daltonryan620 Posted October 3, 2012 Report Share Posted October 3, 2012 i wanted to get a locked diff to limit chances of the welds snapping and turning my diff housing into a grenade... i will be drifting at shows due to the fact its a full oem resto project minus the motor and tranny. but im swapping in the stock shifter to the ka tranny if possible if not im getting one similar to it that can accept the stock knob. i want it to look bone stock but be able to perform. Quote Link to comment
Yrag Posted February 5, 2014 Report Share Posted February 5, 2014 I am sorry for not replying sooner. I am still a newby to ratsun. I just pulled my detroit locker from my truck. It is a direct bolt in. The drop outis an aluminim carrier with a detroit locker with 4.625 ring and pinion mounted. The gears are noisy. They were not set up correct. The carrier and locker are fine. It is a 29 spline locker which fits my 1976 620 truck. My research says it is an Detriot #187S-21A or a NISMO #M-99996-T3011. I have read threads that say this fits the H190 diff. Quote Link to comment
Yrag Posted February 5, 2014 Report Share Posted February 5, 2014 They are only bad if you dont know how to drive one!!! Quote Link to comment
datzenmike Posted February 5, 2014 Report Share Posted February 5, 2014 A welded diff? It's only a matter of time before you get in trouble with one. Knowing they are unpredictable won't save you from one. If you have had a few close calls with one I guarantee you wouldn't have with a proper LSD. You weren't skillful, only lucky. 1 Quote Link to comment
MikeRL411 Posted February 5, 2014 Report Share Posted February 5, 2014 A welded diff? It's only a matter of time before you get in trouble with one. Knowing they are unpredictable won't save you from one. If you have had a few close calls with one I guarantee you wouldn't have with a proper LSD. You weren't skillful, only lucky. Amen to that! Quote Link to comment
ggzilla Posted February 5, 2014 Report Share Posted February 5, 2014 An H190 Detroit Locker is not a welded differential. Quote Link to comment
EricJB Posted February 5, 2014 Report Share Posted February 5, 2014 Correct. And the Summit racing link is known as a spool, not a locker. LSD, Positraction, suregrip, ect, are for street driven vehicles. Spools, not so much. Break an axle with a locked diff and you will be sent quickly one direction or the other. I have run welded diffs and spools on the street. But I'm stupid and crazy. If you find where you can get a spool for an H190 diff, please PM me. Quote Link to comment
banzai510(hainz) Posted February 6, 2014 Report Share Posted February 6, 2014 look under phantom grip for a cheap lunchbox locker phantomgrip.com has datsuns listed. call it good These lunch box lockers might be ok on a solid axle diff. On the IRS these I hear are not that great but might be better than welding so at least you can make tight turns it will rachet/click let us know if these are anygood. with is being wet around here be helpful to have a extra wheel to push Quote Link to comment
Zendar Posted February 28, 2014 Report Share Posted February 28, 2014 H190 4.375 LSD ^_^ Quote Link to comment
ohmrchristopher Posted March 8, 2014 Report Share Posted March 8, 2014 I have a welded 1973 620 rear axel I'll trade anyone for. I would rather have a LSD or E-Locker but I guess thats not an option anymore?? Quote Link to comment
datzenmike Posted March 8, 2014 Report Share Posted March 8, 2014 It was only after market for the 620. The Roadster had an H-190 LSD but it had 23 splines for cars. Quote Link to comment
ggzilla Posted March 8, 2014 Report Share Posted March 8, 2014 You can buy a new H233 LSD for $500. Nissan wants $1500 for the H190 factory LSD. Quote Link to comment
datzenmike Posted March 8, 2014 Report Share Posted March 8, 2014 I have a 4.625 H233 LSD diff sitting out back. Probably weighs a hundred pounds. Quote Link to comment
ohmrchristopher Posted March 13, 2014 Report Share Posted March 13, 2014 PM sent Mike. Quote Link to comment
