Laecaon Posted June 13, 2013 Report Share Posted June 13, 2013 Actually it was only 10.8V through the headlight fuses, which is what raised the red flag. But that was with car off, so I want to check again with the car running. Actually should just check the at the bulbs themselves... I still have a feeling a nice relay harness will be made. Quote Link to comment
Eagle_Adam Posted June 13, 2013 Report Share Posted June 13, 2013 Ur the wiring guru bro! Just lemme know ;) The goon goes in for its alinement today!!! Since it couldn't happen before canby :: Quote Link to comment
Guest_kamakazi620 Posted June 13, 2013 Report Share Posted June 13, 2013 Pfft. You fill the wiper bottle with bleach... newbs.bleach is what you use when you HAVE hp+tq for smoke show WD40 is what you use with L series and automatic, stuntmen use that setup to get an underpowered car sideways........btw THREAD JACK!!!!!!! And "Noob" is dead ded dead...... 1 Quote Link to comment
Eagle_Adam Posted June 13, 2013 Report Share Posted June 13, 2013 took a trip down memory lane via my photobucket folder for the goon..... thought this was post worthy before: After: 4 Quote Link to comment
heretic Posted June 13, 2013 Report Share Posted June 13, 2013 :) very nice "up grade" Adam Looks great.! Quote Link to comment
Eagle_Adam Posted June 13, 2013 Report Share Posted June 13, 2013 thanx man! there literally isn't a system or body panel i have not touched on the car.... from the time i got my hands on it till now its become a whole new car and i know members that have know the car for years can attest to that 1 Quote Link to comment
Eagle_Adam Posted June 13, 2013 Report Share Posted June 13, 2013 the goon got its alignment today!! Night and day difference!!! and they tweaked with the steering box and got rid of the dead spot in it!!! Quote Link to comment
Eagle_Adam Posted June 13, 2013 Report Share Posted June 13, 2013 Pace-Way Frame & Axle Services 1563 SE River Rd Hillsboro, OR 97123(503) 648-2213 they are freekn awesome, if you need an alignment i would hands down send you there!!!!!! $39 for an alignment and steering box adjustment!!!!!!!!!!!!!!!!! 1 Quote Link to comment
Eagle_Adam Posted June 13, 2013 Report Share Posted June 13, 2013 next up will be the break upgrade klotz put together!! Quote Link to comment
Eagle_Adam Posted June 14, 2013 Report Share Posted June 14, 2013 got to drive the goon a bit yesterday! with an alignment and steering box tune up its MUCH better now!! & the goon goes into the carb and tune up guy today!!! should be interesting to see what shes like when the valves have been set hot, timing properly adjusted after the valves and the carbs leaned out a bit to find the sweet spot.... or maybe hes just gunna say fuck it i dont wanna.... we shall see :D Quote Link to comment
Eagle_Adam Posted June 14, 2013 Report Share Posted June 14, 2013 made it to the carb shop, man i love this guy!!!!! (nohomo) got the valves adjusted hot then he went to town on tuning It lives!! IT LIVES!!!!!!!!!!!!!!!!!!! MUCH BETTER NOW! still diesels when its shut off tho... Quote Link to comment
its_karl Posted June 14, 2013 Report Share Posted June 14, 2013 You'd need a way to completely shut the throttle to get that to stop. I used to clutch kill mine, not sure if that's worse to do. My 710 goon was notorious dieseler as well.. Quote Link to comment
RedBanner Posted June 14, 2013 Report Share Posted June 14, 2013 Dont drop the.clutch to.kill it. When you turn the key off floor it. 1 Quote Link to comment
its_karl Posted June 14, 2013 Report Share Posted June 14, 2013 mine was bad enough that it caused the a valve seat to drop, of course fuel cooling the seat in a hot head. That's how they're installed, makes sense they could fall out that way. It provided warning too, I just couldnt figure out what the intermittent chatter was. ended up replacing head, gasket, timing set, and ran alot nicer, eventually started dieseling again though. Quote Link to comment
Laecaon Posted June 15, 2013 Report Share Posted June 15, 2013 My car diesels from 1) too low of octane 2)too rich of idle mixture 3)too much advance. With my weber, I just turned the idle mixture screw a quarter turn leaner and my dieseling stopped. 1 Quote Link to comment
Laecaon Posted June 15, 2013 Report Share Posted June 15, 2013 I ordered some electrical supplies to relay the headlights. It should come out pretty nice, and clean looking. 1 Quote Link to comment
MicroMachinery Posted June 15, 2013 Report Share Posted June 15, 2013 Dont drop the.clutch to.kill it. When you turn the key off floor it. ^^This. Quote Link to comment
datzenmike Posted June 15, 2013 Report Share Posted June 15, 2013 Why waste gas? Just hold the brake and let the clutch up enough to slightly load the motor so it struggles to idle and just turn off. Wait for it to stop to prevent jerking and then release the pedal fully. A passenger won't even know what you're doing with practice. When you think of the abuse a clutch gets daily this is nothing to worry about. Done this for years. Quote Link to comment
MicroMachinery Posted June 15, 2013 Report Share Posted June 15, 2013 There's no clutch yet ... well, unless you count the multiple clutch plates and friction discs inside the 3N71B ;) 4 Quote Link to comment
Guest_kamakazi620 Posted June 15, 2013 Report Share Posted June 15, 2013 There's no clutch yet ... well, unless you count the multiple clutch plates and friction discs inside the 3N71B ;)drop it in "d"???? 1 Quote Link to comment
MicroMachinery Posted June 15, 2013 Report Share Posted June 15, 2013 I wondered if that would work.. Quote Link to comment
datzenmike Posted June 15, 2013 Report Share Posted June 15, 2013 Yes, just shut off idling in gear, then put in park. Done this too. Quote Link to comment
Eagle_Adam Posted June 17, 2013 Report Share Posted June 17, 2013 fuck this goon is fast.... truck wasn't ready this morning and jessi had the day off so i got to drive it into work.... the linkage wants to bind on the carbs tho....... so that needs addressed ASAP before the throttle sticks and the goon is no more Quote Link to comment
MicroMachinery Posted June 17, 2013 Report Share Posted June 17, 2013 the linkage wants to bind on the carbs tho....... so that needs addressed ASAP before the throttle sticks and the goon is no more "Wow this thing's fast! I'm standing on the brakes and I'm still going 60!" 3 Quote Link to comment
