Llittle_Llama Posted April 19, 2008 Report Share Posted April 19, 2008 i cannot seem to figure it out, lol.... i want to remove it and and install a normal switch, i am rewiring the whole headlight and taillight assembly and am replacing EVERYTHING!!! also, i removed the A/C system from the truck when i first bought it and finally removed the part that goes under the dash, just toss it or is it worth anything on here? Quote Link to comment
]2eDeYe Posted April 19, 2008 Report Share Posted April 19, 2008 Hate to say it....but.... Search!!! Or...just grab the shaft (hehe) and push the knob (hehe) in and twist it..(tehehe) :D Quote Link to comment
BACARDI_DWB Posted April 19, 2008 Report Share Posted April 19, 2008 if you cant remove a switch, then are you really capable of rewiring the headlights and tail lights? Quote Link to comment
Llittle_Llama Posted April 20, 2008 Author Report Share Posted April 20, 2008 im trying not to break it.....i am a blackhawk crewchief.......i work on turbine engines all day, and a knob is killing me!!! Quote Link to comment
BACARDI_DWB Posted April 20, 2008 Report Share Posted April 20, 2008 hint, look at the underside of the knob, here is another hint, you will need a small screwdriver Quote Link to comment
datzenmike Posted April 20, 2008 Report Share Posted April 20, 2008 Needle nose pliers...(hint) Quote Link to comment
]2eDeYe Posted April 20, 2008 Report Share Posted April 20, 2008 hint, look at the underside of the knob, here is another hint, you will need a small screwdriver No screw on the 620 knob ;) Quote Link to comment
Llittle_Llama Posted April 20, 2008 Author Report Share Posted April 20, 2008 god i feel retarded, lol....i will give it another go in the morning.....needle nose pliers huh? Quote Link to comment
nismopu Posted April 20, 2008 Report Share Posted April 20, 2008 I believe you need the needle nose pliers to hold the shaft so you can push and twist the knob off. Its baffled alot of people on here there first time as well. Dont let em fool ya into thinking they didn't struggle with it. 1 Quote Link to comment
Llittle_Llama Posted April 20, 2008 Author Report Share Posted April 20, 2008 also, i removed the A/C system from the truck when i first bought it and finally removed the part that goes under the dash, just toss it or is it worth anything on here? now for the second part..... Quote Link to comment
]2eDeYe Posted April 20, 2008 Report Share Posted April 20, 2008 I believe you need the needle nose pliers to hold the shaft so you can push and twist the knob off. Its baffled alot of people on here there first time as well. Dont let em fool ya into thinking they didn't struggle with it. Yep :D Quote Link to comment
moparvwfreak Posted April 20, 2008 Report Share Posted April 20, 2008 luckily i didn't have to many problems when i pulled my dash apart. now i did almost break the wiper switch knob trying to get it off as i didn't realize how ti came off untill AFTER i ripped it off. so dont feel bad... Quote Link to comment
Llittle_Llama Posted April 20, 2008 Author Report Share Posted April 20, 2008 do you still need it mopar? and just hold it with pliers and twist the knob off? i assume counterclockwise..... Quote Link to comment
datzenmike Posted April 20, 2008 Report Share Posted April 20, 2008 Hold and push down and twist. It might twist in either direction, but be sure to have the lettering the right way up when you put it back on. Bacardi is thinking of the heater controls. The '55 Chev you had to reach under the dash and over the switch and push a tiny spring loaded button and the knob and shaft would pull right out. I had a '57 too, and I think they were the same. Quote Link to comment
Llittle_Llama Posted April 21, 2008 Author Report Share Posted April 21, 2008 ok, that was easy, now what do i do with them, are they worth anything? i have all three knobs, the headlight, wiper, and dimmer knob........ Quote Link to comment
moparvwfreak Posted April 21, 2008 Report Share Posted April 21, 2008 how much for hte light switch with knob? i am interested in that. Quote Link to comment
Llittle_Llama Posted April 21, 2008 Author Report Share Posted April 21, 2008 well it's connected to some other ting thats connector to the wiper switch, lol.....thats why i was wondering what to do with it? im just going to run a switch straight to the wiper motor and the battery (fuse also) and do the same with the running lights and headlights..... Quote Link to comment
hang_510 Posted April 21, 2008 Report Share Posted April 21, 2008 you need the needle nose pliers to hold the shaft :lol: Quote Link to comment
Jester Posted April 21, 2008 Report Share Posted April 21, 2008 also, i removed the A/C system from the truck when i first bought it and finally removed the part that goes under the dash, just toss it or is it worth anything on here? What do you want for the underdash A/C unit? Quote Link to comment
moparvwfreak Posted April 21, 2008 Report Share Posted April 21, 2008 well it's connected to some other ting thats connector to the wiper switch, lol.....thats why i was wondering what to do with it? im just going to run a switch straight to the wiper motor and the battery (fuse also) and do the same with the running lights and headlights..... thats cool. spare parts are not a bad thing. switches at my local pull-a-part run bout $5 a pop if ya dont pocket them. i am interested in both. Quote Link to comment
Llittle_Llama Posted April 21, 2008 Author Report Share Posted April 21, 2008 What do you want for the underdash A/C unit? i dont know, shipping will be about 30 bucks i assume, it all works, and is in pretty good condition, lol. i will post pics tomorrow..... Quote Link to comment
datzenmike Posted April 21, 2008 Report Share Posted April 21, 2008 well it's connected to some other ting thats connector to the wiper switch, lol.....thats why i was wondering what to do with it? im just going to run a switch straight to the wiper motor and the battery (fuse also) and do the same with the running lights and headlights..... The ting that's connected to it and the wiper is probably a fiber-optic cable for transmitting light to illuminate the switch knob at night. Quote Link to comment
Llittle_Llama Posted April 21, 2008 Author Report Share Posted April 21, 2008 sounds about right...the ting goes to some little metal can ting.....pics tomorrow.... Quote Link to comment
kiznook Posted April 21, 2008 Report Share Posted April 21, 2008 you do realize that you now have at least (havent seen everything yet) 2 threads about taking your dash apart. I thought we were working on the multiple thread thing? Quote Link to comment
