510 Aluminum Radiators from Datsun Parts LLC
Datsun Parts
  • Replies 44
OK here you go. Looks good, fits right and cools excellent.....off to production! I had to notch a 10" fan slightly to clear the pulley. We had to use a flex hose on the bottom and a cut to fit one for the top as the local Napa did not have OEM 510 hoses in stock. However still looks like stock hoses will work just fine.
I hope I do not get too much grief from the manufacture as John would not let me take it back out to return it as I said I would.....actually I did not want to anyway!
Looks very clean!!!!
  • 1 month later...
  • 2 months later...
I know some of you were wondering about the bottom hose and the alt. Well it turns out I had a bracket form an L16 on a L20 block. I replaced the alt bracket with the right one and I have an inch or so clearence on the bottom hose.
It did rub thru my bottom hose and started leaking so good eye Hainz it was too close.
  • 2 months later...
  • 2 months later...
Um, alternator to radiator outlet clearance is really tight, but does not hit. I just worked on a car with one and had to replace the lower rad house (not because of any rubbing, but age).
I think they are sold on Ebay...
and does he have his own website?
  • 7 months later...
