Farmer Posted October 20, 2010 Report Share Posted October 20, 2010 For who ever is running the Su carb setup on their 620, I have some questions. First, are you running a 720 cable setup? And second, how are you running( the route) the manual choke cable into the cab. And where are you mounting the lever? Thanks larry Quote Link to comment
Skib Posted October 20, 2010 Report Share Posted October 20, 2010 one mine there rigged up to use the 620 cable atm but its not a great set up, it just works enough to drive it to work. Im going to be putting in all the 510 petal and manual linkage that they where ment to use in my truck here soon. Quote Link to comment
Pacific coast Datsun Posted October 20, 2010 Report Share Posted October 20, 2010 For who ever is running the Su carb setup on their 620, I have some questions. First, are you running a 720 cable setup? And second, how are you running( the route) the manual choke cable into the cab. And where are you mounting the lever? Thanks larry Larry im running the stock 620 throttle cable & its mounted to a Roadster part that I modified. For the manual choke I used a 620 hood release cable. The handle mounts to the kick panel right below the dash. Quote Link to comment
mr68gts Posted October 20, 2010 Report Share Posted October 20, 2010 Nope, The stock 620 cable works on mine but my set up was installed in 76 when the truck was new and you could still buy the correct linkage probably and not cobble it together like today. I'll get a pic when it warms up a bit outside and post it. Paul For who ever is running the Su carb setup on their 620, I have some questions. First, are you running a 720 cable setup? And second, how are you running( the route) the manual choke cable into the cab. And where are you mounting the lever? Thanks larry Quote Link to comment
Skib Posted October 20, 2010 Report Share Posted October 20, 2010 Nope, The stock 620 cable works on mine but my set up was installed in 76 when the truck was new and you could still buy the correct linkage probably and not cobble it together like today. I'll get a pic when it warms up a bit outside and post it. Paul NISMO sold a kit to use the SS SU's with the 620 cable. linkage kit #2 99996-T1111 to be used with the linkage kit #1 99996-T1110 but sadly they are long time NLA Quote Link to comment
mr68gts Posted October 20, 2010 Report Share Posted October 20, 2010 Skib, That is probably the one that is on my truck. The parts were bought new from Datsun Competition when they installed it on my truck in 76. Wonder how hard it would be to relicate it and how many would actually want it. I need to disassemble the carbs before I light it off again from it hiatus of 14 years. I can take some better pics and measurements and such when I do get ready to do that. I have no idea where the choke cable assy came from however. *edit* Larry: I was looking at your pics. On mine, the fuel lines come of the back of the floats and tie into a t at the rear carb by the head and then go to the fuel line on the firewall. The long lines you have being sent towards to front of the motor are actually vents on mine and come off the top and then just dive down and terminate there into atmosphere. (I can get more pics if need be. Just let me know) Paul Choke cable assembly in cab: Choke cables sit off the hood release bracket. Various linkage pics: NISMO sold a kit to use the SS SU's with the 620 cable. linkage kit #2 99996-T1111 to be used with the linkage kit #1 99996-T1110 but sadly they are long time NLA Quote Link to comment
Skib Posted October 20, 2010 Report Share Posted October 20, 2010 sweet, Iv just seen it in the NISMO book but I never got to see it actually on a car Quote Link to comment
Farmer Posted October 21, 2010 Author Report Share Posted October 21, 2010 Thanks for the pictures. I would of never of thought of mounting the choke on the hood release. When I bought the Su's from Zeed(nwde) he showed me how he had fuel/vent/return line connected I do have the double choke cables. I just cant get my stock throttle cable to reach My linkage is not stock Larry Quote Link to comment
datzenmike Posted October 21, 2010 Report Share Posted October 21, 2010 Larry try one from a 720. They bolt to the firewall slightly different but are miles longer to reach the 720 carb on the pass side. I have one in my 620 and it fits the gas peddle. This.... ... is pure sex . Quote Link to comment
Pacific coast Datsun Posted October 21, 2010 Report Share Posted October 21, 2010 Larry i forgot to mention that i linked both chokes by using a piece of metal. When i pull the cable they both open as one. Quote Link to comment
Skib Posted October 21, 2010 Report Share Posted October 21, 2010 well my throttle cable broke............. again <_< so Im trying to so all the engineering to get the 510 linkage to fit in one night..... instead of this weekend like I planned <_< its a really tight fit but the linkage in the engine bay is worked out and the rod that goes from the firewall to the carbs needs to be shortened about an inch if you want to be strait on (pic for example) but Im still working out how Im going to get the pedal to fit in a place that will work inside but still be able to come out in a place to reach the linkage. Quote Link to comment
mr68gts Posted October 21, 2010 Report Share Posted October 21, 2010 That's pretty much it on the lines. I don't think mine runs a return though, I'll have to look (self regulated electric pump) and since I don't have a charcoal canister there's no lines from the vents foward. My truck has a aftermarket (Datsun Comp?) 20 gallon tank in it and that changed my setup a little from most. Yeah, having the correct linkage would be a blessing! I've never had any problems with it what so ever. Paul Thanks for the pictures. I would of never of thought of mounting the choke on the hood release. When I bought the Su's from Zeed(nwde) he showed me how he had fuel/vent/return line connected I do have the double choke cables. I just cant get my stock throttle cable to reach My linkage is not stock Larry Quote Link to comment
mr68gts Posted October 21, 2010 Report Share Posted October 21, 2010 LOL! I know. It works flawlessly. I sure wish I knew what it came out of. I was just looking at it and noticed after all these years that the choke words are up side down so I don't think it's a Datsun Comp piece. Paul Larry try one from a 720. They bolt to the firewall slightly different but are miles longer to reach the 720 carb on the pass side. I have one in my 620 and it fits the gas peddle. This.... ... is pure sex . Quote Link to comment
Farmer Posted October 21, 2010 Author Report Share Posted October 21, 2010 I wont be running a char canister either. Im just going to hook them up to the line going back to the fuel tank which was hooked to the canister. Im going to have to make a custom bracket for the throttle cable,something like pac's running Larry Quote Link to comment
Pacific coast Datsun Posted October 21, 2010 Report Share Posted October 21, 2010 Heres another view. I bolted a piece of alluminum to the manifold & the throttle cable slides into the top of that. Its braced by another piece of metal between the intake & the throttle cable bracket... Quote Link to comment
Skib Posted October 22, 2010 Report Share Posted October 22, 2010 heres the 510 stuff so far, will need some fab work but oh well, all the set ups are. its a very tight fit but the simplest thing is prob a set up like PCD has with a well routed cable. Quote Link to comment
datzenmike Posted October 22, 2010 Report Share Posted October 22, 2010 Here's the 710 set up. The rod coming out to the carb(s) is adjustable in length, like a collapsible steering column. Quote Link to comment
Skib Posted October 22, 2010 Report Share Posted October 22, 2010 Here's the 710 set up. The rod coming out to the carb(s) is adjustable in length, like a collapsible steering column. ya the 510 is like the Z one and just one solid rod, Im just going to cut it down and re weld it. along with some of the ball end rods. Quote Link to comment
Logical1 Posted October 22, 2010 Report Share Posted October 22, 2010 I personally hated my stock 510 linkage to my SU's. It just was not as precise as I wanted and just 'clunky' Posted this before when Skunk was looking to link up his SU's so I though I would post a link to the thread: SU Linkage My cable has been pulling VERY smooth for well over a year now with no sign of breakage :) Quote Link to comment
datsun brat pack Posted October 22, 2010 Report Share Posted October 22, 2010 :P ok just make sure to show us when u are done skib lol Quote Link to comment
zerow Posted October 22, 2010 Report Share Posted October 22, 2010 well my throttle cable broke............. again <_< so Im trying to so all the engineering to get the 510 linkage to fit in one night..... instead of this weekend like I planned <_< its a really tight fit but the linkage in the engine bay is worked out and the rod that goes from the firewall to the carbs needs to be shortened about an inch if you want to be strait on (pic for example) but Im still working out how Im going to get the pedal to fit in a place that will work inside but still be able to come out in a place to reach the linkage. You are having the same problem I had... I moved that whole assembly over one screw hole (towards the passenger side) in order for the linkage to align directly with the carbs....and I drilled a new hole for mounting. (Top of the pic) I also installed the socket ends with the Mercedes linkage I described. I now get full pedal travel with 100% open throttle (old linkage gave me 75-80%, at best) Quote Link to comment
Skib Posted October 27, 2010 Report Share Posted October 27, 2010 success! truck officially drives with my re-engineered 510 mechanical linkage :lol: cameras toast and its dark so no pics for now but Ill take some tomorrow with the GF's camera Quote Link to comment
Pacific coast Datsun Posted October 27, 2010 Report Share Posted October 27, 2010 success! truck officially drives with my re-engineered 510 mechanical linkage :lol: cameras toast and its dark so no pics for now but Ill take some tomorrow with the GF's camera Kool..awaiting pix. Quote Link to comment
Master-O-Turbonics Posted October 27, 2010 Report Share Posted October 27, 2010 Choke cable assembly in cab: That looks 100% identical to the stock choke lever setup in a 240z or 260Z that mounts in the center console. See how the word "choke" is upside down? lol Quote Link to comment
Skib Posted October 27, 2010 Report Share Posted October 27, 2010 That looks 100% identical to the stock choke lever setup in a 240z or 260Z that mounts in the center console. See how the word "choke" is upside down? lol lol thats what I was thinking too Quote Link to comment
