jefe de jefes Posted December 9, 2009 Report Share Posted December 9, 2009 Does anybody recognize this animal? What does it fit?? Quote Link to comment
Jesse C. Posted December 9, 2009 Report Share Posted December 9, 2009 That looks like something straight off a JDM only type engine! I would call that "Dead Weight"! Quote Link to comment
jefe de jefes Posted December 9, 2009 Author Report Share Posted December 9, 2009 That looks like something straight off a JDM only type engine! I would call that "Dead Weight"! Dead weight? Cool , I'll put it in my aluminum boat. What anchor? Quote Link to comment
datzenmike Posted December 9, 2009 Report Share Posted December 9, 2009 Electric choke, accelerator pump. Has the swirl inducing butterflies like the KA24E and DE. I would say a carb manifold for a KA24DE. Even has the DE manifold bolt pattern . Or close to it. Where in the world would they have a non EFI KA24DE???? Quote Link to comment
datsunaholic Posted December 9, 2009 Report Share Posted December 9, 2009 There's no such thing as a (factory) carbbed KA24DE (being the "E" stands for EFI). There IS such thing as a KA20... South Africa...? Quote Link to comment
ggzilla Posted December 9, 2009 Report Share Posted December 9, 2009 KA24S, single-carb engine was fitted to the 1990-1993 Nissan 720 pickup. Quote Link to comment
datzenmike Posted December 9, 2009 Report Share Posted December 9, 2009 What I'm trying to say Doug is it's from a dual cam head. Then it's a KA24DS as I think it's from a DOHC. The intake on the left is from the KA24DE and is I think, a match. http://i138.photobucket.com/albums/q251/datzenmike/L%20Z%20Heads%20and%20Motors/motorKA24DEg.jpg[/img]"] Quote Link to comment
lynchfourtwenty Posted December 10, 2009 Report Share Posted December 10, 2009 hmmm.. im not seein the bolt patterns bein the same mike.. could it be from a napz? or some sort of diesel? Quote Link to comment
datzenmike Posted December 10, 2009 Report Share Posted December 10, 2009 :o while not exact, it is too close to deny it's not related. Maybe the head is drilled different but I think it fits the 4 valve KA motor. Quote Link to comment
lynchfourtwenty Posted December 10, 2009 Report Share Posted December 10, 2009 ya it says nissan on the carb also haha Quote Link to comment
ggzilla Posted December 10, 2009 Report Share Posted December 10, 2009 carbureted KA24? Quote Link to comment
datsunaholic Posted December 10, 2009 Report Share Posted December 10, 2009 No, I meant KA20, as in a 2.0L KA. South Aftrica had KA20DE, but it's possible there's a non-EFI version. Dual or single I can't say. I know Africa had carbbed VG30s. What it is NOT is a NAPS-Z intake. They look nothing like that- (Z24 ones will be square but have the same pattern) Nor is it a diesel as you don't have carbs on diesels and diesels can't use standard PCV valves. It's probably something completely different. Definately post-1980, and it's a feedback carb judging by the wires so probably post 1984. What I don't have is a good sense of scale. That carb looks really small- like something sub-2L, perhaps a GA16 or E16S. Or a Nissan Micra (MA12A). But the MA12 doesn't have that coolant passage on the side of the end runner. Quote Link to comment
lynchfourtwenty Posted December 10, 2009 Report Share Posted December 10, 2009 thats a good point, the b11/b12 sentras were carb'd (i dont know much about the naps or diesel lol) Quote Link to comment
nismo dr Posted December 10, 2009 Report Share Posted December 10, 2009 I think it is off a ga16 Quote Link to comment
nismo dr Posted December 10, 2009 Report Share Posted December 10, 2009 carb looks same - not sure exactly what that is Induction Kit to fit Nissan Sentra / Sabre 160, vertical throttle body model Quote Link to comment
jefe de jefes Posted December 10, 2009 Author Report Share Posted December 10, 2009 there are numbers stamped on the carb but they are small and faded. Quote Link to comment
datzenmike Posted December 10, 2009 Report Share Posted December 10, 2009 carbureted KA24? I think that's the throttle body D21 Hardbody truck KA24E Quote Link to comment
bonvo Posted December 11, 2009 Report Share Posted December 11, 2009 carb looks same - not sure exactly what that is Induction Kit to fit Nissan Sentra / Sabre 160, vertical throttle body model that doesnt explane the coolent passage in the mani Quote Link to comment
elmerfudpucker Posted December 14, 2009 Report Share Posted December 14, 2009 Hopefully I dont sound like too much of an idiot, but what is with the valves in the intake if it already has a carb???:confused: Quote Link to comment
datzenmike Posted December 14, 2009 Report Share Posted December 14, 2009 (edited) Hopefully I dont sound like too much of an idiot, but what is with the valves in the intake if it already has a carb???:confused: The butterfly valves are operated by manifold vacuum and are closed at idle and light throttle. The dual valves and huge ports cause the air/fuel to slow down too much on light throttle, so their purpose is to speed the air up around the injector and create turbulence to better mix the fuel and air before it enters the cylinder. As throttle increases, vacuum drops and the butterfly valves open. Only an idiot wouldn't ask a question. Edited December 14, 2009 by datzenmike Quote Link to comment
