Gensaiken Posted May 28, 2010 Report Share Posted May 28, 2010 I sware I've gotten one of these gaskets before but now I can't find it listed any where. Where do I find a water pump inlet gasket? This is the pipe inlet sticking off the L series block that the lower radiator hose connects to. I'd like to know where to get these. I've checked all the local stores and rockauto.com and come up with nothing. :unsure: Quote Link to comment
I'm BLUE Posted May 28, 2010 Report Share Posted May 28, 2010 I know what your talking about , the L-Series ( Z engine's that I worked with ) have the same , they were there last time I checked , but I had to look at the pattern really quick before looking for the different ones on RockAuto and are sometimes listed in different category's as well. Quote Link to comment
Gensaiken Posted May 28, 2010 Author Report Share Posted May 28, 2010 I know what your talking about , the L-Series ( Z engine's that I worked with ) have the same , they were there last time I checked , but I had to look at the pattern really quick before looking for the different ones on RockAuto and are sometimes listed in different category's as well. I figured Z's were the same and checked 240z on rockauto but didn't see it listed. I'm just wondering what else it would be called. Quote Link to comment
I'm BLUE Posted May 28, 2010 Report Share Posted May 28, 2010 hmmmmmmmmmmmmm just a sec :D Quote Link to comment
I'm BLUE Posted May 28, 2010 Report Share Posted May 28, 2010 Well that sucks ! My best bet is the "water outlet gasket" ( that has no picture to verify as you already know :mellow: ) I looked at a quick blow up picture of the "Engine Gasket Set" --- but no dice on the other , I have seen them before I guess googling the words might find a company that has a picture and price for ya :D Quote Link to comment
Gensaiken Posted May 28, 2010 Author Report Share Posted May 28, 2010 Well that sucks ! My best bet is the "water outlet gasket" ( that has no picture to verify as you already know :mellow: ) I looked at a quick blow up picture of the "Engine Gasket Set" --- but no dice on the other , I have seen them before I guess googling the words might find a company that has a picture and price for ya :D I found what you are talking about, this looks like it: http://shop.oreillyauto.com/ProductDetail.aspx?MfrCode=VIC&MfrPartNumber=C26076&PartType=144&PTSet=A Bummer, added it to my cart but it says its NLA. :( In the fel-pro full gasket set I see the gasket but thats a big $30-40 purchase. I might have found it. It appears to be part of the L-Series timing cover set. Still kind of expensive for a single gasket. http://shop.oreillyauto.com/ProductDetail.aspx?MfrCode=FEL&MfrPartNumber=TCS27155 Quote Link to comment
gen4maxima536 Posted May 28, 2010 Report Share Posted May 28, 2010 I think that gasket you're looking at in the timing cover set is for the distributor, I think. I've always made my own, a sharp knife or a pall peen hammer all you need. Quote Link to comment
Skib Posted May 28, 2010 Report Share Posted May 28, 2010 if you just need the one just get some gasket material and make it. super simple. Quote Link to comment
Gensaiken Posted May 28, 2010 Author Report Share Posted May 28, 2010 I think that gasket you're looking at in the timing cover set is for the distributor, I think. I've always made my own, a sharp knife or a pall peen hammer all you need. Yeah, I forgot about that one, think you are right. Looks pretty close. if you just need the one just get some gasket material and make it. super simple. Yeah, I know. A few places have just handed me that. I'm still searching :P Quote Link to comment
banzai510(hainz) Posted May 28, 2010 Report Share Posted May 28, 2010 there in the Felpro "front cover kit" also which is a cheaper purchase. somebody should have this. ck Carquest this is a common part. I usually never separet the inlets from th front cover any way unless a total rebuild. Quote Link to comment
420n620 Posted May 28, 2010 Report Share Posted May 28, 2010 Fel-Pro water pump gasket # 25569 for L16,L18,L20B,Z20E,Z20S,Z22E,Z22S engines 1968 to 87. Quote Link to comment
Gensaiken Posted May 29, 2010 Author Report Share Posted May 29, 2010 there in the Felpro "front cover kit" also which is a cheaper purchase. somebody should have this. ck Carquest this is a common part. I usually never separet the inlets from th front cover any way unless a total rebuild. Looks like the front cover kit gasket has a gasket that LOOKS like it but some one else pointed out that its for the distributor mount since the inlet doesn't connect to the front cover. It connects to the block. I've been pulling them off and never had trouble with a gasket before but now all of a sudden there are none available... Fel-Pro water pump gasket # 25569 for L16,L18,L20B,Z20E,Z20S,Z22E,Z22S engines 1968 to 87. Heh, didn't read the full thread huh? :P Water Pump INLET gasket not the water pump gasket. :lol: Quote Link to comment
I'm BLUE Posted May 29, 2010 Report Share Posted May 29, 2010 if you just need the one just get some gasket material and make it. super simple. +1 , this has been very handy for me many times as well :D Quote Link to comment
420n620 Posted May 29, 2010 Report Share Posted May 29, 2010 Looks like the front cover kit gasket has a gasket that LOOKS like it but some one else pointed out that its for the distributor mount since the inlet doesn't connect to the front cover. It connects to the block. I've been pulling them off and never had trouble with a gasket before but now all of a sudden there are none available... Heh, didn't read the full thread huh? :P Water Pump INLET gasket not the water pump gasket. :lol: sorrry about that, I guess my brain was having fun with me :poke: , at least u got the wp # incase you need it - someday. my bad I've got the water pump inlet # around here - somewhere. :frantics: might even have the gasket in the box still, me look later.. Quote Link to comment
datzenmike Posted May 29, 2010 Report Share Posted May 29, 2010 I believe the Z20, Z22, Z24 inlet gaskets are the same. I use a round hand held hole punch for making small holes in gaskets. All dollar stores have them. Just trace and start punching it out. Great for starting when using scissors for larger holes. Makes perfect round holes or curves. . Quote Link to comment
dat521gatherer Posted May 30, 2010 Report Share Posted May 30, 2010 i use hole punchers also. get the mr gasket sheet and reuse the same gasket that you make on and on. good thick material. i have a pile of gaskets i use as templates. Quote Link to comment
Gensaiken Posted June 1, 2010 Author Report Share Posted June 1, 2010 well, it turns out I had the gasket all along. I looked through some of my parts and found a front cover gasket set that I bought but never used. Looks like the kit (or at least this one) had the gasket for the water pump inlet. Quote Link to comment
