Shifter bushings?
DatDoug
  • Replies 20
There's a Dodge door hinge bushing replacement kit that will work better than the original ones. They look something like these:
http://i138.photobucket.com/albums/q251/datzenmike/DSC01168.jpg[/img]"]DSC01168.jpg
I must have got the wrong no. because they didn't fit:
http://i138.photobucket.com/albums/q251/datzenmike/DSC01195.jpg[/img]"]DSC01195.jpg
So I used a dremel with a cutting disc and removed a small chunk and got them to work:
http://i138.photobucket.com/albums/q251/datzenmike/Copyoftransshifterbushing.jpg[/img]"]Copyoftransshifterbushing.jpg
Maybe someone will see this and can give the right number.
I want new bush...ings on my shifter.:lol:
I'm tired of the sloppy side to side action.:lol::lol:
Yeah I have them on my Dime and they make a big difference. Nothing like a nice tite shift!:D
Ebay sometimes has the original plastic ones...they also have brass ones but don't buy them cuz they were too thick and I had to shave them with a file...but yeah Watch ebay....
http://cgi.ebay.com/ebaymotors/Datsun-510-B110-B210-620-720-810-Shifter-Bushings-NOS_W0QQcmdZViewItemQQcategoryZ46101QQihZ012QQitemZ220210139841QQrdZ1QQsspagenameZWDVW
They are called 'shifter bushings' and you can get them from your local Nissan dealership for around $6
exactly! only I think they are $7.:D
The inner diameter should be 9mm or 0.353", cant get the new bushing out to measure but it would have to fit the hole in the shifter. The kit I got was for the Dodge/Van/Truck '84-'91 upper/lower door hinge bushing kit HELP # 238388 But they were too big diameter so I trimmed to fit. Someone on here gave a different kit # and the dimensions matched my altered ones.
Found the post thanx Jason:http://forum.ratsun.net/showthread.php?t=2297&highlight=door+hinge+shifter+bushings
The little plastic sleeves/bushings that slip into the bottom of the shifter that keeps it tite. What the fuck are they called and where can you get some??:blink:
From the man who cannot have a 4/5 speed in his 610, try this guy:
http://cgi.ebay.com/DATSUN-NISSAN-240Z-280Z-280ZX-BRASS-SHIFTER-BUSHINGS_W0QQitemZ220220408523QQihZ012QQcategoryZ33736QQtcZphotoQQcmdZViewItem
I got the bump steer spacers from him, and the product was top notch. I've directed a few other people his way. I know the price is a bit much, but it beats having to explain yourself to some snot nosed kid at the dealership parts counter.
http://www.nissanparts.cc/cart/?pn=32849-H1010
or
Chrysler Door Hinge kit
38377 under HELP brand sold thru Schucks
rememebr the earlier trucks and all the 510/521s will the 4 speeds use a diffenernt linkage system. Mostly the Ears on the end waer and spread out.
You can shim it with washers or pull the pin out(E clip) and put a grade 8 bolt and sqeeze it together and it will take some slop out. Thats about it. Just the way it is.
  • 3 weeks later...
or
Hainz (or anyone) just so I am clear, the HELP kit listed above won't work for a stock 71 521 4 speed? Nissan shifter bushings also will not fix it. And a grade 8 bolt is the way to go? (My memory tells me it is the ears that are sloppy on my shifter. So I am guessing this can't be fixed with bushings.)
Additionally, I can't get the shift knob off of the shifter. (putting on a new boot) I am about to resort to visegrips! Sounds like an excuse to get or make a custom shiftknob!
