banzai510(hainz) Posted August 4, 2010 Report Share Posted August 4, 2010 After seeing GreenGOONS wagoon with the ROTA wheels installed I finally order some 195/45/15 Nexen Tires. I tried to order Cooper Zeons but theyre were no longer avail. I only was going to get these as they were cheaper and Made in the USA. I figure try to buy American if possible. Anyways I got the tires mounted right after they showed up. With great excitment I figure I would put them on and roll my beater to work with my new bling wheels so everybody would laught at me. I put the front tire on and it clears the strut great and probaply a 195/50 would fit not proplem. But then I bolt the rims on finding out the lugnuts I have are a bit to big to use a socket on there as it will scrape the hole.meaning socket edge hit the wheel. So I found some 19mm lugnuts. Put the wheel on and now it just barely hits the steering joint(tierod),inside of the rim. I said, Fuck No Way. I need to buy spacers. Shit. i called Jeff up(icehouse) and we discussed this then I said what if I removed the T3 bump steer spacers as they have the long ones being like 1.25in thick. He says I bet 100$ if you remove those Bumsteerspacers that it will fit. Well I have a spare strut and A arm assemble in the garage and bolted it together and Low and behold the joint is now 1/4 in or more away from the back of the rim. So when I PM GREENGOON he says they have +20mm offset rims also. That would have been nice to know before I got this +25 but remember this is a 510 strut. But I think I will remove the bumpsteerspacers. also since the car has a slight positve camber removing the Spacer will move the A arm up thus making it more parallel with the road. which Im hoping will make the wheel near ZERO on the camber. thus not neede to buy camber plates. If anybody can conferm this. As before I smashed this car I had shorten struts lowered with the same spring and had perfect tire wear. and steered just fine.I just got to watch the swaybar as when you raise the A arm back up the TC rod will raise and almost hit the sway bar so I might still need a bumsteerspacer bu maybe a .75 or just a 1 in one if avail. Quote Link to comment
jefe de jefes Posted August 4, 2010 Report Share Posted August 4, 2010 Pics of your new bling? I'm thinking of mounting mine up Saturday. Hopefully I font run into any problems. I have the +25 iirc. Still need lug nuts though. Quote Link to comment
datto510 Posted August 4, 2010 Report Share Posted August 4, 2010 I'll take that headache off of your hands for $400. You car looks good with the stock hubcaps. Quote Link to comment
djaztek12 Posted August 4, 2010 Report Share Posted August 4, 2010 on my goon i had to run spacer as well mine rota rb are 30+ offset :lol: Quote Link to comment
Bleach Posted August 4, 2010 Report Share Posted August 4, 2010 sweet. Mine are +4 offset on the Z and I wish they were wider with negative offset! :) I've got room to spare Quote Link to comment
banzai510(hainz) Posted August 5, 2010 Author Report Share Posted August 5, 2010 I took out the spacers last nite. Wheels fit perfect. Now Im rolling down the street and women and children are throwing flowers at me. somebody is going to steal these rims!!!!!!!datto510 PM me your number. I forgot my phone Quote Link to comment
jefe de jefes Posted August 5, 2010 Report Share Posted August 5, 2010 I took out the spacers last nite. Wheels fit perfect. Now Im rolling down the street and women and children are throwing flowers at me. somebody is going to steal these rims!!!!!!!datto510 PM me your number. I forgot my phone Ha, the red carpet treatment. Awesome! Invest in some wheel locks bro. So where's the pics? Quote Link to comment
datto510 Posted August 6, 2010 Report Share Posted August 6, 2010 I told Hainz I'd post some pics of his new wheels. Its now a POS with nice wheels. :lol: I think the front needs to go lower now. Quote Link to comment
ohpyramids Posted August 6, 2010 Report Share Posted August 6, 2010 CHOP THOSE FRONT SPRINGS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! or add a heavier engine. Quote Link to comment
Pacific coast Datsun Posted August 6, 2010 Report Share Posted August 6, 2010 Looks good Hainz...about time you treated yourself to some rims :cool: Quote Link to comment
jefe de jefes Posted August 6, 2010 Report Share Posted August 6, 2010 Alright! We got pics. Lookin' good. Quote Link to comment
ariascarlos1990 Posted August 6, 2010 Report Share Posted August 6, 2010 I would of went 50 series but, overall it looks great! Quote Link to comment
banzai510(hainz) Posted August 6, 2010 Author Report Share Posted August 6, 2010 I wasnt sure about the front tire being close to the strut. I did try to order soem Cooper Zeon's in 195 50 but hey were out so I went back to org pick of the 45s. Dillon has Nitto 45s on his 510 and I like the stretched look but his is more stretched than mine.Differnt manufacture????? so every company is slightly different. maybe should have got 205 in back, would have helped also. But if I drop the front 1.5 more Im sure it will look good. Right now I can get the lowprofile jack under there barely hitting the airdam. Now I have construction around my neiboorhood and roads al busted up. I dont want to lower it yet Quote Link to comment
Romano Jr Posted August 7, 2010 Report Share Posted August 7, 2010 Looks great bro!!! Congrats Quote Link to comment
greengoon Posted August 9, 2010 Report Share Posted August 9, 2010 Hainz- it looks great! I like the 45 series. I would have done those tires had it not been for the solid rear axle of the goon. Glad I motivated you to put them on. No use of having cool wheels sitting in the garage unloved. And I would not call your car a pos. It has lots of character the way a dime should! As far as bumps steer spacers, I have a set that I was going to put on but maybe I should re look at the clearance issues. It rides and handles pretty good without them. Quote Link to comment
Duncan Posted August 11, 2010 Report Share Posted August 11, 2010 I like both of your Rota sets! I'm thinking a set of those might find their way here. That's hard to beat for the price. Would a +20 work w/ ZX struts and coilovers? Quote Link to comment
greengoon Posted August 12, 2010 Report Share Posted August 12, 2010 Duncan, if I remember right the ZX struts are 1" (or so) narrower which means you can handle a lower offset. The cars that run 0 offset wheels have ZX struts usually. Id have to do some calculations to see if the +20s would work without a spacer but I think the +12s would easily fit. Quote Link to comment
Duncan Posted August 13, 2010 Report Share Posted August 13, 2010 Duncan, if I remember right the ZX struts are 1" (or so) narrower which means you can handle a lower offset. The cars that run 0 offset wheels have ZX struts usually. Id have to do some calculations to see if the +20s would work without a spacer but I think the +12s would easily fit. Thanks. I have a project I'm working on, and I like the front wheels tucked in as much as possible. I have the struts in the garage but don't have them on the car yet. Quote Link to comment
INDY510 Posted August 13, 2010 Report Share Posted August 13, 2010 I think it's 3/4" narrower on each side Quote Link to comment
Bunchy Posted May 27, 2011 Report Share Posted May 27, 2011 Trade mr this for my goon!:) Quote Link to comment
banzai510(hainz) Posted May 27, 2011 Author Report Share Posted May 27, 2011 the front is lower now after the coilover install with 7inch springs Quote Link to comment
hobbes_the_cat Posted May 27, 2011 Report Share Posted May 27, 2011 Duncan, if I remember right the ZX struts are 1" (or so) narrower which means you can handle a lower offset. The cars that run 0 offset wheels have ZX struts usually. Id have to do some calculations to see if the +20s would work without a spacer but I think the +12s would easily fit. I think it's 3/4" narrower on each side I just did the 280zx swap, I measured before and after, and it did bring the wheels in 3/4". CONFIRMED Quote Link to comment
