gcmustang Posted April 1, 2012 Report Share Posted April 1, 2012 Man that thing sure works quick. My fingers would be gone in no time. lol Quote Link to comment
mklotz70 Posted April 1, 2012 Author Report Share Posted April 1, 2012 I'm afraid to put a new 24 grit belt on for just that reason! LOL Quote Link to comment
mklotz70 Posted November 25, 2012 Author Report Share Posted November 25, 2012 I used it to bevel the truck brake kit brackets today. WOW! I was amazed at just how fast and easy it went with this grinder...........and I have the speed set lower than before! lol Quote Link to comment
Creepy Cruiser Posted November 25, 2012 Report Share Posted November 25, 2012 That thing is awesome! Quote Link to comment
mklotz70 Posted November 25, 2012 Author Report Share Posted November 25, 2012 Thanks! I really didn't want to go with such a bit motor (3hp, 220V), but it barely slows down when I really push into it. It's a monster! Quote Link to comment
elmerfudpucker Posted November 25, 2012 Report Share Posted November 25, 2012 magnet+trash bag! + alum dirt with a sparkler wick...great for trimming things B), I love that monster, it pretty damned quick. Quote Link to comment
mklotz70 Posted November 25, 2012 Author Report Share Posted November 25, 2012 ? ....even after googling that, I'm still not sure what you mean. Did you move? Quote Link to comment
Z Speed Posted November 28, 2012 Report Share Posted November 28, 2012 One word; WOW! OK OK, two words; do want!! Great job man. That'll shorten many tasks ahead.... Quote Link to comment
mklotz70 Posted November 29, 2012 Author Report Share Posted November 29, 2012 Thanks! :) It will shorten fingers pretty quickly too! Quote Link to comment
mklotz70 Posted February 18, 2013 Author Report Share Posted February 18, 2013 The belt jumping has bothered me since the beginning of this project, but I got it to a managable amount and just dealt with it. While doing R&D for the next belt grinder, I found that my tension was only about half of what I needed. I did a vid showing the difference and how I measured the hardware store spring to find the right one for the next version. Quote Link to comment
mklotz70 Posted March 14, 2013 Author Report Share Posted March 14, 2013 a look at parts for the next version which should be available within the next month or so..... Quote Link to comment
mklotz70 Posted March 18, 2013 Author Report Share Posted March 18, 2013 It's alive :) 1 Quote Link to comment
darrel Posted March 20, 2013 Report Share Posted March 20, 2013 I see you used a better belt material in the latest video. For the end user that is a critical part that shouldn't be skimp on. Working with a Kval door sizer I would be spending more time adjusting the belt tension than running doors. Quote Link to comment
mklotz70 Posted March 20, 2013 Author Report Share Posted March 20, 2013 The biggest affect on tracking seems to come from the tension. Once it gets up around 30lbs, it tracks really nicely. On my other belt grinder, I fought with tracking all the time until I upped the tension to around 30......then I didn't have to mess with it at all. I think Dave got 3M belts for this one. Quote Link to comment
darrel Posted March 20, 2013 Report Share Posted March 20, 2013 The wrong belt and you would be adjusting the tension all the time because they stretch. Does it still need the 30# tension with the belt that doesn't stretch as much? Quote Link to comment
]2eDeYe Posted March 20, 2013 Report Share Posted March 20, 2013 That is awesome :D Quote Link to comment
fisch Posted March 20, 2013 Report Share Posted March 20, 2013 Freaking impressive Mike! Quote Link to comment
mklotz70 Posted March 20, 2013 Author Report Share Posted March 20, 2013 Thanks guys!! :) These new belts are pretty stiff, so they don't bend around the crown on the drive and tracking pulleys very easily.......but with the higher tension, they bend more. On my other grinder, the tracking was spotty with only 16lbs of tension. It tracked better with 20+ and it tracks awesome with the 30lb tension. Everything I could find online said the 2x72 belts ran best with about 30lbs of tension. Quote Link to comment
mklotz70 Posted March 20, 2013 Author Report Share Posted March 20, 2013 I'm way late for bed, but I'm pretty excited about the results of today's testing :) Quote Link to comment
mklotz70 Posted March 25, 2013 Author Report Share Posted March 25, 2013 I've posted some CAD pics of the grinder here..... http://community.ratsun.net/topic/45934-3d-modeling/?do=findComment&comment=882022 I've nearly done with the tweaks to the CAD art so we can submit it for the bulk order. I've integrate two different mountings on the front gusset. One for the box/switch setup that I have on my first grinder in case someone wants to put a motor larger than 2hp on it. They'll need that switch setup to run it. The second mounting is for a single gang box and a physically smaller 30A, 2 pole switch from Home Depot. It's for motors up to 2hp, but it's only $15 for this box/switch setup instead of the $70+ for the larger one. The larger unit is much more stout and would be better for more commercial use. I've also created a mount for a vfd. It will be a 110v to 3ph vfd. It will allow variable speed with a 1hp 3phase motor. The vfd is pretty large, so I didn't want it on the front gusset where it might be in the way and get hit. The mount is 2 piece. The lower part is 3/8" steel with the upper piece being 1/4" aluminum. The aluminum will be much easier for the customer to mount what ever they want to. I think we've covered the bases pretty well. There will be an 8" contact wheel and fish mouth setup available for it in the near future. I'm trying to get everything submitted so that we can have some of these on hand for the swap meet in april(1st weekend at PIR)......so I'm not sure I'll have time to get the other pieces completed. They're far enough along in the design phase to know that they will work with this grinder. :) Unless something changes drastically with the price of the parts and hardware, we've set the basic unit price at $750. It will come with the laser cut parts and hardware. No pulleys, motor or wiring. We're also going to drop the price to $600 for this first batch as an "introductory price". From there we'll gauge feedback and interest and adjust accordingly. The pulleys are about $200 from Beaumont Metal works. two 2", one 3.5", one 6". As a start up, we just can't afford or justify buying up 10-12 sets of pulleys right now. We'd need to mark them up a bit so it will just be cheaper for the buyer to order their own. If these sell well and we start looking at doing another batch, we'll look into having the pulleys made for us to see if they're any cheaper. Similarly with the motor setup. There's too many options for us to even consider buying/stocking them on hand and it will be cheaper for the buyer to get there's direct. The HF 1hp, wiring, plug, switch and box will run about $200 at normal prices. Catch them on sale with a 20% coupon and it will be closer to $150. The 1hp, 3ph motor, vfd and wiring is somewhere in the $300-350 range. For general purpose fabricating, I doubt there will be much need for variable speed, but for fine metal work or knife making, it's worth it. So....compare the intro price of $600 + $200(pulleys) + $200(HF motor setup) and it's $1000. I'd have to check again, but the closest KMG option is $1400. When you look at their prices, don't forget that you need the $115 base plate if you want to mount the motor to the grinder and not bolt it all to the bench. Anyway....that was a bit long winded. I'll be back with more pics to clarify the "basic" unit......but for now.....I've got to get back on the CAD and get that stuff finished!! :) Quote Link to comment
mklotz70 Posted March 26, 2013 Author Report Share Posted March 26, 2013 Since I didn't put any CAD pics here last time, I thought I'd put them here and a link in the other thread :) This is basically what to expect on the "basic" kit mentioned above. All the laser cut pieces and the hardware. These are images from me checking the fit and spacing of the new tool rest to make sure that it reached/cleared everything I wanted it too......including the upcoming fishmouth attachment and 8" contact wheel attachment. ....and a couple of quick renderings just for fun :) Quote Link to comment
mklotz70 Posted March 26, 2013 Author Report Share Posted March 26, 2013 oops....guess that one didn't actually come out as a rendering....just a unique angle. Quote Link to comment
fo0manchu Posted March 28, 2013 Report Share Posted March 28, 2013 Sweetness! Now to justify what I would need this for, besides a show piece in my garage... hmmmm... Quote Link to comment
mklotz70 Posted March 28, 2013 Author Report Share Posted March 28, 2013 Thanks :) Maybe when I get a chance, I'll design a stand for it so you can put it right in the middle of the garage......or living room :) Quote Link to comment
]2eDeYe Posted March 28, 2013 Report Share Posted March 28, 2013 Do you have a parts list for the purchased components? Quote Link to comment
