Eagle_Adam Posted June 24, 2013 Report Share Posted June 24, 2013 right? sounds like jessi is back up and running after a carb adjustment and a new bolt or 2 :D Quote Link to comment
nismo dr Posted June 24, 2013 Report Share Posted June 24, 2013 and fuck red loctite, I told jess I'd never work on it again :rofl: 1 Quote Link to comment
datzenmike Posted June 24, 2013 Report Share Posted June 24, 2013 I sheered the three bolt off on my 521. Didn't have the sense to try an fix it. Had a bud move the alt to the air pump side. Quote Link to comment
Eagle_Adam Posted June 24, 2013 Report Share Posted June 24, 2013 and fuck red loctite, I told jess I'd never work on it again :rofl: your just spoiled with air tools I sheered the three bolt off on my 521. Didn't have the sense to try an fix it. Had a bud move the alt to the air pump side. that almost sounds like more work.... Quote Link to comment
datzenmike Posted June 24, 2013 Report Share Posted June 24, 2013 I was younger then, everything the hard way... had a friend do it with a welder. Quote Link to comment
Eagle_Adam Posted June 26, 2013 Report Share Posted June 26, 2013 when we took the goon to eugene this weekend it over heated...... ended up only being able to find this a giant ass receipt covering the entire length of the bottom of the rad :sneaky: once jessi removed it there weren't any more overheating issues :confused: so after talkn to a few people ive come to the conclusion that A. the rad isnt operating 100% B. the lower half must be doing most of the cooling since when it got covered it overheated C. its time for an upgrade Soooooooooooooooo........ Here's the upgrade! picked this aluminum rad up from NismoDr's 610, it should be all that this goon ever needs cooling wise!!!! and i got a Nissan Thermostat to boot cus i can :D Quote Link to comment
izzo Posted June 26, 2013 Report Share Posted June 26, 2013 Good job dude. Should do the trick and then some! Save that old rad. Its probably still good but needs a flush from an actual rad shop. Someone probably use it sometime! Quote Link to comment
Eagle_Adam Posted June 26, 2013 Report Share Posted June 26, 2013 im not trashing it! just done fucking around..... its a 610 rad i pulled from the JY Quote Link to comment
converted_to_datsun Posted June 27, 2013 Report Share Posted June 27, 2013 Dang now to paint the radiator purple ;) Quote Link to comment
Siqx20 Posted June 27, 2013 Report Share Posted June 27, 2013 i say powder the upper and lower tanks ;) Quote Link to comment
Eagle_Adam Posted June 27, 2013 Report Share Posted June 27, 2013 not this time, gunna polish it up and might get it installed this weekend if i stay motivated Quote Link to comment
ProjectFeint Posted June 27, 2013 Report Share Posted June 27, 2013 Sapporo overflow can? hahaha that's awesome keep it up man, that bay is going to be blingin B) Quote Link to comment
Eagle_Adam Posted June 27, 2013 Report Share Posted June 27, 2013 Sapporo overflow can? hahaha that's awesome :rofl: :rofl: :rofl: compliments of the PO of the rad :thumbup: Quote Link to comment
Eagle_Adam Posted June 27, 2013 Report Share Posted June 27, 2013 well....... seems like i have another project to do on the goon :/ not exactly thrilled about it, long story short the alignment shop the goon went to was "nice" enough to adjust the steering box while they had the goon.... and they over tightened it, and now i need to source a new box and install it :( Quote Link to comment
mklotz70 Posted June 27, 2013 Report Share Posted June 27, 2013 Did it break or just get tight? You can adjust it....maybe get some more life out of it. Quote Link to comment
Eagle_Adam Posted June 27, 2013 Report Share Posted June 27, 2013 its not broken mike, and i did adjust it so she can actually drive it with having the wheel ripped from her hands... Quote Link to comment
datzenmike Posted June 27, 2013 Report Share Posted June 27, 2013 What's it doing? Too loose and you have to swing the wheel in wide arcs to stay straight. Too tight and the wheel sticks on tight corners and won't auto return to straight Quote Link to comment
Eagle_Adam Posted June 27, 2013 Report Share Posted June 27, 2013 no, at the apex of each turn regardless of full lock or not when you go the opposite direction there is a noticeable "clunk" that can be felt in the wheel. As i adjusted it yesterday the "clunk" got better but is still present Quote Link to comment
datzenmike Posted June 27, 2013 Report Share Posted June 27, 2013 Get the front end up off the ground and watch while having it turned. Maybe there is something else binding? Quote Link to comment
Eagle_Adam Posted June 27, 2013 Report Share Posted June 27, 2013 nope.... did that yesterday, you can feel the knock coming from the steering column/box - kinda feels like the joint in between Quote Link to comment
datzenmike Posted June 27, 2013 Report Share Posted June 27, 2013 I'll go find the one I have when it stops raining. Quote Link to comment
Eagle_Adam Posted June 27, 2013 Report Share Posted June 27, 2013 sweet, thanx mike Quote Link to comment
Eagle_Adam Posted July 12, 2013 Report Share Posted July 12, 2013 ended up swapping an original fuel pump into the goon, just heard to many horror stories about the aftermarket ones failing... Also ordered the parts needed to finish up the Klotz big break upgrade!!! other than that jessi has just been rocking the goon with no new issues Quote Link to comment
Eagle_Adam Posted July 15, 2013 Report Share Posted July 15, 2013 jessi had said on friday that he front breaks were acting up, so sunday night after we wrapped up with my brothers truck and took a look at her breaks... the front pads are toast so we will probably have to do a pad slap before the break upgrade Quote Link to comment
Eagle_Adam Posted July 17, 2013 Report Share Posted July 17, 2013 yesterday was the day.... time for a pad slap.... not happy we had to spend the $ on pads just before a break upgrade but oh well.... Jessi mentioned she had never replaced front breaks, only rears... Soooo... i let her do the work yesterday since i was sicker than a dog :D Pads were TOAST! Sooo atleast those are done and the wagon stops correctly again!!! AND some much awaited parts came in today too!!!! HUGE THANX TO D MIKE!!!!!!!!!!!! got the steering box in today, cant thank you enough man! also got the new calipers in for the break upgrade!! just waiting on pads and rotors! 2 Quote Link to comment
