Gary Posted December 18, 2010 Report Share Posted December 18, 2010 the only thing with reversing polarity, i was yelled at by someone (from the internet, mind) who told me i shouldnt do that, i should undo the little nut holding the fan to its motor and flip the fan instead (which is easy, use some thread lock on the little nut though to be sure) i think it depends on the thermos you get, some of them have blades that work better going in one direction than the other, so might be worth loose fitting the fans and giving it a couple tests feeling how much air they pull with your hand im sure you'll be fine if you just reverse polarity, the fan will still work good enough. ive got away with it for a supra engine but its probably better to do it right if it gets fair hot where you live :) 1 Quote Link to comment
fivetenguy Posted December 18, 2010 Author Report Share Posted December 18, 2010 Thanks for the tip, Gary!! 1 Quote Link to comment
alleycat Posted January 16, 2011 Report Share Posted January 16, 2011 great updates. 1 Quote Link to comment
motavated Posted January 16, 2011 Report Share Posted January 16, 2011 where did you get your motor mounts? 1 Quote Link to comment
Wide14u Posted January 16, 2011 Report Share Posted January 16, 2011 looks great but i want more pics Quote Link to comment
Zeusimo Posted January 16, 2011 Report Share Posted January 16, 2011 Yes I Have Ninja Skittles :ninja: Quote Link to comment
fivetenguy Posted February 6, 2011 Author Report Share Posted February 6, 2011 where did you get your motor mounts? Got the mounts at Autozone. 1 Quote Link to comment
fivetenguy Posted February 6, 2011 Author Report Share Posted February 6, 2011 looks great but i want more pics More updates and pics coming soon! 1 Quote Link to comment
fivetenguy Posted February 6, 2011 Author Report Share Posted February 6, 2011 Yes I Have Ninja Skittles :ninja: Dude you are freeking me out! This is an old google pic of my place. House is a different color now. That 620 you see in front of the CL is now in sunny Mexico! It's my transportation when I go and visit. 1 Quote Link to comment
fivetenguy Posted May 4, 2011 Author Report Share Posted May 4, 2011 I haven't posted any updates in a while, but it doesn't mean I haven't been working to complete it. I had to buy a new clutch slave cylinder since it had the wrong one. The line would hit the torsion bar on the clutch slave it came with. Now I need to bleed the line. No pics of this since it's borring stuff. I still need to buy a brake master cylinder. I have the Pathfinder calipers with the Passport rotors up front. Been calling the auto parts stores but no one has the '79-80 280ZX MC (15/16" bore). Do you guys think the 7/8" bore of the '78 280z MC will work? I plan on running the Isuzu rear brakes, as well. I already have the calipers. I need to buy the rotors and bracket. The truck did not come with a fan shroud so the fan is kind of useless. I bought a fan shroud from a fellow Ratsuner, but I guess I will give the electric fans a try for a while. Mounted the 2 Spal fans a little staggered. I still need to run power to them. Not sure if I'm going to run a switch or install a temp controller. Quote Link to comment
fivetenguy Posted May 4, 2011 Author Report Share Posted May 4, 2011 Up front I installed the head lights, grille, lower valence, and new front signal/parking lights. The front signal lights still need to be wired. I still need to put the bumper and air dam on, but I'll wait til the end for those two things. I installed the tailgate. The bed now looks more complete. Also bought new tail light lenses. The quality on these si not bad considering they are aftermarket. The fenders are also installed. I kind of messed up here . These fenders are aftermarket. I got these from the previous owner when I bought the truck. I figured we could save time and money by using the new fenders. As you guys know aftermarket body panels almost never line up very well. Well, these fenders were no exception. I totally forgot to prefit the fenders and do what ever work had to be done prior to paint :angry:. I had to shim, pull, push and ream some holes on the fender. I am not a body tech but I did the best I could. You could see the gaps I have up on the cowl and by the pillar. Oh well, like I said at the beginning of the build, this is not going to be a show truck! 1 Quote Link to comment
fivetenguy Posted May 4, 2011 Author Report Share Posted May 4, 2011 Went out and bought new urethane bushings for the swaybar and the TC's. The old rubber bushings were shot to hell. I decided to swap the seats between my 620 and 510. This will save me the price for a bench seat. 510 is mostly used for the track so it kind of works out. Quote Link to comment
fivetenguy Posted May 4, 2011 Author Report Share Posted May 4, 2011 Been working on the exhaust on and off. It's almost complete. I started from the exhaust manifold using stainless mandrel bent steel. I still have to finish the tip end. I'm not a welder by any means so please don't mind the not so pretty welds :lol:. Not quite sure what angle I will leave it at. Definitely not were it's at now. I don't want the bed to get all covered in suet. I bought an inexpensive Thrush turbo muffler. It's supposed to be quiet but we'll see. Quote Link to comment
fivetenguy Posted May 4, 2011 Author Report Share Posted May 4, 2011 Tried the rims that I will be running for the first time. I had to run a 1/8" spacer up front because it hit the caliper. I turned the wheel all the way to the right and noticed that the rim almost rubs against the sway bay. I plan on running 205/55 all around. What do you guys think, run with the caps or not? I will continue to work on the truck this week coming up. I'll keep you posted... 1 Quote Link to comment
izzo Posted May 4, 2011 Report Share Posted May 4, 2011 What kind of seat is that in your truck now? I used to have similar in my wagoon. They were the most comfy seats ive had 1 Quote Link to comment
Zeusimo Posted May 4, 2011 Report Share Posted May 4, 2011 (edited) Wow.... Do You Drive This? Never Seen It :huh: Edited May 4, 2011 by Zeusimo 1 Quote Link to comment
fivetenguy Posted May 4, 2011 Author Report Share Posted May 4, 2011 What kind of seat is that in your truck now? I used to have similar in my wagoon. They were the most comfy seats ive had These seats are off an '88-'90 Honda Si. I bought these from a JY many years back. Yes, they are very comfortable. I wish I could find another set in the same condition that way I could have left these in my 510. 1 Quote Link to comment
izzo Posted May 4, 2011 Report Share Posted May 4, 2011 If you dont run the center caps maybe just clean up the grease caps a bit and color match it, or paint black? 1 Quote Link to comment
fivetenguy Posted May 5, 2011 Author Report Share Posted May 5, 2011 Wow.... Do You Drive This? Never Seen It :huh: I got the truck back from paint in October. I have been putting it back together since then. I used to drive it a bit when it was silver, but it has not been on the road since i had it painted. Hopefully in a month! 1 Quote Link to comment
Z chopper Posted May 5, 2011 Report Share Posted May 5, 2011 I say use the centre caps maybe get a ratsun decal for all 4 of them for the finishing touch. 1 Quote Link to comment
fivetenguy Posted May 5, 2011 Author Report Share Posted May 5, 2011 I say use the centre caps maybe get a ratsun decal for all 4 of them for the finishing touch. Now there's an idea!! :lol: 1 Quote Link to comment
sick620 Posted August 4, 2011 Report Share Posted August 4, 2011 progress? sweet truck! :) 1 Quote Link to comment
fivetenguy Posted August 4, 2011 Author Report Share Posted August 4, 2011 Hi and thanks! There has been progress. Actually I'm almost done. The thing is, believe it or not, I don't own a digital camera :lol:. I am forced to borrow my brothers' or mom's camera. I know, I suck ... 1 Quote Link to comment
fivetenguy Posted September 15, 2011 Author Report Share Posted September 15, 2011 Finally got around to buying the tires. I went with the Falken 912's 205/55/16. I have the same tires on my GLI and I am happy with them. Also, bought a new voltage regulator and accelerator cable from rock auto. The old voltage reg. was draining my battery and the cable got damaged when I removed the engine to paint the engine bay. 1 Quote Link to comment
fivetenguy Posted September 15, 2011 Author Report Share Posted September 15, 2011 A shot of the front and rear wheels mounted. As you could see I upgraded to rear disk brakes as well. 2 Quote Link to comment
