Galen Posted August 6, 2010 Report Share Posted August 6, 2010 Just picked up a 69 Datto 510 with Nick aka GrizzlyBrother. Shes a real "fixer-upper", but has most of the parts needed to get it running were included. SR is sitting in it all bolted up and ready to be reassembled. BODY: - 240sx flares - surface rust - Sweet paint yo - 6pt cage ENGINE: - SR20DET red top - T25 turDo - Random exhaust mani - Audi intercooler - Random fuel rail STOPPING STUFF: - Brembo rotors - Bigger Nissan calipers SUSPENSION: - Koni yellows - Ground Control coil kit - Camber plates front FUEL: - none WHEELS: - Knock off Panasports - Falken Azenis PICS: . . . . . . . -Galen Quote Link to comment
Galen Posted August 6, 2010 Author Report Share Posted August 6, 2010 So today myself and nick got all the boxes of goodies taken out of the datto. took a look through everything. Ill need a lot of new hosing, and after test fitting the exhaust mani it looks like ill either have to flip the mani and run top mount turdo, or have a new one made (to much chedda for me). the clutch and flywheel need to be put back in, so ill probably just pull the engine to do that since its only a few bolts. while its out ill do the major engine assemblythan drop it back in. I think nick wants to paint the engine bay neon green... why not! After we got all that done we bolted the cage back into place. I still need to get a few more bolts to finish that up but its done for the most part. PICS! . Nick slaving away.. . . Than I got hungry and made a sandwich. Shoulda made a BURGER! We also got some random trim pieces on, got rid of the windshield wiper motors (rainex FTW!!) and pulled out the rest of the sound deadening and other crap that didnt need to be there. -Galen Quote Link to comment
Galen Posted August 6, 2010 Author Report Share Posted August 6, 2010 Been pretty busy, unfortunately it hasn't been on the 510 After work today Nick and I for come cutting and grinding done. I need to order the gasket kit for the SR, than its out with the engine. Its slow going right now, but expect some major updates on the engine in the next week or so. PICS: Makin room for the interCOOLER . . . making room for the piping bends . . . . Test fitting . . . BALLERZ EDIT: ground down the (drag?) link. . . GRIZZLY and grinders... . More cutting... Thats all for now. Quote Link to comment
Galen Posted August 6, 2010 Author Report Share Posted August 6, 2010 Cutting/ cleaning up the tranny tunnel to fit the SR tranny. . . . Random shot Quote Link to comment
banzai510(hainz) Posted August 6, 2010 Report Share Posted August 6, 2010 those front wheels are way to big even with flairs or the series tire are wrong Quote Link to comment
dennis Posted August 6, 2010 Report Share Posted August 6, 2010 Nice project!!!!! and that samich looks good too. How did the previous owner mount the SR? I know flipped but new motor bracket and 510 mounts? Just curious on everyone's setup. Quote Link to comment
skunk Posted August 6, 2010 Report Share Posted August 6, 2010 cool little datsun. keep up the work, i want to hear this thing run. get video of first start up Quote Link to comment
datto510 Posted August 6, 2010 Report Share Posted August 6, 2010 Are you guys in the coast guard? Quote Link to comment
Logical1 Posted August 6, 2010 Report Share Posted August 6, 2010 Great project! Glad to see it being brought to life :) nice work so far, but damn I would tape up the ports on your SR while grinding in the engine bay :o Oh! Welcome to Ratsun :D Quote Link to comment
DISLEXICDIME Posted August 6, 2010 Report Share Posted August 6, 2010 why did you cut the trans tunnel like that ? good thing you got so much tire you will need it Quote Link to comment
DISLEXICDIME Posted August 6, 2010 Report Share Posted August 6, 2010 those front wheels are way to big even with flairs or the series tire are wrong It looks like he has the wider wheels on the front then the back Quote Link to comment
Galen Posted August 7, 2010 Author Report Share Posted August 7, 2010 I havent even thought about the wheels yet. they poke like shit, but ill deal with that when the time comes. there is newspaper in the ports, but your right they should be taped up. lol I mainly was cleaning up the cut that was already made in the tunnle. No, not in the CG. lots of em out here though. Quote Link to comment
]2eDeYe Posted August 7, 2010 Report Share Posted August 7, 2010 ground down the (drag?) link. . Why? This is a pretty important steering component that you have compromised. Quote Link to comment
INDY510 Posted August 7, 2010 Report Share Posted August 7, 2010 Yeah. ... . . .. that should not have been necesary..... It looks like your control arm has the wrong washer......... .. causing the nut to not tighten fully......... thus it hits the idler arm The stock idler arm sits about 1-2mm off the control arm nut........ I have never seen any clearance issues Quote Link to comment
DISLEXICDIME Posted August 7, 2010 Report Share Posted August 7, 2010 Yeah. ... . . .. that should not have been necesary..... It looks like your control arm has the wrong washer......... .. causing the nut to not tighten fully......... thus it hits the idler arm The stock idler arm sits about 1-2mm off the control arm nut........ I have never seen any clearance issues i have! If some one raised the pivot points more then a 1/2 inch it will hit Quote Link to comment
thisismatt Posted August 7, 2010 Report Share Posted August 7, 2010 2eDeYe' date='06 August 2010 - 05:33 PM' timestamp='1281141238' post='336097']Why? This is a pretty important steering component that you have compromised. Brah, chill brah, this is Ratsun brah! :fu: Quote Link to comment
Galen Posted August 7, 2010 Author Report Share Posted August 7, 2010 i just did it the ghetto way. probably not safe but oh well. Took a look at the wheels today. whoever mounted them is a retard and put the wider offset wheels on the front. they have locking lugs so I have to get the key and than switch them. Quote Link to comment
]2eDeYe Posted August 7, 2010 Report Share Posted August 7, 2010 Brah, chill brah, this is Ratsun brah! :fu: :lol: i just did it the ghetto way. probably not safe but oh well. Ummm....ok :mellow: Quote Link to comment
DISLEXICDIME Posted August 7, 2010 Report Share Posted August 7, 2010 i just did it the ghetto way. probably not safe but oh well. Took a look at the wheels today. whoever mounted them is a retard and put the wider offset wheels on the front. they have locking lugs so I have to get the key and than switch them. i am glad to not live near you ! you do realize your not only jeopardizing your safety but other people on the road. Quote Link to comment
