L20b headers!
Stupid_fast
Yes I searched, I didn't get the answer I wanted.
There are two headers on ebay that fit an L20, one is for a 510, one is a "shorty header".
Question: Which one will I want to be sure I can get my car as low as I want(Probably wont be THAT low... on 13"s) and not have to worry about the header? Either?
510 headers,
http://cgi.ebay.com/...#ht_1273wt_1167
shorty ones,
http://cgi.ebay.com/...#ht_1102wt_1167
I'm in no hurry, planning to get it in the next few weeks.
Thanks. :D
  • Replies 38
you want the 2nd one if you really need headers.
But they are $150 at Top End performance
PS spend another 100 and get them ceramic coated.
Fuck Bills datsuns!!!!!!!!!!
Nothing wrong with a L16 non smog injected exhaust manifold. Just get a 2in Y pipe made.
I have the shorty header but havent used it yet.
Unless you have a full race motor most HP gain is in your mind. I only suggest this header if you have a later L20 nasty exhaust manifold you want to get rid of.
Cool, thanks.
They have the top end performance one on ebay for $20 more than their shop, but its free shipping. http://cgi.ebay.com/...s#ht_2601wt_941
Where to get it ceramic coated? I looked it up, and I don't have a spare oven to cure the paint if I do it myself.
The stock manifold is a square-port L20 without the smog stuff though I have to get the exhaust welded back on anyways, so I think a header would be worth it. I'm building for a street prepared autocross/weekend fun car.
I'm probably going to tow it to an exhaust shop to get it welded, unless someone from the bay area will do it for me on the street in front of my house on cheap jackstands. :D
I'm probably going to tow it to an exhaust shop to get it welded.
thats the onee to get rid of.!!!!!!!
yes then get the header.
PS you find a place that get headers ceramic coated. Look in yellow pages or the web near you. No spray can stuff.!!
That header dont use that reducer just get pipe that mates with the downspout and reduce to 2in should be fine
That header dont use that reducer just get pipe that mates with the downspout and redec to 2in shooould be fine
There is a reply button btw, it puts my message in nice little quotes. happy.gif
Thanks, I'll definitely pick this up then. Just the clutch, header, crossmember and I can drop the engine in!
fun.
i STRONGLY SUGGEST you get them coated. That blk paint rust on about 6 months it makes a nice motor look like SHIT!!!!!!!!
http://www.performan...com/index2.html
Yeah I just used google and found a few places that do it. Don't worry. :D
Did you see my 7MGE exhaust manifold on my yota? I definitely wont let that happen to my 510.
edit,
Why do you want a header thay leak are loud and they make the inder hood temps hotter . Are you building a monster l20 or larger?
They give me slightly more HP, they probably sound nicer? I have to weld the exhaust already? I have an L20b.
Funny there are some new earplugs in the ash-trey from the previous owner, along with some coins(rebate!) a hex socket(12mm?), a lighter, a sea shell, ect... OH and there where sunglasses in the glove box! laugh.gifMy point is, I don't care about the noise level as long as its legal. My Toyota can be for when I want a quiet car.
Too bad the left coast wasn't closer to the right coast. 8) I just finished a set of headers before I logged in. I do a lot of ceramic coating and powder coating. The underhood temp is reduced by the gases flowing out versus the metal absorbing the heat and at high rpm's (where the HP increase kick's in). Good luck
My Site
www.srpowdercoating.com
My Site
I would go through you but I could not afford the shipping, sorry. twofinger_salute.gif <Ahh.. The ratsun salute.
If you are not going to be turning some serious RPMs on a regular basis,the manifold is the way to go.
This is why I bought this car, so I can have something that I can push yet never have to worry about breaking my parents stuff. :D
So 8k RPM pulls and clutch drops all the time should not be a problem? laugh.gif
Sorry dude, shipping would probably be too much. I'm on a budget! :(
I'm on a budget! :(
Another reason to run stock manifolds. Or at least an L16/18.
Say $100 header + $100 to coat. That's $200 to maybe gain 3-4 hp at 4K to 6K. Cost $50 per hp. Free or $20 L16 manifold with maybe 2-3 hp gain above 4K. Cost free or up to $10 per hp. and better mid range.
Headers are louder. I can afford them. They look nicer. I have to weld my exhaust anyways.
I am going to be doing more top end work on the engine after I get it running, maybe dual carbs and a nice cam shaft, valves, port it, ect... The higher flow header will help a little bit more every time I mod something else, correct?
Every little bit counts. When we are talking `156whp or 160whp... Its... more...
If yourf trying to get that amount of power from a l20b header is the least of your worries you are about to spend a lot of money
Yes I know, more like 100whp would be nice to start out with, I'm talking about the future... Whatever I'm getting the damn header. lol. :D
he has his mind made up allready. You wont change it.
This is common on New datsun owners when they want something.
I would spemd money on Head,cam match port, and find a dueal carb set up w/1.5in ports.
But the way I look at it, if he buys the header they will still make them cause there is a demand.
I want to see the car running first.
Then spend money on other stuff.
It took one experience with installing a 521 header back in the 70s to teach me a lesson. I thought it would secretly unlock 'hidden' power in my L20B motor. I was so disappointed with it, but had already spent the whole weekend getting it on and had cut the down pipe. For the next several years I had to listen to exhaust leaks and tighten bolts.
Fuckit I say. Every generation has to learn this lesson.... you can tell them and they won't listen. So I sit and watch, hoping for the best.
