420n620 Posted March 6, 2010 Author Report Share Posted March 6, 2010 I think there was supposed to be a space or a "and" in there...get a battery tie down and clean up the basics...in other words, fix the bad or jury rigged junk first, then start cleaning the car up :) got it, I must of had a brain fart. Der :hmm: Hey man, nice snag. I was talkin' to the old lady, and was gonna drive over there an get it myself. Glad to see someone on here got it. It's a find :thumbup: Thanks, I can't wait to start tinkering with it this weekend, the PO got lots of calls on it, I'm just glad I was closer then the other pp that were interested in it, if I would have missed this goon, I would have been P'd off. Quote Link to comment
draga240z Posted March 7, 2010 Report Share Posted March 7, 2010 Wow its got a hitch hahaha nice car for cheap... :D Quote Link to comment
420n620 Posted March 7, 2010 Author Report Share Posted March 7, 2010 What kind of carb is that? Doesn't look like a normal Datsun carb. here a pic of the carb from the extra engine, it's the same as the one on the gOOn. do you know if it a Dastun carb, can't find it in my manual. Quote Link to comment
420n620 Posted March 8, 2010 Author Report Share Posted March 8, 2010 yesterday I had a little time to kill so I thought I would kill it on the gOOn. Washed the outside and cleaned ALL the windows inside / outside which made a hell of improvement plus it gave me the opportunity to find where the dents and rust were, found that the left 1/4 panel has a little damage, rear hatch and right rear door will need some work which I'll worry about that later down the road when the time comes. here shes is washed, looks a tons better. Also decide to check the valves and only 2 were just a little tight. While I had the valve cover off, I notice something not quite right, here's a pic with the cover on, see if you can spot it before I show you pic's of the not so right problem, clue this is a L16. also noticed I started to have accleration problems, it turned out the the arm that works the plungger had fell off, run lot better now. more to come. :thumbup: Quote Link to comment
banzai510(hainz) Posted March 8, 2010 Report Share Posted March 8, 2010 never see a carb setup like that before. if it works run it but looks jeery riged to me. Choke?????? looks like a intake bolt missing also Quote Link to comment
420n620 Posted March 8, 2010 Author Report Share Posted March 8, 2010 the carb pic in post #28 is from the spare motor, I noticed on the side of that block it had M2 where the goon motor doesn't, whats up with the M2, is it a HIPO motor. Quote Link to comment
hang_510 Posted March 8, 2010 Report Share Posted March 8, 2010 the only rare options you missed was the turn signal indicators on top of the fenders maybe from a dart? :cool: another is the addition of (later stock???) side marker lamps <_< remove those ASAP!!! and what are the plexi triangles for, on the doors??? Quote Link to comment
420n620 Posted March 8, 2010 Author Report Share Posted March 8, 2010 maybe from a dart? :cool: another is the addition of (later stock???) side marker lamps <_< remove those ASAP!!! and what are the plexi triangles for, on the doors??? Darts are very cool but not as cool as a Datsun gOOn. :) if I take off those extra side marker lights, there will holes, I'm thinking about putting the gOOn in a parade next month but if I can find the time before the parade, hell ya, I'm getting them off ASAP. I'm not sure what there for, maybe to help keep rain out, the wind or the PO wanted wing windows like the 60's muscle cars. Here today or tomorrow, they will be gone, anyone want them ~~~~~ FREE, just pay shipping.... :rolleyes: Quote Link to comment
mike Posted March 8, 2010 Report Share Posted March 8, 2010 That looks like a toyota carb off of a landcruiser. Probably 74 or newer as its got the electric choke. If you were into cruisers, considering the condition of that one it would make a good parts carb... Those turn signals also look ALOT like the "heads up" turn signals off of a mopar. My 68 Polara had something very similar. I was actually considering trying to find some of those for my 72 goon. I always liked being able to see the blinkers working just for peace of mind and they work well aesthetically. I am also curious what the difference in size is between the 68 mopar round marker lights and the factory 68 datsun marker lights. I like the goon, if you were to selectively remove some of the prior "modifications" it could be a pretty slick little ride... Stay away from the caulk gun though :unsure: Quote Link to comment
420n620 Posted March 9, 2010 Author Report Share Posted March 9, 2010 thats a cool idea about the 68 mopar round marker lights, the 66 67 dodge coronets had some pretty cool side marker lighs, might just have to look into finding a set for the rear 1/4's. since nobody guessed on the " not so right problem" you will notice that the fuel pump is wrong for the L16, the one in the pic is for a L20. Here's some pic's of what I found when I removed the VC. notice the little tab thats been brazed at the end of the fuel pump arm. and it's been welded where the arm comes into the head. it looks like it all will hold till I get the L16 out and install the 77 L20 later. Quote Link to comment
hang_510 Posted March 9, 2010 Report Share Posted March 9, 2010 since nobody guessed on the " not so right problem" you will notice that the fuel pump is wrong for the L16, the one in the pic is for a L20. Here's some pic's of what I found when I removed the VC. notice the little tab thats been brazed at the end of the fuel pump arm. whata repair! :o AFAIK the fuel pumps are the same for all L series. Quote Link to comment
420n620 Posted March 9, 2010 Author Report Share Posted March 9, 2010 I thought the L20's had a longer arm then the L18 ~ L16 because the L20 block was a little taller. :unsure: I checked my L20's and they had the larger diapham where the L16/18 had the smaller diapham. ?????? Quote Link to comment
hang_510 Posted March 9, 2010 Report Share Posted March 9, 2010 I thought the L20's had a longer arm then the L18 ~ L16 because the L20 block was a little taller. :unsure: the pump is attached to the head, not the block. :) diaphragm??? very well could be variations there... Quote Link to comment
420n620 Posted March 10, 2010 Author Report Share Posted March 10, 2010 the pump is attached to the head, not the block. :) diaphragm??? very well could be variations there... dang, I guess I wasn't thinking about the pump being mounting to the head. :hmm: I was kinda of in a hurry when I posted that. I checked my 72 510, 70 521, spare L16 and 74 620 all with L16 or 18 and they got the small diaphram, not sure when datsun started using the larger ones. I'd ask the PO where he got it but he passed away 2 yrs ago. O well, it works so it will stay. Quote Link to comment
M.Creer Posted December 18, 2010 Report Share Posted December 18, 2010 Updates? Quote Link to comment
greengoon Posted December 20, 2010 Report Share Posted December 20, 2010 Updates? I second that :D I want to see it done like your Photoshopped avatar. Enkei 92s and call it good. Its perfect rat and a '68 no less. Quote Link to comment
420n620 Posted December 20, 2010 Author Report Share Posted December 20, 2010 not much to up date. The only thing I've done on the gOOn is I bought a rear hatch and right rear door, got the front fender turn signal light/lens, replaced the left rear tail light lens, doing a little body work, cleaned and replaced some brake shoes, adjusted/bleed the brakes, filled the tranny which was almost dry and fixed the timing chain tensioners and replaced the timing cover. We just got our 1st snow for the season/year and this is how it sits for now. I'll be sweeping snow off her today, don't like it when the doors get frozen to the door seals. Thanks for the interest guys and want to thank Indy510 for doing a photochop on my 68 gOON.... :) This photo is what I'm going to shoot for. Quote Link to comment
M.Creer Posted December 21, 2010 Report Share Posted December 21, 2010 That photoshop looks good. Enkei 92 mesh, and slam. That would make your goon look great. Quote Link to comment
420n620 Posted December 21, 2010 Author Report Share Posted December 21, 2010 Thanks Creer, I like the looks of the Enkei and slammed also. I also like the looks of the te37 wheels but I don't have the skill or program to photo chop them onto the gOOn. Quote Link to comment
bonvo Posted December 22, 2010 Report Share Posted December 22, 2010 those arent gt-r wheels Quote Link to comment
420n620 Posted December 22, 2010 Author Report Share Posted December 22, 2010 those arent gt-r wheels corrected it. :) Quote Link to comment
Wide14u Posted December 22, 2010 Report Share Posted December 22, 2010 she looks so good i like the wheels they are going to be hot on it Quote Link to comment
WAGON JON Posted December 22, 2010 Report Share Posted December 22, 2010 Thanks Creer, I like the looks of the Enkei and slammed also. I also like the looks of the te37 wheels but I don't have the skill or program to photo chop them onto the gOOn. you could always buy them and put them on for real. Quote Link to comment
greengoon Posted December 22, 2010 Report Share Posted December 22, 2010 Here you go: ...and the stock and slammed look: Quote Link to comment
