cheetah79857985 Posted November 7, 2010 Report Share Posted November 7, 2010 This is an automatic 1977 620 series Datsun Pickup for sale $1000.00. The body paint, brakes, tires, and shocks were replaced in 2005. A new Weber carburetor was installed in 2006. The wiring under the hood, the coil, and spark plug cables are were replaced in the summer of 2007. Odometer is at 800 (hundred, not thousand). It just recently rolled over and has probably rolled over once before. So at least 100k miles, maybe 200k. An engine flush was performed at the 88,000 mile mark, in 2006. It gets 18-20 miles to the gallon. The truck is registered and insured. Above all else, I am not a mechanic, and this truck is being sold as is. Any sale will be final and performed with written and signed agreement by both party’s. Links to pictures are provided at the bottom of this post. The next post will host the pictures themselves. Located in Creswell, OR, 20 minutes outside of Eugene/Springfield. Things of note- There is start button under the dash that goes directly to the starter. The key ignition will sometimes not start the truck, so I had the button installed to bypass this problem. The button has never failed to start the truck. The start button does not work without a key, so, theft from this source is not an issue. There are three keys to this truck; one for the driver door, one for the passenger door, and one for the ignition. The rearview mirror is not the original and I do not have the original. The speedometer is fast by approximately ten MPH. If it says 65, you’re going 55. There is no tachometer. The seat has a large gash on the driver’s side. Opportunities that can be worked on- The gas tank can not currently be filled to it‘s max. The over-pressure caused by a gas pump's automatic shutoff causes one of two things; more commonly, a small spurt of fuel sprays out of the line (less than a capful). Less common, a larger amount (my guess is 1-2 gallons) spills out. This problem is avoided by never filling the gas tank past 3/4 full, or 8 gallons if empty/near empty. The engine will “chug” and, sometimes, die while the car is stopped and in gear. It does not do this while in neutral or park, nor does it happen while in motion. The running/tail lights are currently hotwired to the battery. There are two pull switches in the cab, one for each set of lights. The second pull switch is in place of the cigarette lighter, as that never worked and I never needed it. I still own the cigarette lighter mechanism. The ignition is loose, which sometimes causes the grinding noise associated with turning the key with the engine already on. The cab light and washer fluid does not work. The engine-temp gauge does not work. http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184116.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184215.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184251.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184310.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184320.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184333.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184352.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184422.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184432.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184441.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184451.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184503.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184552.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184617.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184640.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184702.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184718.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184730.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184909.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184917.jpg Link to comment
FoxyRoadster Posted November 7, 2010 Report Share Posted November 7, 2010 where are you located? Link to comment
cheetah79857985 Posted November 7, 2010 Author Report Share Posted November 7, 2010 Sorry. Creswell, OR, 20 minutes outside of Eugene/Springfield. Link to comment
danfiveten Posted November 7, 2010 Report Share Posted November 7, 2010 God i want. Just for the fact that its a auto and my wife could actually drive it.. Very nice. Link to comment
cheetah79857985 Posted November 7, 2010 Author Report Share Posted November 7, 2010 I am not opposed to traveling, especially if you are willing to meet in the middle. I would only require a small, non-refundable, deposit in the case we meet and you decide you do not want to purchase the truck. Link to comment
datzenmike Posted November 7, 2010 Report Share Posted November 7, 2010 That truck looks too good to have all that stupid shit wrong with it. Damn. Ignition switch Leaking gas tank No tail lights No washer No cab light Temp gauge not working 3 keys? Does not idle reliably. Worth $1K just on looks. Someone take it away from him. Deserves better. Link to comment
Big Dave Posted November 7, 2010 Report Share Posted November 7, 2010 Too bad I already agreed to buy another to have a 2nd automatic Datsun would be way cool!! Please someone buy it before I do lol Link to comment
Z-train Posted November 7, 2010 Report Share Posted November 7, 2010 Someone take it away from him. Deserves better. For less. Link to comment
datzenmike Posted November 7, 2010 Report Share Posted November 7, 2010 (cheap prick) :D I sometimes forget the quality of Arizona vehicles. You probably see better everyday, Bill. Link to comment
Nas Posted November 8, 2010 Report Share Posted November 8, 2010 That truck looks too good to have all that stupid shit wrong with it. Damn. Ignition switch Leaking gas tank No tail lights No washer No cab light Temp gauge not working 3 keys? Does not idle reliably. Worth $1K just on looks. Someone take it away from him. Deserves better. Seems like a harsh response to a for sale ad. At least he's being upfront about the condition of the truck. 1 Link to comment
datzenmike Posted November 8, 2010 Report Share Posted November 8, 2010 Not at all, these are easy to fix, I'm wondering why they aren't on such a nice looking truck. Push button start and switches for running lights now that's harsh. Link to comment
Guest kamakazi620 Posted November 8, 2010 Report Share Posted November 8, 2010 Not at all, these are easy to fix, I'm wondering why they aren't on such a nice looking truck. Push button start and switches for running lights now that's harsh. Very TRUE!!!!! NICE TRUCK for the money,EASY fixes for a RATSUNER,SOMEONE BUY THIS!!!!!!! GLWS Link to comment
cheetah79857985 Posted November 14, 2010 Author Report Share Posted November 14, 2010 Anyone considering buying? Link to comment
Syxxstring Posted November 15, 2010 Report Share Posted November 15, 2010 I'd love to if I can figure out how to get it to Las Vegas. Link to comment
datsunaholic Posted November 15, 2010 Report Share Posted November 15, 2010 The "leaking gas tank" is usually an easy fix, one of the return hoses (generally the ones to the vapor tank) has rotted out. Every '76 I've owned had that problem. Replace the hose, and the problem goes away. The temp gauge is usually just a corroded connector. The washer and dome light, well, I think I've had one 620 where those worked. I have yet to have a working underhood light. The taillights, that's scary. Only reason they get bypassed is they keep blowing fuses, so now they're hard-wired in, probably straight to the battery with no fuse, since the short is intermittent. Pretty soon it'll become non-intermittent and catch fire. Most of the time it's the front marker lights, where the wire runs through the body. The rubber grommet has rotted out, the wires rubbed the bare rusty metal, causing a short. Replacing the grommet and fixing the wire usually fixes the short. Not sure why the carb is installed backwards, unless that's one of those oddball Weber DFT carbs. Link to comment
cheetah79857985 Posted November 16, 2010 Author Report Share Posted November 16, 2010 Well, I certainly appreciate the tips for fixing those issues. I can probably fix the gas hose and temp connector myself, so I'll look into it to see if that's the case. Thank you. Link to comment
cheetah79857985 Posted May 7, 2011 Author Report Share Posted May 7, 2011 This is an automatic 1977 620 series Datsun Pickup for sale $1000.00. The body paint, brakes, tires, and shocks were replaced in 2005. A new Weber carburetor was installed in 2006. The wiring under the hood, the coil, and spark plug cables are were replaced in the summer of 2007. Odometer is at 800 (hundred, not thousand). It just recently rolled over and has probably rolled over once before. So at least 100k miles, maybe 200k. An engine flush was performed at the 88,000 mile mark, in 2006. It gets 18-20 miles to the gallon. The truck is registered and insured. Above all else, I am not a mechanic, and this truck is being sold as is. Any sale will be final and performed with written and signed agreement by both party’s. Links to pictures are provided at the bottom of this post. The next post will host the pictures themselves. Located in Creswell, OR, 20 minutes outside of Eugene/Springfield. NADA lists this vehicle as having a value of $1425 in a drivable condition. This truck is drivable, though it requires "a special touch" due to the engine chugging mentioned below. I'm tired of keeping this truck around. I only drive it once, maybe twice a month. If it does not sell this summer, for the $1000, I will be scrapping it. Things of note- There is start button under the dash that goes directly to the starter. The key ignition will sometimes not start the truck, so I had the button installed to bypass this problem. The button has never failed to start the truck. The start button does not work without a key, so, theft from this source is not an issue. There are three keys to this truck; one for the driver door, one for the passenger door, and one for the ignition. The rearview mirror is not the original and I do not have the original. The speedometer is fast by approximately ten MPH. If it says 65, you’re going 55. There is no tachometer. The seat has a large gash on the driver’s side. Opportunities that can be worked on- Once in awhile, the over-pressure caused by a gas pump's automatic shutoff causes a small spurt of fuel to spray out of the line (less than a capful). Once, in the entire lifetime I owned the truck (six years), 1-2 gallons spilled out. As this only happened once, I do not know if it is related to the same problem. Either way, I usually only put in 8 gallons to avoid the problem. The engine will “chug” and, sometimes, die while the car is stopped and in gear. It does not do this while in neutral or park, nor does it happen while in motion. Numerous gas-pedal pumps (literally around 50) are needed to get the truck started, and a solid warm-up time (I like to give it 5 minutes) is needed so it runs, though it wasn't aleways like that and this is probably due to the once or twice a month driving. The running/tail lights are currently hotwired to the battery. There are two pull switches in the cab, one for each set of lights. The second pull switch is in place of the cigarette lighter, as that never worked and I never needed it. I still own the cigarette lighter mechanism. The cab light and washer fluid does not work. The engine-temp gauge does not work. http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184116.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184215.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184251.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184310.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184320.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184333.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184352.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184422.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184432.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184441.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184451.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184503.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184552.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184617.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184640.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184702.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184718.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184730.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184909.jpg http://img.photobucket.com/albums/v483/cheetah7985/2009-08-20184917.jpg Link to comment
cheetah79857985 Posted May 7, 2011 Author Report Share Posted May 7, 2011 The seat cover-cloth is no longer there. Link to comment
Siqx20 Posted May 7, 2011 Report Share Posted May 7, 2011 1k? I would pick it up if I had it. For that price the truck should have no problem selling. Issues and all. Glws Link to comment
Jester Posted May 7, 2011 Report Share Posted May 7, 2011 I am interested in your truck. Could you please PM me your info so I can come look at it? SERIOUSLY! Jes Link to comment
datzenmike Posted May 7, 2011 Report Share Posted May 7, 2011 This is a double post and has been for sale here last November. I'll merge them to keep all info in one. Link to comment
Naboobo2000 Posted May 9, 2011 Report Share Posted May 9, 2011 Is this still for sell? Link to comment
Jester Posted May 9, 2011 Report Share Posted May 9, 2011 As far as I know. I wanted it for my daughter, but, she wants a four seater. Link to comment
cheetah79857985 Posted May 9, 2011 Author Report Share Posted May 9, 2011 Yes it is. As long as you aren't trying to scam me with wire transfers and PayPals offering more than I am asking, lol. Link to comment
