Doing some body work on my 521 pickup...figured I'd share
NSRz32
I picked up an NOS pair of rockers for my 71 521 a few years back and am just now getting around to putting them on. The old ones are badly rotted and damaged (and so were the support panels behind them) so I got to work.
Behind the rocker was worse than the front :(
Cut everything out, seperated the side from the floor (floor is getting done too), and welded in a new panel and sectioned it into the front of the cab...new pinch
All fitted up and nice
Going to cut out the drivers side floor and replace that today....
Other than the two rockers, the backing panels they attach to, and the drivers floor...the truck is super solid. Fun winter project :)
  • Replies 19
Made some more progress today on the drivers side floor
Measuring up the new steel before cutting and shaping
Cut out the old one
Where OEM Datsun floor boards belong
Fits really nice, going to get it welded in over the next few days as time allows
really nice job. i see some really shitty rust repair come into my shop to be fixed and this makes me happy that some ppl do know how to do this correctly. well done
Thanks man! This is actually my first time doing body work/metal fabrication....so far so good :) And thanks everybody else, its coming along nicely IMO
:thumbup: This is great, we need more of this type of project, I would really appreciate close up oics. of the drivers side body mount bolt area, are you just going to shim it underneath, or are you going to weld the crater shaped piece in? wayno
At this point I'm likely just going to weld the mount to the floor pan. The bolt head in the body mount is badly decayed from what appears to have been standing water on the floor for a long time so it nearly flush with the rest of the mount. Shouldn't be too bad.
