Roger Posted April 4, 2011 Report Share Posted April 4, 2011 Never had to deal with dual points before. What's it all about? Can I get my with one set? Also my 521 has the original rebuidable fuel pump. Can I get a rebuilding kit somewhere? Roger( My 521 is still in transit from Oregon!) Quote Link to comment
INDY510 Posted April 4, 2011 Report Share Posted April 4, 2011 -Also my 521 has the original rebuidable fuel pump. Can I get a rebuilding kit somewhere? . What year is the 521???? .......... oh,,, and what motor does it have???? .......... :lol: Quote Link to comment
izzo Posted April 4, 2011 Report Share Posted April 4, 2011 Not sure where to get the rebuild kits from, i heard about it before. Keep searching, you may find something. Datzenmike might know, check out 510realm, and dime quarterly also for some info on them. The dual points is a joke really, the second set of points don't work unless the primary fails. Quote Link to comment
datsunaholic Posted April 4, 2011 Report Share Posted April 4, 2011 The dual points is a joke really, the second set of points don't work unless the primary fails. No, not really. When the primary set fails you pretty much are dead in the water. The secondaries only operate under a specific set of circumstances, with a bunch of switches needing to be "closed" before they kick in. The switches vary by year and model, but usually consist of a throttle switch, clutch switch, transmission switch, and temperature switch. So it has to be warmed up, in a particular gear, with the clutch engaged (pedal "up"), and not with the throttle to the floor, to engage the second set of points. Unfortunately, the single-point points don't fit in the dual-point distributor. Quote Link to comment
izzo Posted April 4, 2011 Report Share Posted April 4, 2011 Wow good to know, thanks Doug. I was always told that the secondaries don't do anything unless the first ones fail (even by auto places) I don't run points in my cars, but now at least i know what they do :D Quote Link to comment
datsunaholic Posted April 4, 2011 Report Share Posted April 4, 2011 Datsun Dual-points were part of the emissions system. Aftermarket dual-points and some US-type were done for other reasons. Quote Link to comment
datzenmike Posted April 4, 2011 Report Share Posted April 4, 2011 First the Hitachi fuel pump hardly ever breaks down or wears out. Just last year I fired up a 710 that had been sitting 8 years since the owner died and drove it 100 miles home and to Canby and back that summer. That pump is 37 years old now. There's a better chance your fuel filter is plugged or partly plugged, fuel line is plugged or partly plugged or pinched by a rock, carb float stuck or needle valve stuck or plugged, one or more jet plugged. What makes you think it's the pump? Nissan fuel pump diaphragm # 17053 21017 from the dealer about $10 Quote Link to comment
68Datsun510 Posted April 5, 2011 Report Share Posted April 5, 2011 Datzenmike, will that diaphragm work on a J13 fuel pump as well? Quote Link to comment
datzenmike Posted April 5, 2011 Report Share Posted April 5, 2011 Sorry I thought it was for an L16... There were two different makes of J13 fuel pumps: Koyosan Denki and Showa Seiki, both use the same diaphragm # 17053 32200 Quote Link to comment
Roger Posted April 5, 2011 Author Report Share Posted April 5, 2011 So , can i just put in primary points and leave the secondary point place empty? My fuel pump is good, but I usually see where people replace it. Just want to rebuild it while the going is good. Quote Link to comment
banzai510(hainz) Posted April 5, 2011 Report Share Posted April 5, 2011 So , can i just put in primary points and leave the secondary point place empty? Yes just pull the 2ndary wire. Quote Link to comment
DanielC Posted April 5, 2011 Report Share Posted April 5, 2011 If the fuel pump is working, leave it alone. It should put out about 2.5 to 3.5 PSI, and flow about a liter a minute. If it fails the flow test, do it again, drawing from a container of gas hooked up directly to the pump. Do not go looking at the fuel pump for problems when the gas lines, or tank pickup are bad Quote Link to comment
datzenmike Posted April 6, 2011 Report Share Posted April 6, 2011 My fuel pump is good, but I usually see where people replace it. Just want to rebuild it while the going is good. I don't know of anyone replacing a working pump. If working leave it alone. In your Datsun travels you will come across them attached to a head that you buy or on an abandoned motor or in a parts box. Eventually you will come across one so just save it. I have saved about 7 or 8 of them 'just in case' and have never needed one of them yet! :D Quote Link to comment
wayno Posted April 6, 2011 Report Share Posted April 6, 2011 Hey Roger, just drive your truck around once it arrives, and fix it as needed. :rolleyes: Quote Link to comment
