Cody's Green 69 510 4-door
  • Replies 405
Finished up some side stuff like the undertray, strut bar, etc. Built my oil pressure sensor remote mount! Grease gun hoses are 1/8 NPT on both ends, and have a working pressure of over 3000psi. Used it with some sealant in the block (retapped to 1/8 NPT in the rebuild process) then to a brass coupler to a sensor block. I think this will work out nicely!
Dug this old pics up of my 68 in the good 'ol days! Avenue of the Giants on the north CA coast.
ANd my awesome girlfriend bought this stuff as a surprise gift when i got the datsun road ready again!
Hell yes!
Almost forgot these,
Its a 69, with original 69 turn signals, but, it has a 70+ valance panel...
Should i???
Scored these for $4 at a swap meet. Should I? lol
Awesome pro-Datsun Girlfriend bought an 8" bazooka tube, she likes the boom booms! fits perfectly in the foot well of the pass side! Works GREAT in such a small car =D
Yeah, a 10" sub would be more powerful, but im not one to be obnoxious.........yet......
My timing gun reads 5 degrees more advanced than it really is, its a cheap equus. I have a craftsman digital one now.
ANd the carb issue was when i rebuilt the weber, somehow, i swapped the primery and secondary jets... WHoops!
Installed an Accel Super Coil i had, works better!!
620 Pickup arm rest fits a 69 510!
50A OE Nissan 720 alt, it tested PERFECT!
4 speed shift knob from a Courier
Is this a heat shield? I should install this...
42 years of service
Moving back? Why would you do such a thing? Its such a ...depression town...=(
UPDATE
Just did some cleaning up on my rear disc setup, had a nagging dragging brake issue (lol) every now and then the brakes would hang on a bit and cause drag. I suspect it was a sticking e brake cable, cant find anything else wrong. So, i posted OICS for all to see my 87 maxima rear brakes, mounted upside down to use factory brake cables, and brackets from Aaron Suchy.
