AtomChurch Posted March 21, 2008 Report Share Posted March 21, 2008 well my headlights come on but only the passenger side light is bright and all the other three are dim. then when i turn on the brights the the passenger light stays on and the passenger bright gets really bright and the other lights are dim. I bought a new fuse box today [used] and used that one as well but when I use that I get the exact opposite reaction. I have a feeling its a ground wire somewhere but where is the ground for the headlights? Quote Link to comment
DanielC Posted March 21, 2008 Report Share Posted March 21, 2008 I have a wiring diagram for a Datsun Sedan, or Station Wagon with a manual transmission. My manual is for 1970, and 1971. They appear to be switched at the ground. Consider that possibility when you are troubleshooting your lights. Power from the fuse block goes to all four headlights. The headlight relay controls which set of lamps, or filaments in the lamps are then connected to the light switch, and after the light switch, power is allowed to return to ground. look at the wires on the light switch. A green wire with a blue stripe, and a green wire with a white stripe are for the parking lights, and side marker lights. The other two wires are red, with a yellow stripe, and black. The red/yellow wire goes to the headlight relay, the black wire goes to ground, or as it is labled in the diagram "body earth". The coil for the headlight relay gets its power from the parking light circuit, and is grounded by the turn signal switch. One set of contacts in the relay goes to the main beam headlights, and the other set of contacts goes to the low beam headlights Quote Link to comment
DISLEXICDIME Posted March 21, 2008 Report Share Posted March 21, 2008 mine did that when the screw that grounds / holds the turn singnal switch to the colum wasn't screwed in all the way Quote Link to comment
banzai510(hainz) Posted March 21, 2008 Report Share Posted March 21, 2008 ck the ground wire by the voltage regulator also. Quote Link to comment
datzenmike Posted March 21, 2008 Report Share Posted March 21, 2008 Check the two 10 amp headlight fuses. BTW would be easier if I didn't have to look up your profile to find out we talking about a 510's head lights and not a 620's. Quote Link to comment
Guest 510kamikazifreak Posted March 21, 2008 Report Share Posted March 21, 2008 Like Mike said, Check the headlight fuses, Make sure contacts are clean,wiggle the fuses to see if anything happens. Quote Link to comment
banzai510(hainz) Posted March 21, 2008 Report Share Posted March 21, 2008 I would also disconnected the plug that goes in to the headlight relays and plug it back IN. I assume its just corrossion on some contacks somewhere. Quote Link to comment
Icehouse Posted March 21, 2008 Report Share Posted March 21, 2008 What are the wire colors at the headlight brite relay? It helps to know what harness your car has. 510's are a pain since there are 3 different headlight systems. Sounds like it could be a dirty relay, when was the car last on the road? It may have some electolisis in the relay contacts. Its odd that it switches from one side to the other when you swap fuse boxes.... I fixed so many I should have this shit memorized! Quote Link to comment
]2eDeYe Posted March 21, 2008 Report Share Posted March 21, 2008 I fixed so many I should have this shit memorized! ...and you don't because.....? :D Quote Link to comment
