rofl: ........there must be something going on with the planets. Quote Link to comment
skyblue Posted June 16, 2013 Report Share Posted June 16, 2013 Haha. Woke up randomly. Checked ratsun. Went back to sleep. 2 Quote Link to comment
Ranman72 Posted June 16, 2013 Report Share Posted June 16, 2013 sounds like a major exhaust leak now get it heli-coiled Thanks for the trick with the stethoscope I never thought of that Quote Link to comment
Busta Nut Posted June 17, 2013 Author Report Share Posted June 17, 2013 I had some downtime at work this week......didn't want to rip the carbs off though cause I didn't want to push the car in and out all week.....I'll dod that this week. I decided to clean up some of my trim.....the hood piece and the one that goes under the grill. The bastard that owned this dime before me had sprayed EVERYTHING with shitty silver primer.......not even grey......I don't even know where to get silver primer. Anyways......on with the oics.... Jasco is some nasty shit.......don't get that shit on you.... Jasco took most of it off.........I also drill out the rivets to clean up the little brackets. ...then I started trying different chemicals we had on the shelf to try to rub the remaining paint off....... This seemed to work the best.......now I can see some flaws in the metal that need some polishing...... .......now for some polishing. Quote Link to comment
Busta Nut Posted June 19, 2013 Author Report Share Posted June 19, 2013 I decided to put studs in the head instead of using bolts.........better grip!! ....but first I had to heli-coil my stripped hole.. Little bit of grease to pick up all the shavings.... 1 Quote Link to comment
Busta Nut Posted June 19, 2013 Author Report Share Posted June 19, 2013 After finding that leak and putting those studs in it started missing on #2.........great. Quick compression test was good..... Put it back together and while it was running I put my hand over the horn #2............no vacuum?? Grabbed the stethoscope again and found a bigger leak..........daaaaaaaa there's a problem boss.... Quote Link to comment
Busta Nut Posted June 19, 2013 Author Report Share Posted June 19, 2013 No idea how this happens sitting at a stoplight.........cheap ass plastic I guess. I can't find the rest of it..... I still had the ones from the Z which were much better quality.... Quote Link to comment
Eagle_Adam Posted June 19, 2013 Report Share Posted June 19, 2013 bummer, at least you found it! Quote Link to comment
Busta Nut Posted June 19, 2013 Author Report Share Posted June 19, 2013 Now.....because I'm using the Z spacers the carbs hit the manifold before they're tight.... ......just one thing after another...... You can see the witness mark.... Quote Link to comment
Busta Nut Posted June 19, 2013 Author Report Share Posted June 19, 2013 bummer, at least you found it! Yes....and hopefully without too much damage. Quote Link to comment
Busta Nut Posted June 19, 2013 Author Report Share Posted June 19, 2013 Let the grinding commence!! Now we have juuuust enough clearance.... 1 Quote Link to comment
Eagle_Adam Posted June 19, 2013 Report Share Posted June 19, 2013 custom touches yo! Quote Link to comment
qwk_snd Posted June 19, 2013 Report Share Posted June 19, 2013 Just read this entire thread... it has further inspired me to get back to work on my dime... awesome car, build, and thread! Thanks! Quote Link to comment
skyblue Posted June 19, 2013 Report Share Posted June 19, 2013 Oh woa! Good thing that intake is alimnium. Easier to carve than cast iron. Now I'll take it for a spin. Lol. Quote Link to comment
Busta Nut Posted June 19, 2013 Author Report Share Posted June 19, 2013 Just read this entire thread... it has further inspired me to get back to work on my dime... awesome car, build, and thread! Thanks! Thanks!! Quote Link to comment
r0p0doe Posted June 19, 2013 Report Share Posted June 19, 2013 Now.....because I'm using the Z spacers the carbs hit the manifold before they're tight.... ......just one thing after another...... You can see the witness mark.... Had that same issue i just removed all that stuff... Quote Link to comment
Busta Nut Posted June 19, 2013 Author Report Share Posted June 19, 2013 Had that same issue i just removed all that stuff... Didn't know that was an option.... Quote Link to comment
r0p0doe Posted June 19, 2013 Report Share Posted June 19, 2013 Didn't know that was an option.... Only solution I thought of at the time, didnt affect performance in any way Quote Link to comment
