Wow man. You don't fuck around. Loving the amount of pics taken during your work. Wish my ass would take more pics of my car's progress.
Share this post
Link to post
I was able to get the rear diff mounted up to test fitment of the brackets. It's definitely going to need some adjustable links, but things look good otherwise:
Started to play with the rear fenders just to see what result I could get. I didn't spend too much time on them. I was more interested in finding the location of heavily rusted spots. The rubber edge trim is really a pain when it comes to this. I didn't roll the rear fender lips b/c if I end up putting flares on them, it would get cut anyway.
Driver-side:
Passenger-side:
Share this post
Link to post
I took a break from the body work to start touching the engine harness. I originally had two engine harnesses (both FWD CA18DE Pulsar harnesses), but I cannibalized one to get good connectors. The other I decided to map out and labeled each connector. Then in a genius stroke, I cut the harness in half, save for the MAF and CAS shielded cables. Did forget to label where I cut each wire on both sides of the cut though, so I had to label each ECU pin and then find the corresponding plugs. In the end it worked out though. I was able to eliminate roughly 5' of overall wiring on each strand and routed everything so it's not too obvious across the engine.
These are a few of the free wires in the bay (others are mostly ground wires I haven't trimmed out or those running to the ingition switch or gauges). These go to the fuel pump relay/efi relay/efi safety relay and I haven't decided on a location for those just yet.
These are the wires that I haven't hooked up from the ECU, either b/c they're components are being eliminated, they're grounds that I still have to run (2 or 3 of the wires), or the components will be mounted right beside the ECU/in an undetermined, such as the efi relay/safety relay .
This is all the wiring that I have stored in case I need some extra length down the road, or extra plugs.
I also started working on how I'm going to finalize the in car wiring. I picked up an S2000 Start Button and found a nice place to mount it.
Share this post
Link to post
I also took the time to weld up the three small holes on the fender. I may have to do some small welds to fill in some pin holes that remain, but for now they're semi-fixed.
Share this post
Link to post
Amazing work! Keep the pics coming. Loving this!
Share this post
Link to post
To:
The machine shop still has a couple hours of machining to do on it to clean up the edges and they said they're going to polish it up. They still have to match the taper on the ITB bores as well. The figure '8' piece on the head flange had to be redesigned due to restrictions caused by the type of CNC machine they have. They're going to make a 1/2"-3/4" thick spacer flange that will have those curves included.
Share this post
Link to post
Awesome! Keep up the good work!
Share this post
Link to post
Well, I've been nervous about actually sizing it up against the head. I've only been able to test fitment by printing my workflow images from AutoCad/Inventor. Seems everything is going to be okay though:
It's not seated completely against the head in the images. I need to clearance the bolt holes a tad bit. Good thing is that all the cylinder ports and the coolant passage line up as I intended them to.
Share this post
Link to post
I had the bore milled close to the Silvertop ITB bore. It's actually a little undersized. I planned on using the BT ITBs from the get go, but the ST bore was easier to design. The BT bore will solve any alignment issues that are present.
Share this post
Link to post
Finally picked up some new shoes for the front. Now I can start working on the rear axle. I guess the next purchase will be a set of axle shafts for the 8.8 so I can start working on getting the rear wheels and tires.
Not at full lock, but I seem to have quite a bit of space to spare. Should be more work on the fenders than anything else.
Share this post
Link to post
sweeeeet i cant wait to see this thing done im hoping you keep it white i have a thing for black and white 86's
Share this post
Link to post
this build is the only reason i have an account here haha. im going to be doing the same thing and i found this. i cant wait to see it done. would love to see a video of it started once you get it running. do u have the turbo relocator from flipside customs?
Share this post
Link to post
Holy schweet ass build batman! Just found this thread and damn! Major props on all the work and that custom intake is sexual :wub: I'm currently building up a buddies 81' Starlet and will be using alot of AE86 parts as well as that ford diff. Older Yota's are almost as cool as Datsuns :P
Share this post
Link to post
These are some well spent 30 minutes hecking this thread.................HOLY SHIT!! wish I had the $$. I really like the "artistic" type of pics, you even take the time for that haha. Keep it up!!
Share this post
Link to post
Nothing recent. The heat in San Antonio has been horrible. My garage has a west facing door, so working on the car at 4-6PM in 105-110* heat hasn't been working. Currently I've been working on getting the rear axles ordered so I can get the diff built and the rear wheels ordered. I think I'd have a more flexible work space if I could get the car on wheel dollies. Plus I can finish the brake system with lines and rear calipers and be able to pull the car in and out of the garage if needed.
Share this post
Link to post
I've been talking with the guys in the weld shop at work. They had someone dump a bunch of stainless steel containers that used to hold chemicals for working on the planes. They asked if I could use any of them for personal use:
Fuel Cell
Surge Tank
They're going to start work on them this week. The fuel cell will be right around 15 gallons...maybe a touch under, and the surge tank should hold another 5 gallons (maybe a bit more after I have it reshaped to drain to the engine feed fitting.
I'm hoping the machine shop can get my ITB manifold finished too. They've been busy machining parts for the aircraft so my part had to be put on hold. I'm keeping my fingers crossed.
Share this post
Link to post
