haubstr Posted December 19, 2007 Report Share Posted December 19, 2007 I want to put on my Z-71's w/205-40's on my truck but the tires hit the leaf springs... The rims are already machined out to 4"... I figure I need spacers to get them to not rub, but how much spacer? If I put 1/4" spacers on can I still run the stock studs? Thanks Quote Link to comment
banzai510(hainz) Posted December 19, 2007 Report Share Posted December 19, 2007 Yes I ran 1/4 cheap cast spacers on my 510 using the stuck lug nuts. (I stand corrected by layedoutb2k. It was a 200sx wheel and it was a stock lug nut for that rim) my front wheel the wheel weights were slightly hitting the strut so I added a spacer I guess make sure at least half the threads are used. Quote Link to comment
Pacific coast Datsun Posted December 19, 2007 Report Share Posted December 19, 2007 Hainz is correct [again] :D But...for safety youll want to use a "conical seat" lug nut to hold the rim snug against the drums.... Quote Link to comment
LAYEDOUTB2K Posted December 19, 2007 Report Share Posted December 19, 2007 YesI ran 1/4 cheap cast spacers on my 510 using the stuck lug nuts. I guess make sure at least half the threads are used. Z-71s on a 510 with stock lug nuts?? id like to see that. :P Quote Link to comment
fiveNdime Posted December 20, 2007 Report Share Posted December 20, 2007 I once heard from a tire shop that as long as there is 3 full turns on the lug nut then its ok.....I would like more though, even more on the 510 cause theres only 4 lug nuts to depend on. Quote Link to comment
banzai510(hainz) Posted December 20, 2007 Report Share Posted December 20, 2007 3 full turns??????? I dont think Ill go to that tire shop Quote Link to comment
datsunaholic Posted December 20, 2007 Report Share Posted December 20, 2007 3 full turns? That's 3 THREADS. Uh, no. 10 threads, MAYBE. With a Standard lugnut (not the cap type) I like to see 3 threads extend through the nut. Quote Link to comment
Z-train Posted December 20, 2007 Report Share Posted December 20, 2007 Unless the thought of YOUR tires passing you on the highway appeals to you,CHANGE THE STUDS!!!:blink: Quote Link to comment
yello620 Posted December 21, 2007 Report Share Posted December 21, 2007 Rule of thumb from my 15 years in the tire business was that you need to be threaded on at least as far as the stud is round. So a 12mm datsun stud needs to have a lugnut threaded on AT LEAST 12mm. I personally always prefered more thread engagement than that. I never understood why it is even a question as to whether or not you need longer wheel studs! If you have to ask, Just get the longer studs and be done with it. Sorry to be a DICK. But this is one of the overlooked safety things of a vehicle. Lugnut torque is overlooked also. Jason Quote Link to comment
haubstr Posted December 21, 2007 Author Report Share Posted December 21, 2007 I asked the question because I wanted to find out if others had come across the same problem or if maybe I had done something wrong... I hadn't even tried to put a lug nut on it yet because the spacers won't be here until Monday(hopefully)... I was trying to use some advance thinking and see if I can do something else in the meantime... like getting longer wheel studs... Quote Link to comment
yello620 Posted December 22, 2007 Report Share Posted December 22, 2007 ... Cool, Reread my post and I suppose I kinda sond like a DICK about it, But this question has been answered so many times and then people still try to get by WITHOUT listening to the advise. Sorry, no offense was intended to you. Sounds like you are planning it and Want it to be safe. Let's see pics when you get the wheels installed. Jason Quote Link to comment
mklotz70 Posted December 22, 2007 Report Share Posted December 22, 2007 maybe on a grade 8 bolt the 3 threads is what it takes to be able to achieve it's rated holding, but that's almost insane on a lugnut.....especially on aluminum wheels that expand and contract with heat. Anyway.....new lug bolts is money well spent!! :) Quote Link to comment
shane_lxi Posted December 23, 2007 Report Share Posted December 23, 2007 A good rule to go by is to have atleast as many threads as the thickness of the stud. Like you'd want atleast 1/2" of thread in the lugnut for a 1/2" stud, in other words. Sandwich spacers arent exactly the safest way to go anyway, expecially the cheaper ones. They can be machined unevenly, so the spacer would have like high and low spots, which could lead to a wobble or losing your wheel :(. If you need to run them though, I'd run some quality spacers (which are still kinda cheap) like Gorilla or h&r if they still make the ones that dont bolt on. Quote Link to comment
mklotz70 Posted December 23, 2007 Report Share Posted December 23, 2007 I'd put some old drums on the lathe and cut out the center part and use it :) .....but that's just me :) Quote Link to comment
shane_lxi Posted December 27, 2007 Report Share Posted December 27, 2007 ^ that works, lol. Quote Link to comment
