makya Posted December 19, 2007 Report Share Posted December 19, 2007 I want to put bags on the dually, but being cheap I don't want to spend $$$ on a compressor. So, has anyone used the air ride compressors from a Town Car or Caddy? Quote Link to comment
Jester Posted December 19, 2007 Report Share Posted December 19, 2007 No.....but it sounds like a good idea for my onboard air in the Jeep.:rolleyes: Thanks for the idea. Jester Quote Link to comment
yello620 Posted December 19, 2007 Report Share Posted December 19, 2007 My experience with those compressors is that they will put out the pressure that we need for bags, but produce very little volume. Might work ok if you ran two of them in parallel while uitilizing a holding tank. Would not be good for any up/down bag action, only the occasional use. Really, the compressor takes about 3 minutes to inflate the rear of the lincoln if you deflate the factory bags. Thats just to get it to ride height. Jason Quote Link to comment
makya Posted December 19, 2007 Author Report Share Posted December 19, 2007 thanks, the plan is to run two in parallel to a small tank, then to a valve. Quote Link to comment
nismopu Posted December 19, 2007 Report Share Posted December 19, 2007 its about the same size that subaru used and ust as weak IMO. it was always fun trying to pull town cars/ crown vics off the lift before reseting the air suspension. peace. Quote Link to comment
Jester Posted December 19, 2007 Report Share Posted December 19, 2007 How about useing an old air conditioning pump. Just make sure that you use a "York" type pump. The NON-York pumps don't have any stored lubrication in them. They get their lubrication from the freon(?) itself. They work, but not for long. Jester Quote Link to comment
phatdave Posted December 19, 2007 Report Share Posted December 19, 2007 I know DICK about air bags other than I have them on my tractor at work...why don't youse guys go to where they take wrecked SEMIS and get the comps off of those? Quote Link to comment
521Lvr Posted December 19, 2007 Report Share Posted December 19, 2007 I knew a guy that used an old ford a/c compressor on his wrecker for air like for tires. It worked great but was slow. I worked for Ford for 5 years and we replaced ALOT of pumps on Lincolns. Not very dependable Knowing that, I think I would use the largest tank I could find for maximum volume. tc Quote Link to comment
Pacific coast Datsun Posted December 19, 2007 Report Share Posted December 19, 2007 Spend a bit more & get a compressor made for the job. http://www.suicidedoors.com sells many different brands & sizes depending on what setup you are running. Ive seen the York pumps used before, a custom bracket will need to be fabbed to hold it. Check over @ http://www.nissancustoms.com & do a search for "york compressors"...lots of good info there. Quote Link to comment
datzenmike Posted December 19, 2007 Report Share Posted December 19, 2007 Caddys and some Buicks had a 12 volt compressor too. Very little volume, but like a dripping tap it would eventually fill a bath tub. Get the biggest tank you could to store some volume and let it refill during down time. continuous use like this may shorten it's life though. Car air con. pumps might work, but yeah most use freon oil mix to lube and peep them cool. Chrysler used to have a double piston compressor unlike the rotary vanes of to-day. Looked like a home compressor actually. I made a home compressor out of a hotel ice maker. It would take some time but would fill my compressor tank. On the 4th or 5th fill it slowed down and seized up. Maybe an oil drip on the intake? Oh well, cost nothing to try. Quote Link to comment
makya Posted December 19, 2007 Author Report Share Posted December 19, 2007 I've converted York pumps to run as air compressors. It's cheap to do,the problem is space. I already have a/c in the truck, so there's no more room(remember, this is Cali., I have to keep the smog pump). I was hoping to find a cheap alternative that won't pull a lot of amperage, I don't care if it's slow, it won't be used a lot. Quote Link to comment
]2eDeYe Posted December 19, 2007 Report Share Posted December 19, 2007 I know the caddy ones are pretty good, but you'll definitely want a tank for capacity. Harbor Freight has some that seem like they would work well, but I haven't seen any of those in action. Quote Link to comment
makya Posted December 20, 2007 Author Report Share Posted December 20, 2007 Okay guys, I just got this off of another website I'm on: from 84-92 Lincoln mark VII' date=' drivers side engine bay, late 89-9? continental is in the engine bay, not sure on Towncars, 93-98 Lincoln MarkVIII's, it is behind the fender I want to say passenger side, The pumps are slow, but seem to be pretty reliable if used occasionally, they are not a constant use pump, that will wear them out and burn them up.[/quote'] Quote Link to comment
Cruzn620 Posted December 20, 2007 Report Share Posted December 20, 2007 the duty cycle on those comps SUCK...and i have friends that have had bad luck with either buying an engine driven, or building their own out of a york. they are fast, but leak oil and stuff like that. you can't go wrong with an AZ or viar 450 or 380 IMO Quote Link to comment
makya Posted December 20, 2007 Author Report Share Posted December 20, 2007 Yorks aren't bad, you just have to really know what you're doing to make one last, making sure it has an oiling system. If I wanted speed and heavy use, I'd go York. I can build one with a pressure switch, gauge, tank, and air chucks to run air tools for under $200. But like I said earlier, I don't have the space for a York. I already have A/C, and I can't get rid of my smog pump. Plus, if I run a ViAir or similar, I have to worry about amp draw. Quote Link to comment
